Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 03-28-2012, 13:18   #1 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
RM-495 (Nokia 5130 XpressMusic) restart after flash [ solved ]
phone was ok just no enough memory when try open music
any solution
Processing rm495__07.97.mcusw (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 12C0000D04810F560ADB84EBA8CBB35314D05742
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
rm495__07.97.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR
EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 106.469s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 51.359s
Flashing Speed: 2972,15 kBit/S
Restarting MCU...
Processing rm495__07.97.mcusw (APE)...
Processing rm495__07.97.ppm_mena_a1 (CMT)...
Booting CMT...
CMT Ready!
rm495__07.97.ppm_mena_a1, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR
Erase taken 35.266s
TurboCache Loaded!
All blocks written OK! Time taken 15.343s
Flashing Speed: 3316,14 kBit/S
Restarting MCU...
Processing rm495__07.97.ppm_mena_a1 (APE)...
Processing rm495__07.97.image_mena_a1_red (CMT)...
Booting CMT...
CMT Ready!
rm495__07.97.image_mena_a1_red, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR
EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR
Erase taken 162.578s
TurboCache Loaded!
All blocks written OK! Time taken 25.781s
Flashing Speed: 3339,07 kBit/S
Restarting MCU...
Processing rm495__07.97.image_mena_a1_red (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version V 07.97
MCU Date 13-09-10
Product RM-495 (Nokia 5130 XpressMusic)
Manufacturer (c) Nokia
IMEI 358297045476843
Mastercode 174523630
IMEI Spare 3A85920754748604
IMEI SV 3385920754748654F8000000
PPM V 07.97, 13-09-10, RM-495, (c) Nokia , MEN
CNT Content: mena_a1_bd_red, V 07.97, 13-09-10, RM-495, (c) Nokia
PSN 31CCFCAAH
Product Code 0576625
Module Code 0204024
Basic Product Code 0567773
PSD 0000000000000000
LPSN 0
RETU 16
TAHVO 22
AHNE 30
HW 1005
RFIC 06560601
DSP ICPR72_10w01
LCD SEIKO
BT 2222-302
Failed to read info -> Failed to read SP info
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Booting CMT...
CMT Ready!
Box VPP disabled
APE Boot skipped on user request
Restarting MCU...
Failed to Write PM -> No file assigned by user
MCU Version V 07.97
MCU Date 13-09-10
PSN 31CCFCAAH
Module Code 0204024
LPSN 0
RETU 16
TAHVO 22
AHNE 30
HW 1005
RFIC 06560601
DSP ICPR72_10w01
LCD SEIKO
BT 2222-302
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
[120,0] Written, Length: 944 bytes, Status: OK
[120,1] Written, Length: 160 bytes, Status: OK
[120,2] Written, Length: 130 bytes, Status: OK
[120,3] Written, Length: 112 bytes, Status: OK
[308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19
Write PM Finished, Record written OK: 4, Record written NOT OK: 1
Setting factory defaults of: Factory set full
Factory defaults set OK
Booting CMT...
CMT Ready!
Box VPP disabled
Restarting MCU...
Selftests to proceed: 29
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SLEEP_X_LOOP_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_KEYBOARD_STUCK_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_LCD_TEST
Passed ST_LPRF_IF_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_RADIO_TEST
Passed ST_BACKLIGHT_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Passed ST_BT_WAKEUP_TEST
Passed ST_HOOKINT_TEST
Passed ST_TAHVOINT_TEST
Passed ST_BTEMP_TEST
Passed ST_IIC_TEST
Passed ST_EXT_DEVICE_TEST
Passed ST_CDSP_SLEEPCLK_FREQ_TEST
Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST
Passed ST_CDSP_RF_BB_IF_TEST
Passed ST_CDSP_RF_SUPPLY_TEST
Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Passed ST_CDSP_GSM_TX_POWER_TEST
Selftests done, Tests total: 29, Tests passed: 29, Tests not passed: 0
Old 03-28-2012, 13:20   #2 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
tarted Phone Security Analysis...
MCU Version V 07.97
MCU Date 13-09-10
Reading Security Block...
Security block OK and saved to "RM-495_358297045476843_28032012_121935.SecurityBlock. PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
SECURITY SEFLTEST PASSED OK!
Step 3 : Analyzing Security Block
"12C0000D04810F560ADB84EBA8CBB35314D05742.C0001215 " Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
Old 03-28-2012, 14:29   #3 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
try with another flash files......
Old 03-28-2012, 16:11   #4 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Could you be more detailed about the "restarting"?
It restarts after the nokia logo or it restarts after it fully started?
Alex
Old 03-28-2012, 16:19   #5 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
restart with white scren
Old 03-28-2012, 19:55   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
before going into hardware repair full flash ur set . means erase flash & reflash with any version . restore all certificates . make sx4 & write pm 1,309
remember backup all important certificates including simlock data before any operation .
it seems pm of d phone become messy ! post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 03-28-2012, 20:27   #7 (permalink)
moulnisky's Avatar
Member: 947561
or could be as well a memory card problem if there is any inserted int he mobile.
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 03-28-2012, 20:28   #8 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
Problem is micro sd card thanks
Page generated in 0.56398 seconds with 9 queries
