Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > JAF No Tp Unlocker by Cinek
Old 06-18-2009, 23:34   #1 (permalink)
Member: 129719
n75 not working after unlock
Hello i unlocked N75 now pm is bad. I resent the correct locked pm but the phone is still showing config key and provider key as 00000000000000000. Any way to repair this without buying rpl. Thanks.
6/18/2009 3:39:08 PM JAF box ATmega firmware version: 1B1
6/18/2009 3:39:18 PM Searching for phone ...
6/18/2009 3:39:18 PM Phone found on FBUS interface
6/18/2009 3:39:18 PM Reading phone info ...
6/18/2009 3:39:18 PM Type: RM-128
6/18/2009 3:39:18 PM Version: V_06wk15v45.1_17-10-07_RM-128_(c)_Nokia.
6/18/2009 3:39:18 PM IMEI: 35xxxxxxxxxxxxxxxxxxx
6/18/2009 3:39:18 PM SP LOCK status:
6/18/2009 3:39:18 PM Provider Key: 3101700000000000
6/18/2009 3:39:18 PM Block 1: CLOSED Type 5 Data: 310150
6/18/2009 3:39:18 PM Block 2: CLOSED Type 5 Data: 310150
6/18/2009 3:39:18 PM Block 3: CLOSED Type 5 Data: 310170
6/18/2009 3:39:18 PM Block 4: CLOSED Type 5 Data: 310170
6/18/2009 3:39:18 PM Block 5: CLOSED Type 5 Data: 310410
6/18/2009 3:39:18 PM Block 6: CLOSED Type 5 Data: 310410
6/18/2009 3:39:18 PM Block 7: CLOSED Type 5 Data: 311180
6/18/2009 3:39:18 PM Block 8: CLOSED Type 5 Data: 311180
6/18/2009 3:39:18 PM Key counter: 0/3
6/18/2009 3:39:18 PM Cable counter: 0/10
6/18/2009 3:39:18 PM Read Phone Info OK
6/18/2009 3:39:18 PM Operation time: 00:12.
6/18/2009 3:39:18 PM Successfully done.
6/18/2009 3:39:23 PM JAF box ATmega firmware version: 1B1
6/18/2009 3:39:33 PM Searching for phone ...
6/18/2009 3:39:33 PM Phone found on FBUS interface
6/18/2009 3:39:33 PM Reading phone info ...
6/18/2009 3:39:33 PM Type: RM-128
6/18/2009 3:39:33 PM Version: V_06wk15v45.1_17-10-07_RM-128_(c)_Nokia.
6/18/2009 3:39:33 PM IMEI: 35xxxxxxxxxxxxxxxxxx
6/18/2009 3:39:33 PM SP LOCK status:
6/18/2009 3:39:33 PM Provider Key: 3101700000000000
6/18/2009 3:39:33 PM Block 1: CLOSED Type 5 Data: 310150
6/18/2009 3:39:33 PM Block 2: CLOSED Type 5 Data: 310150
6/18/2009 3:39:33 PM Block 3: CLOSED Type 5 Data: 310170
6/18/2009 3:39:33 PM Block 4: CLOSED Type 5 Data: 310170
6/18/2009 3:39:33 PM Block 5: CLOSED Type 5 Data: 310410
6/18/2009 3:39:33 PM Block 6: CLOSED Type 5 Data: 310410
6/18/2009 3:39:33 PM Block 7: CLOSED Type 5 Data: 311180
6/18/2009 3:39:33 PM Block 8: CLOSED Type 5 Data: 311180
6/18/2009 3:39:33 PM Key counter: 0/3
6/18/2009 3:39:33 PM Cable counter: 0/10
6/18/2009 3:39:33 PM Read Phone Info OK
6/18/2009 3:39:34 PM Reading PM Field 308 Subfield 1 with length 8192 bytes
6/18/2009 3:39:35 PM Saving to file: RM-128_354xxxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0_ _V_06wk15v45.1_17-10-07_RM-128_(c)_Nokia.__18_06_2009__15_39_35.bin
6/18/2009 3:39:36 PM PM308 backup OK
6/18/2009 3:39:36 PM Searching for JAF box ...
6/18/2009 3:39:36 PM JAF box detected
6/18/2009 3:39:37 PM JAF box ATmega firmware version: 1B1
6/18/2009 3:39:37 PM Initialize JAF box ...
6/18/2009 3:39:37 PM JAF box JAFBOX_BB5_FLASH_bb5challenge ...
6/18/2009 3:39:38 PM
6/18/2009 3:39:38 PM ASIC ID: 000000010000022600010006010C192101003000
6/18/2009 3:39:38 PM HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
6/18/2009 3:39:38 PM ROM ID: 273F6D55DFAAF68F
6/18/2009 3:39:38 PM JAF BB5+ no TP v1.02
6/18/2009 3:39:38 PM Sending loader...
