04-12-2013, 06:58 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 85658 Status: Offline Thanks Meter: 5 | cyclonebox only Bootloader Mode (Solved) |
04-12-2013, 20:08 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
http://forum.gsmhosting.com/vbb/4706746-post1.html BR. Arsalan gsm2000. | |
04-13-2013, 15:03 | #5 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Post your box serial number here http://forum.gsmhosting.com/vbb/show....php?t=1423606 |
04-16-2013, 22:44 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Please Post / Paste the Box Service Tag, which is copied to Clipboard, when you run the Box Wizard. Also, check the other posible error causes pointed in the "Error popup message" |
04-17-2013, 00:48 | #8 (permalink) |
Member: 85658 Status: Offline Thanks Meter: 5 | Clip Maintenance Tool Ready, Engine Revision: 1.0.1.923 Opening Box... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Failed to Check Clip -> No connection was established, or box is not in needed mode |
04-17-2013, 21:38 | #11 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Please, to help you WE NEED that YOU POST HERE your Box Service Tag, wich is copied to your "Clipboard", you just need to right click and paste it here, when you reply Without your Box Service Tag or Box Serial Number (NOT THE CYAxxx) is IMPOSIBLE to help you. |
