Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 03-25-2013, 08:30   #1 (permalink)
Member: 644616
Sonork: 100.1608012
Thanks Meter: 257
nokia 206 rm827 flashing problem
what about nokia 206 flashing
Old 03-26-2013, 13:07   #2 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Add this line " RM-872:NOKIA 206 " at models hete[ X:\Program Files\Cyclone Box ] then check BB5 phone list at software & try to flash & post log.
BR,
Old 02-24-2014, 11:18   #3 (permalink)
Member: 1623940
Thanks Meter: 22
206 done fhash with mxkey
flash done with mxkey sucesessfully
usb pinounts .
Old 06-11-2014, 14:29   #4 (permalink)
aravindanav's Avatar
Member: 1587303
Thanks Meter: 42
Number of Image Files: 3
Processing Image File :
rm872__04.52.mcusw
rm872__04.52.ppm_mh2
rm872__04.52.image_mh2_059Q316_059R9M3_232_01
[]: Found 1 active devices.
[Nokia X2-02 USB Phonet]: Opening Connection
[Nokia X2-02 USB Phonet]: Port opened OK!
SW: V 03.59 24-12-12 RM-872 (c) Nokia
IMEI: 355902053524425
START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
FULL PM Backup Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355902053524425\USB_FULL_BACK UP_V 03.59 24-12-12 RM-872 (c) Nokia_355902053524425__64907.pm
Reading Battery Value : 4961 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 12001817A3022808
Original Product Code: 059R9M3
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355902053524425\3559020535244 25_64915.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355902053524425\3559020535244 25_CERTIFICATE_1A36E939.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355902053524425\3559020535244 25_PMM_PROT_E5B21BED.bin
Security Code: 12345
Data Sections : 04
Current File : rm872__04.52.mcusw
Compile Name: rm872__04.52.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 26480008 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: AFC6
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A66
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 94C5
Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41A7FFFE
Start Erasing...
Block Erase Done...
Data Size: 25165824 bytes
Data Checksum: 0C9F
Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm872__04.52.ppm_mh2
Compile Name: package_mh2.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 5354056 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41A80000~0x420FFFFE
Start Erasing...
Block Erase Done...
Data Size: 5350712 bytes
Data Checksum: 6B95
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : rm872__04.52.image_mh2_059Q316_059R9M3_232_01
Compile Name: rm872__04.52.image_mh2_059Q316_059R9M3_232_01.fls
Image Type : CONTENT Package
Data Size : 18877712 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42100000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 18874368 bytes
Data Checksum: 7E3F
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:07:59
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 04.52 30-06-13 RM-872 (c) Nokia
IMEI Plain : 355902053524425
IMEI Spare : A355902053524420
IMEI SV : 33559020535244211F
IMEI (2nd) : 355902053524433
IMEI Spare : A355902053524430
IMEI SV : 33559020535244311F
Phone Model: K 206
Category : Entry
Phone Type : RM-872
Extended Phone Information
Product Serial Number: 8B254B8BI
Product Code : 059R9M3
Module Code : 0205283
Basic Production Code: 059P6H2
Long Production SN : 0
PPM SW Version : V 04.52 30-06-13 RM-872 (c) Nokia MH2
BT MCM Version : 19b5-22012
MCU SW Version : V 04.52 30-06-13 RM-872 (c) Nokia
HW Version : 2300
RFIC Version : 68
LCD Version : TPO
Content Pack Version : Content: mh2_059Q316 V 04.52 30-06-13 RM-872 (c) Nokia
Bluetooth ID : A8:44:81:8A:4D:55
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC : 11
PROVIDER : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 01029704
DCC Ver: 008013
Status : OK
Selected VPL File:
RM872_059R9M3_04.52_020.vpl
Variant Details : RM-872 VAR INDIA-MH2 IN CV BLACK
Software Version : 04.52
Product Type : RM-872
Variant Version : 020
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
Old 06-13-2014, 15:35   #5 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 581
cyclone supports nokia 206.........
i have flashed 3 sets successfully with cyclone.....
buy usb fbus cable for nokia 206, then download latest flash file from google eg:mcu,ppm,image and flash...... its easy with cyclone......
Old 04-19-2016, 13:41   #6 (permalink)
Member: 2561722
Sonork: www.razamohammadjalbani.c
nokia 206 flashing slow problam use atf box
Page generated in 0.20342 seconds with 8 queries
