Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-16-2009, 11:38   #1 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Problems in Unlock 5800, N85, N96 Ver 30.0.11 and 31.0.8
NOTE : This solution is now obsolete as the new Cyclone update can unlock these mobile directly (Won't use any logs) I keep it here as can be used to unlock them, when possible, if the rpl system doesn't work and as it is still the only solution to restore the PM308 back-ups in these mobiles
Is happening always more often people opening threads for problems in unlock of rapido SL2 like the 5800 with firmware 30.0.11 or 31.0.8
This version of firmware, if we try to unlock using the NCK codes gives you error BB5 Unlock Failed -> Failed to get Lock Key (6, 5)
The only mode we have at the moment to unlock it is via downgrade.
Not all the models can be unlocked using this system!! before you start is better to check if it can be done or not: how to?
Just read the PM and make the simlock RPL using the function "create RPL frm PM": if the simlock_key_data are 3 lines, it can be done. If are 8 lines no chances.
The steps for a safe Downgrade, unlock ad re-update are simple but must be done in the exact sequence.
A) made all the back-ups (Tab Common/info "READ PM", tab BB5/Security "CREATE RPL FROM PHONE" and tab BB5/Security "READ ALL CERTS") plus a Simlock rpl using the function "create RPL from PM" and selecting the PM back-up.
B) Dowload the firmware versions you need for the job 21.0.25 for the downgrade and 30.0.11 or 31.0.8 (Depending the actual version of the mobile) for the re-upgrade and this recovery kit which must be unzipped in the common firmware folder as E71 (normally c:\Program files\Nokia\Phoenix\Products\RM-346).
C) Downgrade the mobile to the version 21.0.25 using the files related to the original product code of the mobile
D) In the tab bb5/security Thick "plain RPL" and write the Security RPL you made doing "create RPL from PM"
E) Unlock the mobile using the NCK codes (Keep a copy of the calculate codes in a side)
F) flash the mobile with the erase file 5800_Erase_256MB_kashi4gul with "Skip APE" Thicked.
G) flash the mobile as E71 v300 product code 0559569 with "skip APE" thicked ONLY COR and PPM.
the mobile now should be readable and you can see the infos with damaged imei as you are working on a RM-346; if you can't read the infos or the mobile just vibrate if you try to power it on manually flash it using the RM-356 ENO file included in the recovery package (Skip APE Thicked) and flash again the MCU E71 in the mobile (Skip APE Thicked)
H) write the full PM you have from the original back-up
I) flash it again with the 5800 firmware V30 or 31 was in origin in the mobile
J) write back the FULL RPL Back-up
if you now read the infos in the mobile the logs will be perfect with the mobile locked again as before
K) go in the tab BB5 security and click on sx4 auth.. the mobile should get the sx4 auth without any problem
L) go in the tab common/info, SX4 bypass NOT THICKED and click on write PM selecting full PM back-up you made in origin
M) go in the tab bb5/security and in the area NCK input via Fbus the unlock code calculated #pw+..+7#
Job done.. you can connect the battery back and test the mobile
Note : procedure revised to be sure the mobile is 100% without watch dog problems
Note 2 : for the N85 the procedure is the same, just after the point "E", once you got the unlocking code, go directly to the step 1 of this post : http://forum.gsmhosting.com/vbb/show...&postcount=127
Note 3 : for the N96 the procedure is the same, just after the point "E", once you got the unlocking code, go directly to the step 1 of this post : http://forum.gsmhosting.com/vbb/show...1&postcount=81
Alex
The Following 114 Users Say Thank You to moulnisky For This Useful Post:
Old 09-16-2009, 22:53   #2 (permalink)
Member: 6142
Sonork: i dont use it
Thanks Meter: 47
After this unlock producere phone will not restart after 5-10 min? Because use mt box with rapido rpl, phone always restart!
