richardex78 | 08-25-2011 19:15 | Quote:
Originally Posted by ptt
(Post 7660986)
Please post the Log of "ALL" Process, not only the "error" part
BR | Ok this is the log: Code:
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia/Blackberry Application v01.66, (Jul 19 2011 16:55:18, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: Cxxxxxxxxx
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32
Initializing security card...
Card Serial Number: D700028E
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5,09v PASSED
MCU Voltage 3,30v PASSED
Core Voltage 1,76v PASSED
VBAT Voltage 1,15v PASSED
VBAT Voltage 4,99v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 4,92v PASSED
Box VPP disabled
VPP Voltage 0,02v PASSED
External Box VPP Enabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Booting CMT...
APE_SYSTEM_ASIC_ID: 24200705
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: 6266553C18A495E3FCE06B6707FD0B186E884D44
APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1FD00113916B0052030DB945D50CC31F6829BBB0
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: A8C1D671
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020880400006B21, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip 0x00208804 (ST), Size: 8MBytes, VPP: 9V
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
OMAP2420_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.14.0, Algo: BB5
Adding FUR Client (APE, State: Start)...
APE FUR Ready!
FlashChip[0,APE]: 0x0000000000000000, Unknown, RAM
FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,APE]: 0x00EC004000000000, Samsung, ONENAND
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
OMAP2420_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.14.0, Algo: OMAP2420 UNISTORE-II-1.5.1 ALG
TurboCache Loaded!
Writing APE KEYS Certificate...
Writing APE PASUBTOC Certificate...
Writing APE ALG Certificate...
APE Algorithm Ready!
Adding FUR Client (APE, State: Ready)...
APE FUR Ready!
Box VPP disabled
Internal APE Phone VPP Enabled
PAPUBKEYS Hash for APE: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
CMT NPC Ok
CMT HWC Ok
CMT CCC Ok
CMT R&D Ok
CMT VARIANT Ok
CMT PAPUBKEYS Ok
CMT KEYS Ok
APE NPC Ok
APE HWC Ok
APE CCC Ok
APE R&D Ok
APE VARIANT Not Found
APE PAPUBKEYS Ok
APE KEYS Ok
Restarting MCU...
Read all certificates finished
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Simlock Store not supported, not a PA_SL2 Phone
Trying to store WMDRM RPL...
Reading Keys...
Failed to Create RPL from phone -> Failed to read WMDRM Key
Proceeding with Recovery Mode...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE FUR Ready!
TurboCache Loaded!
APE FUR Ready!
Box VPP disabled
NPC Backup stored in "1FD00113916B0052030DB945D50CC31F6829BBB0_25082011_111852.NPC.CMT.crt"
Set to Recovery Mode Finished
Failed to Create RPL from phone -> Failed to read Product Code, Phone is not responding
Starting PM read in range 0-512...
Failed to read PM -> Phone not detected
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
BB5 Unlock Started...
MCU Version V 06wk41v57.1
MCU Date 24-04-08
Product RM-160 (Nokia N95)
Manufacturer (c) Nokia
IMEI 12345610654321?
Simlock Server SIMLOCK SERVER
Simlock Key 3340201549764300
Simlock Profile 1000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: 3F007F206F07FFFF @ FC00 Data: 334020
Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 334020
Reading Security Block...
Security block OK and saved to "RM-160_12345610654321_25082011_112301.SecurityBlock.PM"
WARNING: "1FD00113916B0052030DB945D50CC31F6829BBB0.C000262E" Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
CMT Ready!
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Using OLD BB5 FLASHING PROTOCOL
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Old Loader Detected
Readed OK, Saving to "1FD00113916B0052030DB945D50CC31F6829BBB0.C000262E"
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: NCK Calculation (new method)
#pw+857069302098651+1#
#pw+629586954562116+2#
#pw+142888321620128+3#
#pw+176291384142607+4#
#pw+833357050644625+5#
#pw+080822242994204+6#
#pw+579497054466746+7#
BB5 Unlock Failed -> Phone not detected (FBUS) What can i do????, Thanks |
