01-08-2010, 15:33 | #1 (permalink) |
Major Poster Join Date: Mar 2005 Age: 68
Member: 131470 Status: Offline Thanks Meter: 9 | security test Fail nokia 5800 [SOLVED] Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8198 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: C00****1 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D40000DF Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,95v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,76v PASSED VBAT Voltage 0,66v PASSED VBAT Voltage 4,88v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,86v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V ICPR72_09w20.12 MCU Date 10-09-09 Product RM-356 Manufacturer (c) Nokia IMEI 35691003******* Mastercode 104431535 IMEI Spare 3A65190033347603 IMEI SV 3365190033347643F8000000 PSN 0 PSD 0000000000000000 LPSN 0 WLAN MAC 0026CCB4F04F APE SW V 31.0.101 APE Variant V 31.0.101V 31.0.101 V 31.0.101 APE Test eno_version APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 RFIC 17141715 DSP ICPR72_09w19_1 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Selftests to proceed: 50 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Failed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_MBUS_RX_TX_LOOP_TEST Passed ST_AMB_LIGHT_SENSOR_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_CAMERA_ACCELERATOR_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LED_FLASH_TEST Passed ST_CAMERA_AUTOFOCUS_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_TOUCH_STUCK_TEST Passed ST_BT_WAKEUP_TEST Passed ST_WLAN_TEST Passed ST_BT_WLAN_COEXISTENCE_TEST Passed ST_TOUCH_IF_TEST Passed ST_ACCEL_IF_TEST Passed ST_LCD_CONTROLLER_TEST Passed ST_VIBRA_TEST Passed ST_USB_LOOP_TEST Passed ST_RADIO_TEST Passed ST_TVOUT_IF_TEST Passed ST_IO_EXPANDER_IF_TEST Selftests done, Tests total: 50, Tests passed: 49, Tests not passed: 1 |
The Following User Says Thank You to langin For This Useful Post: |
01-08-2010, 16:04 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | To solve "Failed ST_SECURITY_TEST" you need to write PM fields 1 & 309, using SX4 auth. you can download PM from: http://www.ptt.4mg.com/Gsmforum/PM/ BR |
01-09-2010, 09:47 | #3 (permalink) |
Member: 131470 Status: Offline Thanks Meter: 9 | Thanks, but also writing PM Fields 1 & 309 does not change! The only way to pass the Security Erase SELFTEST is to make a change imei 1234 ... Initializing box... Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: C00****1 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D40000DF Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,96v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,66v PASSED VBAT Voltage 4,87v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 4,88v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V ICPR72_09w20.12 MCU Date 10-09-09 Product RM-356 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8198 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: C00****1 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D40000DF Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,95v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,77v PASSED VBAT Voltage 1,61v PASSED VBAT Voltage 4,87v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 4,86v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Selftests to proceed: 50 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_MBUS_RX_TX_LOOP_TEST Passed ST_AMB_LIGHT_SENSOR_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_CAMERA_ACCELERATOR_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LED_FLASH_TEST Passed ST_CAMERA_AUTOFOCUS_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_TOUCH_STUCK_TEST Passed ST_BT_WAKEUP_TEST Passed ST_WLAN_TEST Passed ST_BT_WLAN_COEXISTENCE_TEST Passed ST_TOUCH_IF_TEST Passed ST_ACCEL_IF_TEST Passed ST_LCD_CONTROLLER_TEST Passed ST_VIBRA_TEST Passed ST_USB_LOOP_TEST Passed ST_RADIO_TEST Passed ST_TVOUT_IF_TEST Passed ST_IO_EXPANDER_IF_TEST Selftests done, Tests total: 50, Tests passed: 50, Tests not passed: 0 |
01-09-2010, 10:03 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Flash it with the eno firmware and afterward again full flash it same version. the mobile should start now again. To solve the security test try writing again the CCC.NPC and HWC.NPC certificate in the mobile and try again the sx4 auth and PM 1 and 309. You can use as well the certs of another mobile same product code. BR Alex |
01-10-2010, 10:25 | #6 (permalink) |
Member: 131470 Status: Offline Thanks Meter: 9 | Grande Alex! I performed the procedure with the same problem with a 3120c HWC wrote CCC and a 3120c with the same version of firmware and modified with full-PM ONLY (no 120 no 308) and the phone is working again! Now I'm going to get a 5800 working and repeat the procedure with the 5800! Thank you! |
01-10-2010, 16:34 | #8 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: king solomons temple
Member: 301387 Status: Offline Thanks Meter: 51 | Quote:
what eno firmware. | |
01-10-2010, 17:12 | #9 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | The one for the RM-356 you can find in this recovery kit http://rapidshare.com/files/28293637...covery_kit.zip BR Alex |
01-10-2010, 22:24 | #10 (permalink) |
Member: 131470 Status: Offline Thanks Meter: 9 | Everything ok on 5800, back running! I did not use the file Eno. I flash the full flash HWKuFs and the phone is gone! I restored the imei with MX-key, imei rebuildet! And finally I wrote the Cyclone CCC.NPC and HWC.NPC another 5800 same firmware, most recently with permission SX4 I wrote the PM (no 120 and 308) of the 5800 itself! Fully functional! |
nokia n76 sucussfully phonestartup failure solved .security test fail solved | manish_jain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-14-2011 06:55 |
Help with Nokia 3500 with security test failed? [ Solved ] | geovanny78 | Cyclonebox | 2 | 02-18-2010 00:27 |
HELP MX TEAM NOKIA 5800 RM 428 security test failed!!!! | michael garcia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-08-2010 02:22 |
security test failed how to solve | newtouch | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-05-2010 13:15 |
phone start-up failed nokia 5800 [SOLVED] | a2b2t | Cyclonebox | 28 | 12-12-2009 15:58 |