Old 09-16-2009, 23:01   #3 (permalink)
LIEREN's Avatar
Member: 917576
Sonork: QQ:366688456
Thanks Meter: 533
hi, use Cyclone box unlock phone, 100% no problem i hasbeen use Cyclone box unlock
LIEREN
The Following 2 Users Say Thank You to LIEREN For This Useful Post:
Old 09-16-2009, 23:12   #4 (permalink)
moulnisky's Avatar
Member: 947561
You will get the problem if after the downgrade and the unlock you don't update again the phone as the structure of the PM308 is different between the firmware 30. and the old versions
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 09-17-2009, 13:37   #5 (permalink)
Member: 13716
Thanks Meter: 8
Hi, I downgrade to v25, write bak rpl, and unlock.... see log:
MCU Version	V ICPR72_09w20.5
MCU Date	16-06-09
Product		RM-356
Manufacturer	(c) Nokia
IMEI		354183025283447
Mastercode	5445644022
IMEI Spare	3A45810352824304
IMEI SV		3345810352824344F3000000
PSN		CZB492346
Product Code	0559051
Basic Product Code	0578897
PSD		0000000000000000
LPSN		0
WLAN MAC	00247D390D8A
APE SW		V 30.0.011
APE Variant	V 30.0.011V 30.0.011 V 30.0.011
APE Test		eno_version
APE HW		256
APE ADSP	256
RETU		16
TAHVO		22
AHNE		11
HW		1101
RFIC		17141715
DSP		ICPR72_09w19_1
Simlock Server	SIMLOCK SERVER
Simlock Key	2140300000000000
Simlock Profile	8000000000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 21403F
Scanning avaiable products...
Processing C:\Archivos de programa\Nokia\Phoenix\Products\...
Found 61 products, Filtering BB5 Products - wait...
1 Products left after filtering. Ready.
Retrieving Variants for Product RM-356 - wait...
60 Variants Retrieved
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Simlock Store not supported, not a PA_SL2 Phone
WMDRM Store not supported
Booting RAP...
CMT_SYSTEM_ASIC_ID:	 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID:		 00000296
CMT_EM_ASIC_ID:		 00000B22
CMT_PUBLIC_ID:		 1080011815710052F573870A13F922C3A4DFA78C
CMT_ASIC_MODE_ID:	 00
CMT_ROOT_KEY_HASH:	 CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_ROM_ID:		 4B9B75103E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Backing up simlock...
MCU Date	16-06-09
Product		RM-356
Simlock backup OK, saved to RM-356_354183025283447_17092009_141954.SLBackup.PM
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing RM-356_21.0.025_prd.core.C00 (CMT)...
Booting RAP...
RM-356_21.0.025_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5
Flashbus Write baud set to 650Kbits
Box VPP disabled
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.875s
Writing all blocks...
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*ENO Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 124.828s
Restarting MCU...
Processing RM-356_21.0.025_prd.core.C00 (APE)...
Processing RM-356_21.0.025_prd.rofs2.V09 (CMT)...
Booting RAP...
RM-356_21.0.025_prd.rofs2.V09, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x06560000-0x0915FFFF, ONENAND
Erase taken 0.234s
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 44.625s
Restarting MCU...
Processing RM-356_21.0.025_prd.rofs2.V09 (APE)...
Processing RM-356_21.0.025_C01_prd.rofs3.fpsx (CMT)...
Booting RAP...
RM-356_21.0.025_C01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x09160000-0x09E5FFFF, ONENAND
Erase taken 0.78s
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 1.844s
Restarting MCU...
Processing RM-356_21.0.025_C01_prd.rofs3.fpsx (APE)...
Processing RM356_20.0.010_008_xxx_U01.uda.fpsx (CMT)...
Booting RAP...
RM356_20.0.010_008_xxx_U01.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x09E60000-0x0F71FFFF, ONENAND
Erase taken 0.468s
All blocks written OK! Time taken 7.188s
Restarting MCU...
Processing RM356_20.0.010_008_xxx_U01.uda.fpsx (APE)...
All images processed OK! Processing post flash tasks...
Reading info...
MCU Version	V ICPR72_09w06.2
MCU Date	03-03-09
Product		RM-356
IMEI SV		3345810352824344F1000000
CNT		v 20.0.010_008_xxx_U01, 21-01-09, vanilla, RM356
PSN		CZB492346
LPSN		0
APE SW		V 21.0.025
APE Variant	V 21.0.025V 21.0.025 V 21.0.025
APE HW		256
APE ADSP	256
RETU		16
TAHVO		22
AHNE		11
HW		1101
RFIC		17141715
DSP		tube_ICPR72_09w06_p1
Failed to read info -> Failed to read SP info
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Product Code...
Writing PSN...
