04-17-2011, 16:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | HELP! nokia 5230 no power and problem flashing... my 5230xm rm-588 have problems ....this is the log another problem my box not have in bootloader mode log complete with PASSED etc screen: Uploaded with ImageShack.us Using cable f-bus 5800 by gpg problem boot CMT not aliment the battery Thanks, BR. 3. Check USB cable quality, connect to USB 2.0 Port 4. It may be also phone hardware problem 5. Also, loader may be corrupted, or current BootROM don't support it (affected are RAP3Gv3 and RAPIDO phones) Failed to Process all Image files -> Failed to process RM-588_40.0.003_prd.core.C00 Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-588_40.0.003_prd.core.C00 (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D60001090930052A60790E10481B3793DCACE20 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-588_40.0.003_prd.core.C00, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... Processing Flash Image Failed -> The ROM Refused to start Secondary Loader. Common Reasons: 1. Battery voltage is too low. 2. Transmission error occured. Usually happens when You put battery on while USB cable plugged. Try unplug USB cable, re-insert battery, plug USB Cable. 3. Check USB cable quality, connect to USB 2.0 Port 4. It may be also phone hardware problem 5. Also, loader may be corrupted, or current BootROM don't support it (affected are RAP3Gv3 and RAPIDO phones) Failed to Process all Image files -> Failed to process RM-588_40.0.003_prd.core.C00 |
04-18-2011, 03:39 | #3 (permalink) | |
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
not solved problem HW,the mainboard have problem VBAT ( non si alimenta anche con il caricabetteria) no charging ,in italy the CAT master today new mainboard Ciao Carissimo King Regards Simone | |
04-18-2011, 08:38 | #4 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Roma (Italy)
Member: 1173993 Status: Offline Thanks Meter: 46 | If there is still that problem, you have to check BETTY and the VBAT lines to it. But to change BETTY, you have to remove from another board, coz it's quite impossible to find it in an e-store . Bye |
The Following User Says Thank You to nicolati For This Useful Post: |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
