04-26-2011, 22:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Dominican Republic Age: 49
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | errol errol Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.57, (Mar 10 2011 12:45:53, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 wk9 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000xxxxx HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23 Initializing security card... Card Serial Number: D008xxxxx Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5,09v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,04v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V m3.35 MCU Date 13-10-05 Product RM-75 (Nokia 6030b CABLE 1100) Manufacturer (c) Nokia. IMEI 0109280041xxxxx Mastercode 1171511246 Proceeding with RSA Unlock... Setting Local Mode... Local mode Set Asic 2 HW Signature 44A0EB7B8729D744 Simlock Server SIMLOCK SERVER VERSION 58 Simlock Key 3101700000000000 Simlock Profile 8000000000000002 Simlock Aux 00025555 Simlock IMEI 00550109280041345900 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310150 Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310170 Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 311180 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Asking card to sign HW Signature... Signed OK (7F459C12422F6C1E928793FA5EA45283832BA008) Calculating SP... Writing SP... Failed to Unlock DCT4 Plus -> Possible cause: Other error (0x00) |
04-26-2011, 23:09 | #2 (permalink) |
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | with this new Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.57, (Mar 10 2011 12:45:53, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 wk9 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000xxxx HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23 Initializing security card... Card Serial Number: D008xxxxx Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5,09v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,03v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 5,04v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Failed to Unlock DCT4 Plus -> Phone not detected Booting UPP... UPP ID: 2031 [HW_UPP4M_v3] Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020882E @ 0x01000000, ST, SectorSize: 128kB, Ext: 00007121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020882E (128Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Terminating flash session Boot operation took 6.62s Check Flashing Bus finished MCU Version V m3.35 MCU Date 13-10-05 Product RM-75 (Nokia 6030b CABLE 1100) Manufacturer (c) Nokia. IMEI 0109280041xxxxx Mastercode 1171511246 Proceeding with RSA Unlock... Setting Local Mode... Local mode Set Asic 2 HW Signature A605BC7DEBF6224A Simlock Server SIMLOCK SERVER VERSION 58 Simlock Key 3101700000000000 Simlock Profile 8000000000000002 Simlock Aux 00025555 Simlock IMEI 00550109280041345900 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310150 Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310170 Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 311180 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Asking card to sign HW Signature... Signed OK (7BFA20B010CDF224083EFF3D654EC2226B73595D) Calculating SP... Writing SP... Failed to Unlock DCT4 Plus -> Possible cause: Other error (0x00) Booting UPP... UPP ID: 2031 [HW_UPP4M_v3] Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020882E @ 0x01000000, ST, SectorSize: 128kB, Ext: 00007121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020882E (128Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,02V Terminating flash session Boot operation took 7.156s Check Flashing Bus finished MCU Version V m3.35 MCU Date 13-10-05 Product RM-75 (Nokia 6030b CABLE 1100) Manufacturer (c) Nokia. IMEI 0109280041xxxxx Mastercode 1171511246 Proceeding with RSA Unlock... Setting Local Mode... Local mode Set Asic 2 HW Signature 57D49981766F1C04 Simlock Server SIMLOCK SERVER VERSION 58 Simlock Key 3101700000000000 Simlock Profile 8000000000000002 Simlock Aux 00025555 Simlock IMEI 00550109280041345900 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310150 Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310170 Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 311180 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310410 Asking card to sign HW Signature... Security Card Process APDU Error -> Problem with APDU processing, Possible error: APDU not responding Failed to calculate HW Signature -> APDU Process problem Failed to Unlock DCT4 Plus -> Failed to calculate HW Signature |
errol furious golds no open | jai123 | FuriousGold | 11 | 04-16-2010 07:17 |
white screen n70 hang errol ape | mark_07 | Nokia Hardware & Hardware Repair | 0 | 09-15-2009 10:45 |
white screen n70 hang errol ape | mark_07 | Nokia Hardware & Hardware Repair | 0 | 09-15-2009 10:38 |
white screen n70 hang errol ape | mark_07 | Nokia Hardware & Hardware Repair | 0 | 09-15-2009 10:37 |
s521a errol | cdmagsm03 | Infinity-Box | 1 | 04-08-2009 21:01 |