Writing HWID...
Processing FLASHBUS Part...
Booting RAP...
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Writing PSN...
Writing HWID...
Booting RAP...
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
MCU Date	03-03-09
Product		RM-356
LPSN		0
APE SW		V 21.0.025
APE HW		256
APE ADSP	256
RETU		16
TAHVO		22
AHNE		11
HW		0559
RFIC		17141715
BB5 Unlock Started...
MCU Date	03-03-09
Product		RM-356
Warning: Failed to read SP Info, Assuming defaults
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
Box VPP disabled
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Booting RAP...
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
please help
The Following User Says Thank You to ja_palma For This Useful Post:
Old 09-17-2009, 16:52   #6 (permalink)
moulnisky's Avatar
Member: 947561
Flash it again with the V21.0.25 and retry the unlock
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 09-17-2009, 16:58   #7 (permalink)
Member: 13716
Thanks Meter: 8
I did and I get the same error before flashing: "Failed to read info -> Failed to read SP info" when read info phone, before unlocking same error: "BB5 Unlock Failed -> Failed to get Lock Key (6, 5)".... thanx in advance
Old 09-17-2009, 17:00   #8 (permalink)
Member: 13716
Thanks Meter: 8
Sorry, before= after.... bad english
Old 09-17-2009, 17:14   #9 (permalink)
moulnisky's Avatar
Member: 947561
The mobile is on retevision movil spain and looks like it has been unbranded in the past.
Can you tell me please what is the product code on the lable under the battery?
Alex
Old 09-17-2009, 17:23   #10 (permalink)
Member: 13716
Thanks Meter: 8
yes, retevision spain.... I spoke with the client and confirmed to me that has changed the product code to 0559051 for unbranded and upgrade the phone via usb with nokia updater. The original product code under the battery is 0576022. i can do? flash again with firmware v25 with product code original? thanxxx
Old 09-17-2009, 17:48   #11 (permalink)
moulnisky's Avatar
Member: 947561
Yes.. flash it again with the original product code
Alex
Old 09-17-2009, 17:53   #12 (permalink)
Member: 13716
Thanks Meter: 8
Thanx.... I have to change the product code for the original before flash? My nokia datapackage v25.0.025 does not include the product code 0576022, I downgrade it once again to a lower version of firmware which include my product code? thanx in advance
Old 09-17-2009, 17:59   #13 (permalink)
moulnisky's Avatar
Member: 947561
may be is a better solution too or you can look using navfirm for the files you need
http://rapidshare.com/files/23592893...rm-0.1-bin.zip
Alex
File list :
RM-356_21.0.025.228.02.rofs3.fpx
RM-356_21.0.025_018_xxx_U01.uda.fpsx
The Following 5 Users Say Thank You to moulnisky For This Useful Post:
Old 09-17-2009, 18:50   #14 (permalink)
Member: 13716
Thanks Meter: 8
I use navifirm to update 0576022 variant in v25 firmware, change product code to original, flash with original product code and write back rpl, now simlock is ok, unlock using the NCK codes and sinlock continue ok, I have to upgrade obligatorily again to v30.0.11? phone should work with firmware v25? My datapackage v30.0.11 does no include product code 0576022 and I don´t found it in navifirm. thanx in advance
Old 09-17-2009, 18:55   #15 (permalink)
moulnisky's Avatar
Member: 947561
Now you can change the product code and upgrade it back...
yes.. is better you upgrade it again to prevent the mobile going in watch dog as the structure of the PM308 wouldn't fit the firmware .25 and could give you problem about the superdongle.
Keep written on a piece of paper the unlock code used
Alex
Nokia 5800 XM RM-356 firmware 30 and 31.0.101 - service manual pitone02 Nokia Base Band 5 ( BB-5 ) 1 11-06-2009 23:03
Anybody unlocked N96 ver 30. without WD problem harim_1981 Genie Universal 3 10-06-2009 05:52
Anybody unlocked N96 ver 30. without WD problem harim_1981 Genie Universal 0 09-30-2009 17:08
Problems in Unlock 5800 - refuses password johnete Cyclonebox 14 09-30-2009 13:16
n96 problem in unlocking ..::Mobile Smoker::.. Genie Universal 3 03-20-2009 13:35
Page generated in 0.35347 seconds with 10 queries
