03-23-2011, 11:13 | #1 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 722598 Status: Offline Thanks Meter: 6 | Nokia 6700c CMT Error, wrong First Char Received [ Solved - Cable problem ] Could anybody answer what is wrong? Reading SL3 LOG File... MCU Version V 10.50 MCU Date 23-11-09 Product RM-470 (Nokia 6700 classic) Manufacturer (c) Nokia IMEI 355364040160*** Mastercode 4366743057 WARNING: "0D300217709C03448A149377C381B1E780F3B13F.C0003332 " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... Failed to Boot CMT -> CMT Error, wrong First Char Received Prepare phone failed with message -> Failed to Boot CMT Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) Failed to Read SL3 LOG File -> Failed to obtain Phone Unique Data |
03-24-2011, 09:30 | #2 (permalink) |
Member: 722598 Status: Offline Thanks Meter: 6 | solved Problem solved ! Changed the 8 pin cable from box to telephone with a better quality and a shorter one. TX2 pin connected to pin2 (rj45) and without the yellow cyclone adapter. Log read OK ! |
03-24-2011, 09:36 | #3 (permalink) | |
Freak Poster Join Date: Aug 2003
Member: 37362 Status: Offline Thanks Meter: 25 | Quote:
thanks for proferinng solution some of us are going through also. plz explain step by stepp how u go about this . thanks in advance. | |
03-24-2011, 09:54 | #5 (permalink) |
Member: 722598 Status: Offline Thanks Meter: 6 | Hi I not have too much time to make a tutorial with pictures but this is very simple to solve. Just replace the cable itself with a better quality. I used the red one from GPG cutted to aprox 10cm. The pin 2 from rj45 connector connect to TX2 pin of phone so you don`t have to use the adapter of the cyclonebox. The main ideea is to use tha shortes cable from box to the phone. Good luck! |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
