Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 11-13-2009, 10:42   #1 (permalink)
Member: 43940
Thanks Meter: 27
nokia 6220c unlocking [SOLVED connecting charger to the phone]
trying to unlock nokia 6220c with cyclone. phone is on, not entering test mode. not being detected by cyclone box, PLEASE advise. THANKS
Old 11-13-2009, 10:56   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
If the mobile is switching on as it is under battery it means the BSI value in the cable you are using is too low.
Try using a bsi value 2-3 kohm higher
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 11-13-2009, 11:16   #3 (permalink)
Member: 43940
Thanks Meter: 27
phone now connected....how to unlock??? stuck on BOOTING RAP then fail..
Old 11-13-2009, 11:56   #4 (permalink)
moulnisky's Avatar
Member: 947561
It is a quite "heavy" mobile..
Thick in the tab BB5/flashing where says "skip repower boot" and when you click on unlock, after 10 seconds, answer yes when asked to calculate the NCK codes.
Alex
Old 11-13-2009, 12:52   #5 (permalink)
Member: 43940
Thanks Meter: 27
after 10 secs i press yes i get this....
APIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
BB5 Unlock Failed -> Loader Password not Accepted
Old 11-13-2009, 14:02   #6 (permalink)
Member: 43940
Thanks Meter: 27
HERE FULL LOG...
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 0D30010E2AB401589B2C9B755C857518951DDBB5
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_ROM_ID: 4B9B75103E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 519000BA5458BBCDC84B772B73EB89DF88AC4319
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Booting RAP...
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Old 11-13-2009, 14:04   #7 (permalink)
Member: 490127
Thanks Meter: 86
i have 2 pieces ,same thing...just conect charger then try
Old 11-13-2009, 14:19   #8 (permalink)
Member: 43940
Thanks Meter: 27
THANKS FOR REPLY, BUT STILL SAME...do we have to press any other key before pressing UNLOCK
Old 11-13-2009, 14:23   #9 (permalink)
Member: 490127
Thanks Meter: 86
i firs press backup pm, backup rpl, then unlock..
Old 11-13-2009, 14:24   #10 (permalink)
Member: 43940
Thanks Meter: 27
Do i have to flash the phone before unlocking ??? Or do i have to sx4 autorise ???
Old 11-13-2009, 14:35   #11 (permalink)
Member: 43940
Thanks Meter: 27
WHY AM GETTING THIS EVERY TIME???
Old 11-14-2009, 02:38   #12 (permalink)
Member: 274214
Thanks Meter: 4
Alex
it worked!!! Thx
This is the log before i tick the "skip repower boot" box: (problem: hang at "booting RAP....")
MCU Version V 08w16.10
MCU Date 26-06-08
Product RM-328
Manufacturer (c) Nokia
IMEI 35292202511****
Mastercode 2651611441
IMEI Spare 3A25290252117702
IMEI SV 3325290252117732F2000000
PSN CXC691943
Product Code 0567688
Module Code 0204460
Basic Product Code 0590262
PSD 0000000000000000
LPSN 0
APE SW 03.23
APE Variant 16.0103.23.210.04
APE Test rm328_ENO_x_2008wk50v0.021
APE HW 256
APE ADSP 256
RETU 16
TAHVO 22
AHNE 11
HW 1306
RFIC 17141715
DSP ICPR72_08w20
Simlock Server SIMLOCK SERVER
Simlock Key 5050300014981890
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 50503F
BB5 Unlock Started...
MCU Date 26-06-08
Product RM-328
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
BB5 Unlock Failed -> Failed to Boot / Prepare Phone
This is the winning bit (after tick the "skip repower boot")
MCU Date 26-06-08
Product RM-328
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
CMT_EM_ASIC_ID: 00000296
CMT_PUBLIC_ID: 1FE0000206DB8A5277A0EE48E4AA0870933750E1
Box VPP disabled
Restarting MCU...
Booting RAP...
#pw+051791124213078+1#
#pw+463095099206425+2#
#pw+858361579063360+3#
#pw+307059310477772+4#
#pw+913412345936006+5#
#pw+518705609562941+6#
#pw+970228190898177+7#
Sending NCK Code (Level 7)..
NCK Accepted! Phone unlocked OK!
MCU Date 26-06-08
Product RM-328
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: 50503F
Simlock NCK #pw+970228190898177+7#
Unlock finished!
Old 11-14-2009, 02:42   #13 (permalink)
Member: 274214
Thanks Meter: 4
Did the "calculate the NCK codes" window pop up and did you press "Yes"?
Old 11-14-2009, 04:53   #14 (permalink)
Member: 275590
Thanks Meter: 41
u press "YES" br...
This is my log after pressing YES
MCU Date 26-06-08
Product RM-328
IMEI 352922024850918
Mastercode 541762420
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
CMT_PUBLIC_ID: 1BB00001B67D0052BCE53DC68447A7D6D18F9BF5
Box VPP disabled
Restarting MCU...
Booting RAP...
#pw+084145736883721+1#
#pw+868956854404117+2#
#pw+041015972662410+3#
#pw+018711917831244+4#
#pw+513227652759872+5#
#pw+947024347723719+6#
#pw+863366203709373+7#
MCU Date 26-06-08
Product RM-328
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock NCK #pw+863366203709373+7#
Unlock finished!
Old 11-14-2009, 06:44   #15 (permalink)
Member: 43940
Thanks Meter: 27
yes i got the CALCULATE window, after 10 secs i press yes, it goes out n after i get the message unlock fail
nokia 6220C unlocked succsesfully telecomindia Genie Universal 0 09-11-2009 16:13
+ The Nokia N80 Internet Edition connects you to your on-line life. apocalypso Nokia Base Band 5 ( BB-5 ) 3 09-03-2006 15:03
I need help , i have COM port connection and i can't connect to the phone starmad Nokia Digital Core Technology 4 ( DCT-4 ) 3 10-01-2004 20:11
I need help , i have COM port connection and i can connect to the phone starmad Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-01-2004 17:25
How connect charger to C35 jerry77 x1x to x45/x50 2 08-17-2002 08:59
Page generated in 0.25887 seconds with 9 queries
