06-18-2009, 06:28 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | The yellow cable, proper name TX2 adaptor, is an addon you MUST use when you work with the BB5 mobiles to keep the full compatibility with the JAF/UFS cables. It connects the pin 8 of the RJ45 cable to the TX2 line of the box to use the dual line during the flash operations. Normally this pin, in the DCT4 cables, is the VPP which is used to give a speed boost during the flash operation. Normally the old boxes used to change the function of the pin depending what mobile was selected as was not provvided any VPP during the flash of the BB5 phone but Cyclone has this function hence the use of this adaptor. When will be out the cables et for Cyclone this adapter won't be used any more.. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
05-12-2012, 14:19 | #3 (permalink) | |
Junior Member Join Date: Jun 2010 Location: pakistan
Member: 1331665 Status: Offline Sonork: muhammad1982 Thanks Meter: 0 | Quote:
05-12-2012, 23:56 | #6 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | Quote:
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
how to repair ku990i yellow screen (refreshing) | 4given4gotten | FuriousGold | 1 | 03-29-2010 17:43 |
Nokia N95 cant connect using yellow cable help | coleford | Cyclonebox | 2 | 10-24-2009 18:40 |
Belkin RJ45M/RJ45M 10/100BT CAT5E 7ft Yellow Crossover Cable with Molded Gray Boot | IPMART | ipmart WebShop | 0 | 06-27-2009 11:00 |