6/18/2009 3:39:38 PM Rap3Gv3 selected.
6/18/2009 3:39:38 PM BB5_FLASH_CMTbootload
6/18/2009 3:39:38 PM JAF CMT Boot Ready
6/18/2009 3:39:39 PM Hello ok
6/18/2009 3:39:39 PM start
6/18/2009 3:39:39 PM JAF BB5Plus No TP by [c]Cinek started.
6/18/2009 3:39:39 PM ok
6/18/2009 3:39:40 PM Connecting to server
6/18/2009 3:39:51 PM Credits: 20
6/18/2009 3:39:54 PM Data recived.
6/18/2009 3:39:54 PM Hello ok
6/18/2009 3:39:55 PM PM send.
6/18/2009 3:39:55 PM PM - [OK]
6/18/2009 3:39:55 PM After unlock.
6/18/2009 3:39:57 PM JAF box ATmega firmware version: 1B1
6/18/2009 3:40:07 PM Searching for phone ...
6/18/2009 3:40:07 PM Phone found on FBUS interface
6/18/2009 3:40:07 PM Writting PM Field 308 Subfield 1 with length 8192 bytes
6/18/2009 3:40:20 PM 0x10010403
6/18/2009 3:40:20 PM 0x12210001
6/18/2009 3:40:20 PM 0x13040120
6/18/2009 3:40:20 PM Operation time: 00:58.
6/18/2009 3:40:20 PM Done with error(s).
Old 06-19-2009, 23:06   #2 (permalink)
Lavarow's Avatar
Member: 922305
Sonork: 100.1580089
Hi,
Use JAF, click INFO and paste log.
B.R
Lavarow
Old 06-19-2009, 23:38   #3 (permalink)
Member: 129719
Hello I have original backup for this phone , but I read with bb5+ unlocker. When I write this locked bkup with normal jaf no testpoint I get config and provider key 0000000000000000 etc. I do self test with Jaf it changes to
CONFIG KEY: FFFFFFFFFFFFFFFF
PROVIDER KEY: FFFFFFFFFFFFFFFF
Nezt i open Jaf no testpoint unlocker and repair sl area and it changes provider key to at^t again and its unlocked. However I still get contact retailer message at startup. Any sugetsions?
Old 06-20-2009, 02:29   #4 (permalink)
xerraco's Avatar
Member: 890926
Restore again the 1st Backup & use Repair button instead.
Old 06-20-2009, 12:45   #5 (permalink)
renegade's Avatar
Member: 426389
This is only your fault, you have used wrong sw JAF BB5+ no TP v1.02
N75 is old bb5 and should be used with JAF Nokia BB5 Unlocker v1.04
In sticky thread i wrote which models works with which sw :
Phones supported by JAF_Nokia_BB5_&_BB5+_Unlocker
I also warned about saving full pm (0-400) before any attempt to unlock so you can restore the phone in its previous state (locked and working) if something goes wrong...
Now what you can do:
-use Jaf no tp 1.04 and restore the backup (the one made with Jaf bb5+ 1.02)
-if restoring the backup doesn't solve the problem, try SL repair with v1.04 and post here all logs (also info readed with JAF main sw)
Old 06-20-2009, 15:34   #6 (permalink)
Member: 129719
tnx 4 your answer . I will try
Old 06-20-2009, 17:05   #7 (permalink)
Member: 129719
Hello I tried rewriting locked pm and repairing sl but get this error message after repairing is finished>
Error. 0x13040023
I would appreciate further assistance tnx
Old 06-20-2009, 20:46   #8 (permalink)
soshan's Avatar
Member: 592636
writting pm with jaf box
in this time u should try to read rpl backup then wriiting blank rpl so then checking imei if imei is 12345 very easy to wite 308 then witting rpl and cheching info
Old 06-26-2009, 17:47   #9 (permalink)
Member: 129719
Hello I tried writing blanlk rpl imei changed to 123......, however I need a good pm. I have searched, even downloaded modified pm but still doesnt remove "startup failed". Help me with link.
Old 06-29-2009, 01:52   #10 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
if sl zone ok and imei ok and still contact retailer, try write PM 1, 139 with SX4
This should arrange problem
BR,
A65 & MCT62 4 keys not working after unlock - we pay for help info codec_romania Siemens Hardware Repair Area 14 06-26-2009 14:17
U6 power button not working after unlock tong83 Smart-Clip 4 04-05-2006 20:46
a65 key not work after unlock NuengEve Siemens Hardware Repair Area 1 04-24-2005 11:57
Please Help!!!! data suite not working after unlock C60 cyberdemonzz Siemens-Benq RingTones and WallPapers 2 07-01-2004 13:56
3330 not working after unlock snoopsterg Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 08-12-2002 20:24
Page generated in 1.33544 seconds with 11 queries
