Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-08-2009, 19:42   #1 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Local mode final solution for BB5 cables
Here the schematics of the add-on box..
It solves:
a) BSI problem (add the value of 2,7 or 5.1 to the actual resistor inside the cable)
b) Low power problem (using a standard usb charger you can give up to 1 ampere to the mobile ) important when you have not a self powered usb hub or you are using a laptop.
Valid solution as well (Using an UFC cable connecting only GND and VPP to the battery connector) to give power to the mobile during an USB flash.
Alex
The Following 39 Users Say Thank You to moulnisky For This Useful Post:
Old 05-09-2009, 01:09   #2 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
Schematics similar to the TMA Adaptor by GPG Industries....
Advantages:
-BSI has more Resistor Options (switches)
-PSU 5vDC is connected to the USB Power Cable
-7/8pin and 10 pin cables supported
Good Schematic by the way, u can add the above mentioned then u get a complete TMA Adaptor only with Low Quality Cables.
Good Luck
The Following 3 Users Say Thank You to PhoneCareCenter For This Useful Post:
Old 05-09-2009, 06:06   #3 (permalink)
moulnisky's Avatar
Member: 947561
Never seen the tma adaptor in my life :-)
As well not always the usb port has power enough, expecially using laptops, to power up mobiles like N95, 5800 or N96 and this is the reason of a lot of failures in the unlock procedure.
The scheme is free to be mofied using RJ 48 connectors instead.
Alex
The Following 3 Users Say Thank You to moulnisky For This Useful Post:
Old 05-09-2009, 06:37   #4 (permalink)
moulnisky's Avatar
Member: 947561
Had a look to the TMA adaptor..
The TMA adaptor is only increasing the value of the BSI.. nothing about the LOW power problem.. I remember now the tool and I didn't buy it just for this reason.
The LOW power problem is the biggest working on mobiles like 6300, 6500, 5800, N95 or N96 where most boxes or usb ports fail to give the proper current to the mobile in restarting it and the job goes in error.
As well those mobile are the cause of problem on the boxes stressing over limit the power regulator ic.
10 K resistor added I think is useless considering all the commercial cables, today, have at least 5.1 Kohm BSI value.. so 0, 2.7 and 5.1 are enough.
Anyway free GPG to get the IDEA and make new version of the TMA adaptor.. I think there is space enough in the actual one to add a micro rele or an electronic one and a socket for an external power supply.
There is the market for a tool like this one made in high quality standards.
Alex
The Following 8 Users Say Thank You to moulnisky For This Useful Post:
Old 05-09-2009, 09:04   #5 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
U idea is good for future TMA adaptor update for GPG...
Keep it up mate
The Following 3 Users Say Thank You to Amir-SkillZ For This Useful Post:
Old 05-09-2009, 11:40   #6 (permalink)
moulnisky's Avatar
Member: 947561
Keep it up mate
I hope if they will do it I can get one for free lol...
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 05-09-2009, 11:58   #7 (permalink)
kabirhossain's Avatar
Member: 271880
Sonork: 100.1578866
Thanks Meter: 1,289
more easy local mode or Low power problem
use 9V adaptor use VPP box ext 9v
Box is activated
Started box selftests procedure
USB Voltage 4.98v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.77v PASSED
VBAT Voltage 0.03v PASSED
VBAT Voltage 4.88v PASSED
Box VPP disabled
VPP Voltage 0.00v PASSED
Internal Box VPP Enabled
VPP Voltage 4.79v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
External Box VPP Enabled
VPP Voltage 7.88v PASSED
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
The Following User Says Thank You to kabirhossain For This Useful Post:
Old 05-09-2009, 12:06   #8 (permalink)
moulnisky's Avatar
Member: 947561
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
The VPP voltage you highlighted is only used when you flash some DCT4 to erase the flash memory (Is called boost).
When you work on bb5 mobiles the TX2 adaptor disconnect the external vpp and use the pin as TX2 (Here the name TX2 adaptor) so is unused on BB5.
As well won't sort out the problems with those cables who have the wrong BSI resistor.
I think I don't need to say this solution is for all those boxes using cables in standard Cyclone or UFS
Alex
Old 05-09-2009, 12:14   #9 (permalink)
aswancamel's Avatar
Member: 303402
Thanks Meter: 346
please, more explanation
when i use ext power 5 in cyclone jack, should i use TX2 adaptor for bb5 phone or need any more,
i hope i do not miss translate what u mean.
thanks
The Following User Says Thank You to aswancamel For This Useful Post:
Old 05-09-2009, 12:22   #10 (permalink)
Member: 91045
Thanks Meter: 8,696
U Used 5volt EXT power to Cyclone BOX?
Dont use it until u know what r u doing and what for that needed,!
Thats for boosting FLashing Speed...So while Doing work on BB5 phones Adaptor Works for TX2 Line...Thats Recommended
The Following 2 Users Say Thank You to Amir-SkillZ For This Useful Post:
Old 05-09-2009, 17:33   #11 (permalink)
Member: 996201
Thanks Meter: 315
Good drawing next time, put your name and date of 1st drawing so people will not take your idea.
GPG will make money on something so simple to build, all we get is thanks.
The Following 11 Users Say Thank You to 10xs4asking For This Useful Post:
Old 05-09-2009, 18:21   #12 (permalink)
aswancamel's Avatar
Member: 303402
Thanks Meter: 346
who will sell this modified cable for cyclone. gpg or cyclone itself.
when cyclone special power adapter for cyclonebox
Old 05-09-2009, 19:01   #13 (permalink)
moulnisky's Avatar
Member: 947561
Lol.. ******** is a good lad.. he can modify my projects.. :-)
He just didn't get why I put the rele in the schematic..
without the rele the mobile won't start when needed (the boxes cut off the VPP to the battery to restart it.. if it is always under power this won't happen) ..
About the resistors we can add all the value we like or put a trimmer 10 Kohm to be safe :-)
Guys.. the idea i put here for everybody... feel fre to use it. Actually I'm on the prototipe n.2.. giving the tool a nice case ;-)
Alex
The Following 7 Users Say Thank You to moulnisky For This Useful Post:
Old 05-09-2009, 19:34   #14 (permalink)
Member: 996201
Thanks Meter: 315
Alex
Mod-2 is the circuit one gets when the N/C relay is active.
Also since no relay is used, it is optional to connect box ground...
I have picture of proto type Mod-1 and Mod-2 will put soon...
The Following 2 Users Say Thank You to 10xs4asking For This Useful Post:
Old 05-09-2009, 20:28   #15 (permalink)
Member: 996201
Thanks Meter: 315
Looks messy but it is functional....
The Following 14 Users Say Thank You to 10xs4asking For This Useful Post:
Easy local Mode Final Solution for or UFS/JAF Cables edcentec Nokia Base Band 5 ( BB-5 ) 66 12-27-2010 10:10
Local Mode Final Solution for or UFS/JAF Cables moulnisky Nokia Base Band 5 ( BB-5 ) 80 08-09-2009 07:05
Local mode final solution for BB5 cables converter Scenarios 10xs4asking Nokia Hardware & Hardware Repair 0 05-17-2009 02:59
Local mode final solution for BB5 cables converter Scenarios 10xs4asking Nokia Base Band 5 ( BB-5 ) 0 05-17-2009 02:49
tma modification Local mode final solution omkarvitekar Nokia Base Band 5 ( BB-5 ) 1 05-16-2009 08:49
Page generated in 0.31163 seconds with 10 queries
