Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 07-11-2014, 10:20   #1 (permalink)
Member: 801055
Thanks Meter: 20
lumia 800 flashing fault (log)
hi.
i tried to unlock my lumia 800 and that went wrong....
now i want to flash it with newest software but i cant....
i boths up like it shuold and i can use it like normal...
i have NOT formatted the disk but it after my try to unlock it it comes with i need to format the disk when i try to flash it.
but when i try to flash it this happens :
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0002DB5
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32
Initializing security card...
Card Serial Number: DC0000F8
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4,91v PASSED
MCU Voltage 3,30v PASSED
Core Voltage 1,80v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 4,82v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 4,75v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 3.1023GB
Avaiable Virtual Memory: 1.741GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
[USB-sammensat enhed]: WinUSB Port opened OK!
[Nokia USB Connectivity]: WinUSB Port opened OK!
MCU Version 1750.0823.8852.12430
MCU Date N/A
Product Lumia Series (Nokia Lumia Series)
Manufacturer (c) Nokia
IMEI 352826051225631
Mastercode 6166564513
Public ID F2B17A9C8252D74665072923613B19EF
Product Code 059N3Z6
Basic Product Code 059K478
Module Code 0205051
NCSd Version 1.9
HW Version 112.1402.2.4
SW Version 1750.0823.8852.12430
PSN Number 0114EEBAB
ESN 00000000
WLAN MAC 3C363DC5E7020000
BT ID 3C363DC72EF6000000000000
Battery Life 43%
Battery Cycle Count 65535
Battery Temperature 33.5C
Battery Voltage 3857mV
Battery Flags 296
Battery Standby Current -8mA
Battery Max Load Current -844mA
Battery Health 842
Battery Average Current 116mA
Battery Remaining Capacity 520mAh
Battery Full Charge Capacity 1220mAh
If phone is alive, It will be automatically swithced to OSBL mode.
If software can't switch to OSBL mode, or phone is generally DEAD do folllowing:
1. Turn OFF device, wait 15 seconds afterwards
2. Eject USB cable, wait 10 seconds
3. Press and hold Volume-UP button
4. Insert USB Cable. OSBL should be booted.
Booting CMT...
Switching to RAW Mode...
BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected.
Failed to Boot CMT -> No compatible USB devices detected
Prepare phone failed with message -> Failed to Boot CMT
Process ESCO Image Failed -> Failed to Boot OSBL
Failed to Flash WP7 -> Failed to Flash All ESCO Images
Old 07-12-2014, 00:25   #2 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Thanks Meter: 693
try one more time and recharge your battery full before flashing the phone not with 43% voltage
Page generated in 0.13028 seconds with 8 queries
