10-10-2013, 18:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1631147 Status: Offline Thanks Meter: 116 | nokia 6300 flash error CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1E50010C4B187B5654179B2641767412D65E66E2 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm217__06.01.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: Single Line 8Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001004100006A21, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit Processing Flash Image Failed -> Not found required Algorithm Failed to Process all Image files -> Failed to process rm217__06.01.mcusw |
