05-13-2012, 04:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1717221 Status: Offline Thanks Meter: 87 | 5800 show contact the retailer HOW TO SOLVED 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... MCU Version V ICPR72_09w20.15 MCU Date 30-12-09 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 353382042163266 Mastercode 5660612214 IMEI Spare 3A35830224612306 IMEI SV 3335830224612356F6000000 PSN MTJ903289 Product Code 0588613 Module Code 0204538 Basic Product Code 0592754 PSD 0000000000000000 LPSN 0 WLAN MAC 80501B0F7766 APE SW V 10.4.101 APE Variant V 10.4.101V 10.4.101 V 10.4.101 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1104 RFIC 17141716 DSP tube_ICPR72_09w19_1_p1 Simlock Server SIMLOCK SERVER Simlock Key 4500000088401881 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ E000 Data: 450FFF Auto Selecting Flash Files on User Request... Product Code: 0588613 This is Valid BB5 Product Variant found for readen Product Data! Started Phone Security Analysis... MCU Version V ICPR72_09w20.15 MCU Date 30-12-09 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 353382042163266 Mastercode 5660612214 Reading Security Block... Security block OK and saved to "RM- 356_353382042163266_5132012_93425 AM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block WARNING: "1E700103669A00524827A9492BA9C7DEC0B08F94.C0000366 " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1E700103669A00524827A9492BA9C7DEC0B08F94 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Sending Auxiliary Loader... Auxiliary Loader Sent! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... Readed OK, Saving to "1E700103669A00524827A9492BA9C7DEC0B08F94.C0000366 " Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! |
The Following User Says Thank You to FullFlash. For This Useful Post: |
05-13-2012, 04:16 | #2 (permalink) |
Member: 1717221 Status: Offline Thanks Meter: 87 | PM AND SELFTEST Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_MBUS_RX_TX_LOOP_TEST Passed ST_AMB_LIGHT_SENSOR_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST |
The Following 2 Users Say Thank You to FullFlash. For This Useful Post: |
05-13-2012, 05:41 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST imei is fine too This mobile as software side looks 100% fine CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 this mobile is sl3 version new hash so must be unlocked via bruteforce BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
05-13-2012, 06:13 | #5 (permalink) |
Member: 1717221 Status: Offline Thanks Meter: 87 | same this phone http://forum.gsmhosting.com/vbb/f528...-dead-1473894/ |
05-13-2012, 10:57 | #8 (permalink) |
Member: 1717221 Status: Offline Thanks Meter: 87 | alex flash error please check Code: FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Sending XSR Configuration... XSR Configuration OK Writing all blocks... Initializing TurboCache... TurboCache Loaded! Block Write Failed -> Failed to write CMT FUR data header and payload at 0x20165 Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process 5800_SW_0634515_Korea_4G_1.1.fpsx |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
Ringtones from the charts and new Links | GM | GSM Mobile Links | 0 | 09-26-1999 13:54 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
