08-18-2009, 11:44 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: www.GSM10.com
Member: 720059 Status: Offline Thanks Meter: 33 | how to unlock E65-1? here is the log: Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 8E847161B3014133F90FD24059375F44004E362F APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 17400210071C5150C138D64494DF9ADA283596D0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0266638E9C2164FC6B5194ED596A6A251C699896 helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x009801A100900095, Toshiba, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND h3_sam_nand_format.fg, Type: Algorithm, Rev: 0.1.16.255, Algo: OMAP1610 FORMAT ALG Box VPP disabled Internal APE Phone VPP Enabled Failed to Create RPL from phone -> Failed to Boot / Prepare Phone Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 8E847161B3014133F90FD24059375F44004E362F APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 17400210071C5150C138D64494DF9ADA283596D0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0266638E9C2164FC6B5194ED596A6A251C699896 helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x009801A100900095, Toshiba, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND h3_sam_nand_format.fg, Type: Algorithm, Rev: 0.1.16.255, Algo: OMAP1610 FORMAT ALG Box VPP disabled Internal APE Phone VPP Enabled Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 8E847161B3014133F90FD24059375F44004E362F APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 17400210071C5150C138D64494DF9ADA283596D0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0266638E9C2164FC6B5194ED596A6A251C699896 helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x009801A100900095, Toshiba, NAND FlashContent[0,APE]: 49494949494949494949494949494949, NAND h3_sam_nand_format.fg, Type: Algorithm, Rev: 0.1.16.255, Algo: OMAP1610 FORMAT ALG Box VPP disabled Internal APE Phone VPP Enabled Failed to Read All Certificates -> Failed to Boot / Prepare Phone |
08-18-2009, 12:01 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | its supported tick skip sp read and try again also check cable and use tma if necessary sometimes i have probs with n95 but using tma and ticking skip sp read on sl1 seems to work |
08-18-2009, 21:58 | #4 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 565487 Status: Offline Sonork: 100.1590618 Thanks Meter: 35 | Quote:
FlashContent[0,APE hardware problem ... | |
08-19-2009, 05:55 | #5 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Phone if working .... FINE it should Unlock...notthing todo with APE error as much i encounter Only he need Stablization in needed mode or External Power TMA is Answer |
How to Unlock E65? | ufs3 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-09-2010 15:16 |
Is it possible to unlock E65-1 with MT Box Pro LITE? | wadalhag | MT-BOX | 9 | 12-07-2007 10:04 |
how to unlock e65 mt pro lite | nilan | MT-BOX | 7 | 09-25-2007 15:54 |
How to unlock E65 sec. code? | capri | Nokia Base Band 5 ( BB-5 ) | 4 | 08-21-2007 15:27 |
