Old 03-12-2010, 10:18   #1 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
Question 3110 security test failed ?
hi mxkey team i have 3110 showing contact service
its security test failed
here info
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
self test info
Phone Type: RM-237
SW version: V 07.21 05-11-08 RM-237 (c) Nokia.
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
15 SLEEP_X_LOOP Y passed
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N passed
20 BACKUP_BATT N passed
21 LPRF_IF N !not ready
44 LPRF_AUDIO_LINES N !not ready
2 CURRENT_CONS N !not ready
42 RADIO Y !not ready
69 BACKLIGHT Y !not ready
33 SIM_LOCK N !not ready
93 SECURITY N !not ready
71 BT_WAKEUP N !not ready
99 IRDA_LED_STRESS N !not ready
96 HOOKINT N !not ready
88 TAHVOINT Y !not ready
56 SLEEPCLK_FREQ N !not ready
101 BTEMP N !not ready
107 BT_SLEEP_CLK N !NOT EXECUTED(03)
108 EXT_DEVICE N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
85 CDSP_TX_IQ N !NOT EXECUTED(03)
74 CDSP_TXC_DATA N !NOT EXECUTED(03)
79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03)
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
Old 03-12-2010, 10:22   #2 (permalink)
Member: 757799
Thanks Meter: 782
do this
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309
Old 03-12-2010, 10:24   #3 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
Use sx4 & write modifyed pm
Old 03-12-2010, 11:11   #4 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
what does the sx4 means or where is its use option ?
Old 03-12-2010, 11:16   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
SUPER SD Auth
+ Write PM1,309
br,
The Following 3 Users Say Thank You to Andra For This Useful Post:
Old 03-12-2010, 11:22   #6 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
Originally Posted by trio1 View Post
do this
boss
i wrote full modified pm
then repair simlock ticked make simlock rpl
then repair SD
then did super SD Auth
wrote pm1 and pm309
but phone is same condition
here bus info
SIMLOCK_TEST passed
Old 03-12-2010, 12:44   #7 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
hello mxkey help me plz
Old 03-12-2010, 12:58   #8 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
Originally Posted by GSMBALOCH View Post
boss
then repair SD
wrote pm1 and pm309
here bus info
SIMLOCK_TEST passed
post you log as i say---------go---
service>phone test>various>bb5 certificate validation
than we could see your hwc & ccc data condition
Old 03-12-2010, 16:16   #9 (permalink)
Member: 267985
what about its imei condition
Old 03-12-2010, 16:41   #10 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
detailed info here about this error
Click here --> http://forum.gsmhosting.com/vbb/f550...l-here-945700/
Originally Posted by hasnain View Post
.::Solution for::. Security Test Fail .: HERE :.
SIMLOCK valid
WMDRM_PD seems to be valid
how to solve this problem ?
1.
First of all u need good pm with SX4
( do SX4/super SX4 after that pm1 and pm309 )
2.
if not solved than
check CCC and HWC certificates
How to repair CCC and HWC certificates ?
backup RPL than open it in notepad
there u will see NPC data after that CCC data and HWC data
just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model )
RapidShare: 1-CLICK Web hosting - Easy Filehosting
RPL_collection_V1__without_NPC_DATA__made_by_MxKey .zip
4shared.com - online file sharing and storage - download RPL_collection_V1__without_NPC_DATA__made_by_MxKey .zip
MEGAUPLOAD - The leading online storage and file delivery service
3.
if still not solved than
recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON )
4.
if still same than
Repair SL
REPAIR SD
SUPER SD AUTH
write PM1 and PM309
5.
if still same than
make RPL backup
full erase
than flash
than rpl
than Repair SL
than SD repair
than super AUTH
than PM
6.
after all these steps if still same than i am here for don't worry
__________________________________________________ ____________
FOR SL3 LIKE 5130 , 6700c ,.................
1.
SIMLOCK invalid
Block1 : open
Block 2 pen
Block 3 : open
in this case just do SX4 and than pm1 and pm309
2.
SIMLOCK invalid
SL data corrupted
in this case u need Nokia RPL ( not supported by MXkey yet )
__________________________________________________ _______________________
PM FILES OF BB5 : just download them from this link and enjoy
Old 03-12-2010, 18:15   #11 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
bro , pls do it step by step
1_mxkey>serves>imei&securty>imei rebuild>repair sd
2_go to pm >click sd auth writ pm 1 and 309 and wait 2 mnt
3_full factory
Old 03-13-2010, 07:33   #12 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
bb5 certificate validation info sir
NK module version: 1.08
NK applet version: 00.20
NK module ready.
Please "Scan" or "BUS check" before any operation ...
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1A90000EEDA87C5670080F305931439D4D02082C
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Reading RAP NPC (0x168 bytes)
Original Product Code: 0544325
Reading RAP VARIANT (0x0 bytes)
Reading RAP CCC (0x160 bytes)
CCC seems to be valid
Reading RAP HWC (0xD4 bytes)
HWC seems to be valid
Old 03-13-2010, 08:44   #13 (permalink)
Member: 300547
Thanks Meter: 23
WITH MX-KEY: IMEI&Security>imei rebuild>repair sd. then
PM>Super SD Auth>PM Auth>Load from file>write, BUT BE CAREFULL IMEI SHOULD BE WITHOUT 120,308.PM
Old 03-13-2010, 08:54   #14 (permalink)
pinkyelectronic's Avatar
Member: 1173492
Thanks Meter: 27
1.Service > Imei & Security > Imei Rebuild > Repair SD
2.Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
3.Service > PM >super SD auth is done, write PM imediately.
Old 03-13-2010, 09:34   #15 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
Thanks Meter: 129
just replace CCC and HWC data with clone RPL's ( of same model )
5300 and 3110 security test failed kamal07 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 05-12-2010 08:55
3110 security test failed SAN INFOTECH MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 03-24-2010 14:55
3110-security test failed!!! Riteshgpt60 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-27-2010 19:25
3110 security test failed.. help pls appu2009 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-19-2010 11:03
security test failed 3110 c help gopalhot MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-04-2010 14:12
Page generated in 0.35533 seconds with 9 queries
