05-10-2012, 17:44 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: jamaica
Member: 852991 Status: Offline Thanks Meter: 19 | c1-01 |
The Following User Says Thank You to thee011 For This Useful Post: |
05-11-2012, 07:05 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | without logs is hard to help you: please post the logs. Note: for the mobile with the user code move in this way: tab common/connection: select usb a) switch the mobile off (better if you remove the battery) b) go in the tab bb5/flash and click on " check flashing bus" c) connect the mobile to the USB cable and press shortly power on on the mobile: the mobile will be in local mode at the end of the check d) go in the tab bb5/user area and click on read BR Alex |
05-12-2012, 01:09 | #3 (permalink) |
Member: 852991 Status: Offline Thanks Meter: 19 | Initializing FBUS... All initialized - Ready to work Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT there the log when i press check flash bus |
05-12-2012, 17:34 | #9 (permalink) |
Member: 852991 Status: Offline Thanks Meter: 19 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.01, (Apr 29 2012 16:16:15, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0003979 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 Initializing security card... Card Serial Number: DE0000FF Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.99v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.99v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.160GB Avaiable Virtual Memory: 1.494GB Avaiable Pagefile: 3.196GB Initializing FBUS... All initialized - Ready to work Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT there the log again |
Sony CMD-C1 interface | janosik99 | Hardware Equipments for GSM | 3 | 12-20-2001 11:09 |
sony C1 | S-max | Various | 0 | 07-16-1999 18:39 |
Sony c1 | Saulius | Various | 0 | 07-03-1999 12:52 |
Any kind of info on Sony CMD C1?? | vmarquesa | Various | 0 | 06-16-1999 12:04 |
Sony C1 unlocking method wanted | Janos | Various | 0 | 06-08-1999 03:33 |
