07-03-2012, 19:49 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: anywhere
Member: 847047 Status: Offline Thanks Meter: 24 | 6085H RM-198.. vibrate and remains in the logo. [ Solved ] After flashing, vibrate and remains in the logo. Any possible solution .. Can’t read Info from phone… I backup: RPL from Phone, Cert and PM Log: Check Flashing Bus: Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 04F0000E58F36A5094C470295F54280166FD03FC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C44614CCC0A09C4A52B890FA55B4B31AF4787668 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Failed to read info -> Phone not detected Flashing: rm198_CareDP_19.9_NA_LTA v05.03 Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm198__05.03.mcusw.bin (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 04F0000E58F36A5094C470295F54280166FD03FC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm198__05.03.mcusw.bin, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C44614CCC0A09C4A52B890FA55B4B31AF4787668 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x0110FFFF, NOR Waiting 320s for erasure finish... Erase taken 63.540s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT DSP0 Certificate... Writing CMT PMM_CONF Certificate... Writing CMT SBIF_CONF Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PRIMAPP Certificate... Writing CMT UPDAPP Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 63.539s Flashing Speed: 1908.22 kBit/S Restarting MCU... Processing rm198__05.03.mcusw.bin (APE)... Processing rm198__05.03.ppm_i (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 04F0000E58F36A5094C470295F54280166FD03FC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm198__05.03.ppm_i, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C44614CCC0A09C4A52B890FA55B4B31AF4787668 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01120000-0x015DFFFF, NOR Waiting 320s for erasure finish... Erase taken 12.948s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 12.12s Flashing Speed: 1954.03 kBit/S Restarting MCU... Processing rm198__05.03.ppm_i (APE)... Processing rm198b405.03.image_i_na_BP (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 04F0000E58F36A5094C470295F54280166FD03FC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm198b405.03.image_i_na_BP, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C44614CCC0A09C4A52B890FA55B4B31AF4787668 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x015E0000-0x01FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 46.940s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 12.137s Flashing Speed: 2074.80 kBit/S Restarting MCU... Processing rm198b405.03.image_i_na_BP (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! Still reboot at Logo. What can I do? BR |
07-03-2012, 20:35 | #2 (permalink) | |
Freak Poster Join Date: Sep 2010 Location: VeneZueLa
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | have a copy of RPL and PM? download the version 6.1 which is the latest update for this model and flash it. sure remember having copies of RPL and PM. Quote:
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
