02-25-2013, 23:01 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Egypt Age: 41
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | Q: how to flash lumia phone? A: choose wanted firmware in WP7 tab, press flash, press and hold volume button on the phone and connect the USB cable. log Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.713 Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002E8C 2009, wk32 Initializing security card... Card Serial Number: Card Firmware Revision: Card is activated Box is activated Started box selftests procedure USB Voltage 5,07v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,05v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.817GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files (x86)\Cyclone Box\StoredFiles\Products\... Found 74 products, Filtering BB5 Products - wait... 1 Products left after filtering. Ready. Retrieving Variants for Product RM-835 - wait... 1 Variants Retrieved If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.1 Version: v256.0 Build: 1 Timestamp: 22.2.2012 11:37:26 OSBL Bootloader Ready USB&UART Tracing set [HA Auth] : Not elevating, will not flash unsigned images ESCO: Processing RM835_12w26_prod_generic_amss.esco... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031573 Signer Timestamp: 28.6.2012 8:29:48 Signer S/N: 418 Signer User ID: 10318699 Auth Level: None Data Encryption: 1 Image Index: 4 Asic Index: 0 Type: File Write Hashtable Parsed OK Sending Certificate... Certificate Accepted... [ASIC 0, Storage 4,1] Writing File "amss.mbn" (18.237MB), Partition: 0 Flushing... Flushed OK Write taken 18.705s (Average speed: 8176,51kBits/s) ESCO: Processing RM835_12260_prod_338_01_boot.esco... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98030051 Signer Timestamp: 17.7.2012 12:56:42 Signer S/N: 567 Signer User ID: 3681852672 Auth Level: None Data Encryption: 0 Image Index: 2 Asic Index: 0 Type: Image Write Hashtable Parsed OK Sending Certificate... Certificate Accepted... [ASIC 0, Storage 4,1] Writing 300.68MB @ 0x0000000028000000 Write taken 95.473s (Average speed: 26364,94kBits/s) ESCO: Processing RM835_12w26_prod_generic_user_area_erase.esco... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031568 Signer Timestamp: 28.6.2012 8:23:24 Signer S/N: 414 Signer User ID: 10318699 Auth Level: None Data Encryption: 0 Image Index: 6 Asic Index: 0 Type: Image Erase Hashtable Parsed OK Sending Certificate... Certificate Accepted... [ASIC 0, Storage 4,1] Erasing 0x000000004C000000-0x0000000795FFFFFF (29.160GB) Erase taken 0.125s Restoring Modem from BACKUP_RAMFS_IMAGE... Restore OK Restarting MCU... All ESCO Images Processed Successfully Reading info... [Složené zařízení USB]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! MCU Version 1066.0000.8779.12260 MCU Date N/A Product Lumia Series (Nokia Lumia Series) Manufacturer (c) Nokia IMEI xx Mastercode xx Public ID C71C5C41473D5E9612E60ABF372A56AE Product Code 059P349 Basic Product Code 059L3R3 Module Code 0205127 NCSd Version 1.9 HW Version 112.1569.1.0 SW Version 1066.0000.8779.12260 PSN Number 475247BAB ESN 00000000 WLAN MAC A4E731A7196C0000 BT ID A4E731A544AC0000FFFFFFFF Battery Life 52% Battery Cycle Count 65535 Battery Temperature 29.0C Battery Voltage 3849mV Battery Flags 312 Battery Standby Current -2mA Battery Max Load Current -500mA Battery Health 356 Battery Average Current 148mA Battery Remaining Capacity 688mAh Battery Full Charge Capacity 1324mAh Read info thread finished, BR |
The Following 2 Users Say Thank You to amralkareem For This Useful Post: |
