Old 01-21-2011, 17:57   #1 (permalink)
Monty's Avatar
Member: 12835
Thanks Meter: 23
2730 Flashing error (ANSWERED)
Hello all!!
What could be wrong, when I try flashign Nokia 2730 and it's something like this?? Before flashing cell phone was good, now will not start.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010)
Processing MCU file: rm578__10.45.mcusw
 [BB5,BB5 ALGORITHM]  size: 21.65 MB
 Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101023000
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0E2001102BEA0056C66408986D090E86EE4D5D66
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 1.30.0 revision: 0.0 size: 0x3C00
 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM]  version: 1.31.0 revision: 0.0 size: 0x297E0
 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 23.25 MB
CMT NOR area [00000000-000006BF] erased in 0.797 s
CMT NOR area [000006C0-0001FFFF] erased in 0.172 s
CMT NOR area [00040000-000BFFFF] erased in 3.125 s
CMT NOR area [000C0000-0013FFFF] erased in 0.218 s
CMT NOR area [00140000-0155FFFF] erased in 1 min 31.109 s
CMT NOR area [01560000-0175FFFF] erased in 12.282 s
Flash programming ...
CMT PAPUBKEYS: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 (RAP Certificate 215 v1) written.
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00F60400, Result: 0010
Flashing terminated with error(s) in 4 min 34.781 s
RX Buffer: C7012D0103CD000010000000F172
Old 01-21-2011, 18:30   #2 (permalink)
NeeMan's Avatar
Member: 767786
Thanks Meter: 320
use working fbus cable or try usb flashing (if phone has usb port)
Old 01-21-2011, 21:13   #3 (permalink)
Monty's Avatar
Member: 12835
Thanks Meter: 23
it is working fbus cable :-)
Old 01-21-2011, 23:21   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
it just the matter with flash loader. switch it from config menu.
Old 01-22-2011, 10:09   #5 (permalink)
Monty's Avatar
Member: 12835
Thanks Meter: 23
Now the phone is flashed properly DeadUSB mode. But there is only the Nokia logo and then the only white screen and nothing more. What can still be done to restore it to life?
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3AA74EEC
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101023000
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 0E2001102BEA0056C66408986D090E86EE4D5D66
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 2333F7FF
Verifying communication to device OK.
CMT NOR area [00000000-000006BF] erased in 0.719 s
CMT NOR area [000006C0-0001FFFF] erased in 0.734 s
CMT NOR area [00040000-000BFFFF] erased in 4.593 s
CMT NOR area [000C0000-0013FFFF] erased in 2.828 s
CMT NOR area [00140000-0155FFFF] erased in 2 min 9.734 s
CMT NOR area [01560000-0175FFFF] erased in 13.140 s
Programming completed in 1 min 23.734 s
Processing PPM file: rm578__10.45.ppm_ea
 [BB5,BB5 ALGORITHM]  size: 5.24 MB
Erase size: 8.62 MB
CMT NOR area [01760000-01FFFFFF] erased in 51.812 s
Programming completed in 19.859 s
Processing CNT file: rm578__10.45.image_ea_black
 [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
Erase size: 31.75 MB
CMT NOR area [02000000-0245FFFF] erased in 27.672 s
CMT NOR area [02460000-03FBFFFF] erased in 2 min 46.187 s
Programming completed in 50.469 s
Total time for flashing process(boot+erase+write) was 9 min 43.328 s
Timeout, no usb device found.
Flashing completed in 10 min 36.391 s
Phone not responding !
Market items is empty, please select the correct products path !
I Have only MX-KEY and UFS+HWK for nokia Phones
Old 01-22-2011, 12:57   #6 (permalink)
Member: 1166085
Sonork: 234567
Erase size: 8.62 MB
use 3.5 ver 1.7 its set up problem
Last edited by tauheed24; 01-22-2011 at 12:58. Reason: use 3.4ver1.7 its set up problem brother ye mere sath bhi eesa ho raha tha
Old 01-22-2011, 18:56   #7 (permalink)
Monty's Avatar
Member: 12835
Thanks Meter: 23
1.71 and 1.72 are OK ??
...i'll try and post results.
