03-01-2010, 14:37 | #1 (permalink) |
Junior Member Join Date: Jun 2008
Member: 787993 Status: Offline Thanks Meter: 3 | sir moulnisky help!!!!!!!!!!!!! Reading Security Block... Security block OK and saved to "RM-243_356255019142793_312010_90621 PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "048001193C7B0058F518AA737EFBB04F8AD7F8D4.C000 0ED6 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! thanks in advanced!!!!!!!!!! |
03-04-2010, 15:39 | #5 (permalink) | |
Member: 787993 Status: Offline Thanks Meter: 3 | Quote:
=infos= MCU Version V 06.01 MCU Date 02-09-08 Product RM-243 Manufacturer (c) Nokia IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452341F2000000 PSN MJI637045 Product Code 0548276 Basic Product Code 0539292 PSD 0000000000000000 LPSN 0 APE SW 06.01 APE Variant rofs_version_inforofx_version_info APE Test rm243_ENO_x_2007wk24v0.01 APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 0602 RFIC 17141715 DSP 06w41pb_08w28.0.1_rm243 BT 256 ADSP Sw 256 ADSP DevID 256 ADSP RevID 256 AEM 256 Flip MCUSW 256 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF =selftests= Selftests to proceed: 31 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_EXT_DEVICE_TEST Failed ST_CDSP_RF_BB_IF_TEST Failed ST_CDSP_RF_SUPPLY_TEST Failed ST_CDSP_TX_IQ_TEST Failed ST_CDSP_TXC_DATA_TEST Failed ST_CDSP_PWR_DETECTOR_BIAS_TEST Failed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_WCDMA_TX_POWER_TEST Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_RADIO_TEST Selftests done, Tests total: 31, Tests passed: 21, Tests not passed: 10 tnx in advanced..... | |
03-04-2010, 15:50 | #6 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Try to reheat a little. Br, Shadab Ahmad | |
03-04-2010, 15:52 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | The mobile is without imei.. did you use the sx4 bypass on it? in case look for a file starting as name with 048001193C7B0058F518AA737EFBB04F8AD7F8D4 and ending for NPC.CMT.crt. Write it in the mobile using write certs. BR alex |
03-04-2010, 21:45 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Near the sea... Portugal Age: 48
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | IMEI 12345610654321? Here is your problem! Follow this thread; http://forum.gsmhosting.com/vbb/showthread.php?t=747417 By the way sorry if i missguide here in this thread: http://forum.gsmhosting.com/vbb/showthread.php?t=941940 To be honest i never understood very well the credits police! |
03-04-2010, 22:17 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
Needed for only DCT4 PRL ... WBR | |
03-04-2010, 23:34 | #10 (permalink) |
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | I know bro. But as i said i never understood quiet well this matter. Any way i´m sorry for the missguide! Regards, Alex |
sir moulnisky help me,,5800 BB5 Unlock Failed -> Failed to Get Uni Key (1) [SOLVED] | rsftronics | Cyclonebox | 2 | 01-15-2010 14:35 |
moulnisky help mee | .::TR_LAZ::. | Cyclonebox | 11 | 01-13-2010 15:12 |
need moulnisky help | yasminato | Cyclonebox | 8 | 11-08-2009 11:08 |
mr moulnisky help | ferdie1969 | Cyclonebox | 1 | 10-09-2009 09:04 |
@latigido sir please help myc-2-2 is not det | cellworld | SAGEM JTAG UNLOCKER | 3 | 02-10-2006 08:21 |
