Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > JAF No Tp Unlocker by Cinek
Old 04-09-2009, 19:22   #1 (permalink)
Member: 974079
Thanks Meter: 6
Box can not be connected to unlock bb5 help!
Dear all,
I have an issue here. I connected the jaf box and usb dongle, turn on the jaf software, set in bb5 mode. Then I turned on cinek. It detected my usb dongle, but it keeps saying no jaf box found and no ufx box found. What should I do? I bought all the bb5 phones cable but I can't use any to unlock any phones. Some cables have a cord comes out that allow me to plug in a battery. What should I do? Please help.
Old 04-10-2009, 02:50   #2 (permalink)
Member: 974079
Thanks Meter: 6
anyone can solve my problem?
Old 04-10-2009, 17:38   #3 (permalink)
beerfoote1's Avatar
Member: 220143
Thanks Meter: 108
Ok I will attempt to try and help. 1st you have to ensure that the box is connected because the JAF software will open even if the box is not properly installed. It only needs the PKEY to open (the usb dongle). So update box drivers . Once your computer recognise the box and you open JAF software you should see in the message section of JAF thet your box is conected. You should now be able to connect to BB5Plus software.
PM me if you need further help.
WELCOME TO GSMFORUM
Old 04-10-2009, 18:36   #4 (permalink)
Member: 974079
Thanks Meter: 6
Thank you so much. I will try it out. So I only need to connect jaf box but not the vspec box right?
Old 04-10-2009, 20:06   #5 (permalink)
beerfoote1's Avatar
Member: 220143
Thanks Meter: 108
Connect Vspec only if you gonna do unlock with testpoint.
Old 04-13-2009, 22:52   #6 (permalink)
Member: 974079
Thanks Meter: 6
thank you beerfoote1. All is fine now and cinek can detect the jaf box. But when I try to unlock nokia 5200 rm-174 it comes with the following message. I am using a fbus cable which has an extended cable allowing me to plug in a dry cell battery. Don't know if it is the cable problem. Thanks for your help again.
JAF box ATmega firmware version: 1B1
Searching for phone ...
ERROR: Cannot detect phone on FBUS interface
Operation time: 00:12.
Done with error(s).
Thread phone exit.
Old 04-14-2009, 19:59   #7 (permalink)
waseemshahzad's Avatar
Member: 482296
Thanks Meter: 43
Do not use any battery 9v or whatever it was just plug the fbus cable and change the the jaf usb cable and also ur pc port ur pc shuold have 4..6 usb ports if u instal himachi software and drivers first uninstal it and try to use only one device at one time
ATF Please update the error can not be used to help shen690 Advance-Box 12 03-22-2010 14:28
KF311 can not be connected aswancamel VygisToolbox 6 10-10-2009 11:56
Can it be possible to flash BB5 phones through UFS-5 BOX?? chhoton UFS2 + UFS3-Tornadoflasher 0 11-07-2008 07:49
can c168i be connected/flashed/unlocked? yurais Infinity-Box 17 10-24-2008 20:09
9210 can not be connected tp PC anymore jurjen1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-11-2002 17:22
Page generated in 0.15804 seconds with 9 queries
