Nokia 5800d RM-428 in SECURITY_TEST is FAILED! [Solved] good friends .. This time I have a Nokia 5800d RM-428 with the problem of SECURITY_TEST is FAILED! I present here the log of "Read info"..... Code: MCU Version V ICPR72_08w47 searching the web tell me a PM is solved turnin 'it up ... but I miss with distindos PM and the problem persists ... I can do to solve the problem? since I've written about 3 PM and nothing ..... I can do ... thanks ... |
Just Go to "BB5 / Security" use the "Analize Security" function and FOLLOW the Instructions given by the soft. You can get te Needed PM (with 1&309 Fields) & RPL (with HWC & CCC) from here: http://ptt.4mg.com/Gsmforum/PM/ Just Download the RM-428.zip and extract the Contents to Cyclone Box\SX4 folder BR |
below the log of "Analyze Security" Code: Started Phone Security Analysis... I should do? sorry, I'm newbie to this box |
Do as indicated: Quote:
BR |
I think the solution is as follows ..... Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) but in the folder C: \ Program Files \ Cyclone Box \ SX4 is not that of my model is RM-482 ... I can do? |
ok try and comment friend ... thanks |
Download the RM-428.zip and extract the Needed files in Your SX4 folder Link in Post #2 |
here gave me the error when trying to write the PM....... Code: SX4 Authorization / SD Repair Procedure Started.... is due to this error? |
Strange :confused: that PM is from a working 5800, and the only one from an RM-428 that i have :confused: |
I recommend? |
Close the Soft, download the Zip file again, extract the contents to SX4 folder (overwrite / delete the 2 previously downloaded files, RM-428.pm & RM-428.rpl) repeat the process |
nothing the same error ....... if you do a full erase and up the software version and try again? Quote:
I dont think so.... Check this post from Alex: http://forum.gsmhosting.com/vbb/4832326-post3.html Quote:
achieved and friends solve the problem!! I explain ... the trick was to place a backup of the RPL of the cell and replace it on the. rar you sent me and copy the folder with the name SX4 RM-408 and I am super good ... and on and normal ... thank you very much for the help mates .. experience and stay there hehehehe Code: SX4 Authorization / SD Repair Procedure Started.... |