Old 01-22-2011, 19:30   #8 (permalink)
GsmXplorer's Avatar
Member: 363308
Thanks Meter: 79
Originally Posted by gbluez View Post
hi,
CMT NOR area [00000000-000006BF] erased in 0.062 s
CMT NOR area [000006C0-0001FFFF] erased in 0.093 s
CMT NOR area [00020000-0007FFFF] erased in 0.141 s
CMT NOR area [00080000-000DFFFF] erased in 0.157 s
CMT NOR area [00100000-001FFFFF] erased in 0.282 s
CMT NOR area [00200000-0031FFFF] erased in 0.313 s
CMT NOR area [00320000-0105FFFF] erased in 3.094 s
CMT NOR area [01060000-01067FFF] erased in 0.062 s
CMT NOR area [01068000-0107FFFF] erased in 0.078 s
Error chk C7012D0103CD000090000000F1
Error while programming [00] at 0x00000400, Result: 0090
RX Buffer: C7012D0103CD000090000000F172
Still same can u show steps here
Regards
Old 01-22-2011, 21:45   #9 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
hi,
hii..mbulz,
I have been attempting to use the auto select loader but just the same, what is wrong with version 1.8, I think version 1.8 many bugs that should fix is not perfect in its previous version 1.7
sorry please permit would pee used
Old 01-23-2011, 13:25   #10 (permalink)
Monty's Avatar
Member: 12835
Thanks Meter: 23
with version 1.70 still whote screen after flashing (deadUSB mode) (with force 128k CNT checked, and without).
...in Monday I have to give cell phone to his owner. What else can I try to do to cell phone work?
Old 01-24-2011, 10:13   #11 (permalink)
Monty's Avatar
Member: 12835
Thanks Meter: 23
After long efforts, the mobile phone back to life.
I'll explain how I managed to fix it. Maybe someone need it. Everything has been repaired by DeadUSB mode and Phoenix_2009_20.
I got the phone in which I had to change the language. Originally it was a RM-578 v 7.75, 3-UK (Product Code: 0591475). In this version of the software no language that interested me. I was flash latest firmware (v10.40) and then problems has started. I tried different options but ultimately went back to the original version of the software and the phone is launched. Finally, when I fixed the phone, i've used the MX-KEY to flash PPM only with the appropriate language pack, version 7.70.
If someone else has a similar problem, try to go back to what was at the very beginning In my case it ended a 100% success.
At the end LOG form a successful recovered phone by Phoenix_2009_10:
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
--- Press phone's power button! ---
Loading secondary boot code: 14592 bytes
Secondary boot loaded
Loading update server code: 308032 bytes
Update server loaded
Asic CMT: Verifying communication to device...
Asic CMT: Start programming 46340 KB...
Asic CMT: Erasing rm578__07.75.mcusw
Asic CMT: Erasing area 1...
Asic CMT: Erasing area 2...
Asic CMT: Erasing area 3...
Asic CMT: Erasing area 4...
Asic CMT: Erasing area 5...
Asic CMT: Erasing area 6...
Asic CMT: Erasing rm578__07.75.ppm_ae
Asic CMT: Erasing rm578__07.75_ISM_006.image_ae_uk_black_3_uk_black_v3
Asic CMT: Programming rm578__07.75.mcusw
Asic CMT: Programming  0%
Asic CMT: Programming  2%
Asic CMT: Programming  4%
Asic CMT: Programming  6%
Asic CMT: Programming  8%
Asic CMT: Programming  10%
Asic CMT: Programming  12%
Asic CMT: Programming  14%
Asic CMT: Programming  16%
Asic CMT: Programming  18%
Asic CMT: Programming  20%
Asic CMT: Programming  22%
Asic CMT: Programming  24%
Asic CMT: Programming  26%
Asic CMT: Programming  28%
Asic CMT: Programming  30%
Asic CMT: Programming  32%
Asic CMT: Programming  34%
Asic CMT: Programming  36%
Asic CMT: Programming  38%
Asic CMT: Programming  40%
Asic CMT: Programming  42%
Asic CMT: Programming  44%
Asic CMT: Programming  46%
Asic CMT: Programming rm578__07.75.ppm_ae
Asic CMT: Programming  48%
Asic CMT: Programming  50%
Asic CMT: Programming  52%
Asic CMT: Programming  54%
Asic CMT: Programming  56%
Asic CMT: Programming  58%
Asic CMT: Programming  60%
Asic CMT: Programming rm578__07.75_ISM_006.image_ae_uk_black_3_uk_black_v3
Asic CMT: Programming  62%
Asic CMT: Programming  64%
Asic CMT: Programming  66%
Asic CMT: Programming  68%
Asic CMT: Programming  70%
Asic CMT: Programming  72%
Asic CMT: Programming  74%
Asic CMT: Programming  76%
Asic CMT: Programming  78%
Asic CMT: Programming  80%
Asic CMT: Programming  82%
Asic CMT: Programming  84%
Asic CMT: Programming  86%
Asic CMT: Programming  88%
Asic CMT: Programming  90%
Asic CMT: Programming  92%
Asic CMT: Programming  94%
Asic CMT: Programming  96%
Asic CMT: Programming  98%
Waiting for communication response: 25
Waiting for communication response: 24
USB Flashing succeeded.
Phone flashing completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Communication verified
Product code changed
Doing factorysets
Factorysets complete
Reading Dynamic Camera Configuration ID 1
Updating configuration of camera with ID 1
Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NI00IIIIRR030102F201 was found.
Loading default data to phone
Getting Data Package
Reading product state
Starting backup/restore sub-procedure: data item pre-delay
data item pre-delay
data item pre-delay
Sub-procedure completed: Succeeded., result code: 0
Starting to backup/restore data item: Contacts, version: S40_FILE2
Data Item backup/restore completed: Succeeded., result code: 0
Starting backup/restore sub-procedure: data item post-delay
data item pre-delay
data item pre-delay
Starting to backup/restore data item: ProductProfile, version: 1.1
data item pre-delay
data item pre-delay
Starting to backup/restore data item: Certificates, version: 1.0
data item pre-delay
data item pre-delay
Starting to backup/restore data item: ISSVariantActivator, version: 1.0
Backup/restore result: 0 out of 4 items were not backed up
Default data loading complete
Stopping all operations, returning phone to default mode
All operations completed
Product flashing succeeded.
...and LOG from the change in the language pack from the older software (MX-KEY v1.7.0)
Processing MCU file: rm578__07.75.mcusw
 [BB5,BB5 ALGORITHM]  size: 21.60 MB
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1814D62C
Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: A17F3F
Skipped by user request.
Processing PPM file: rm578__07.70.ppm_bor
 [BB5,BB5 ALGORITHM]  size: 6.86 MB
Erase size: 8.62 MB
CMT NOR area [01760000-01FFFFFF] erased in 56.906 s
Programming completed in 23.328 s
Processing CNT file: rm578__07.75_ISM_006.image_ae_uk_black_3_uk_black_v3
 [BB5,BB5 ALGORITHM] page size: 128 K size: 18.02 MB
CMT NOR area [02000000-0245FFFF] erased in 28.610 s
CMT NOR area [02460000-03FBFFFF] erased in 3 min 2.110 s
Programming completed in 1 min 0.359 s
Total time for flashing process(boot+erase+write) was 6 min 0.485 s
Device found: nmwcdc\Nokia 2730 classic USB Generic, ID: 4E4DBA0
Flashing completed in 6 min 37.672 s
Phone Type: RM-578 (Nokia 2730 classic)
SW Version: V 07.75 05-07-10 RM-578 (c) Nokia
Imei plain: **************-*
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: ***************
Version: SIMLOCK SERVER
Provider: Hutchison 3G UK Ltd. , Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 8000000000000000
BLOCK 1:   1=OPEN, DATA=23420F
BLOCK 2:   1=OPEN, DATA=23594F
Thank you for your help and best regards
Monty
The Following User Says Thank You to Monty For This Useful Post:
Old 01-24-2011, 10:24   #12 (permalink)
sunny box's Avatar
Member: 1456392
Sonork: 100.1606104
Thanks Meter: 115
tyr ro usb flashing....
Old 01-25-2011, 23:07   #13 (permalink)
Member: 97044
Thanks Meter: 41
Try to use fbus cable from 2690!
Old 01-26-2011, 11:12   #14 (permalink)
Monty's Avatar
Member: 12835
Thanks Meter: 23
Read my last post. You'll know it, that problem has been corrected and additional information about how I did it.
Old 01-26-2011, 11:56   #15 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
bro u should be ching cable
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.31094 seconds with 9 queries
