03-08-2010, 09:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | .::Solution for::. Security Test Fail .: HERE :. SIMLOCK valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! how to solve this problem ? 1. First of all u need good pm with SX4 ( do SX4/super SX4 after that pm1 and pm309 ) 2. if not solved than check CCC and HWC certificates How to repair CCC and HWC certificates ? backup RPL than open it in notepad there u will see NPC data after that CCC data and HWC data just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model ) http://rapidshare.com/files/34542441...e_by_MxKey.zip http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip http://www.4shared.com/file/21610198...thout_NPC.html http://www.megaupload.com/?d=2MSDVYSY 3. if still not solved than recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON ) 4. if still same than Repair SL REPAIR SD SUPER SD AUTH write PM1 and PM309 5. if still same than make RPL backup full erase than flash than rpl than Repair SL than SD repair than super AUTH than PM 6. after all these steps if still same than i am here for don't worry __________________________________________________ ____________ FOR SL3 LIKE 5130 , 6700c ,................. 1. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! Block1 : open Block 2 pen Block 3 : open in this case just do SX4 and than pm1 and pm309 2. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SL data corrupted in this case u need Nokia RPL ( not supported by MXkey yet ) __________________________________________________ _______________________ PM FILES OF BB5 : just download them from this link and enjoy http://www.megaupload.com/?d=290ZML6M |
The Following 249 Users Say Thank You to hasnain For This Useful Post: |
03-08-2010, 10:22 | #2 (permalink) |
No Life Poster Join Date: Nov 2007 Location: tunisia elmanar sfax
Member: 636518 Status: Offline Thanks Meter: 175 | thanks for detailled information...please add here any notepad to edit rpl |
The Following 2 Users Say Thank You to traxgsm For This Useful Post: |
03-08-2010, 10:31 | #3 (permalink) |
Product Supporter Join Date: Aug 2007 Location: Inside Mobile Phones
Member: 562024 Status: Offline Sonork: +971506319003 Thanks Meter: 135 | FOR SL3 LIKE 5130 , 6700c ,................. 1. SIMLOCK invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! Block1 : open Block 2 pen Block 3 : open in this case just do SX4 and than pm1 and pm309 Is it supported.......................... Br Mahadi |
The Following 7 Users Say Thank You to UNLOCK PARK ® SUPPORT For This Useful Post: |
03-08-2010, 10:35 | #4 (permalink) |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | for example here is N91 RPL [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0535240 PSN=SFE923985 HWID=0600 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303533353234300000000000 NPC_DATA_2=0000000000000000000000009540E094F57E4F4 44E91100000000000000000001E60010556954951 NPC_DATA_3=7D000BE1A830E4982FFCAC24B2E0D53F2FDDF1F C8E55510130F0D067713524354BDF5CEEEC15EBF9 NPC_DATA_4=F5F70C5E875BE02492D9BF5D000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3385930100725682FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF574C414E5F494400 NPC_DATA_6=C47BBD4E1600000000000000000000000000000 00000000000000000000000005B9323A6550F641F NPC_DATA_7=26CF5AE822A624C48C0B979D56C491782F7A890 2BEF90054728900F515ED2FCD4B6DAA2058456ADB NPC_DATA_8=2ADABDF753CBDD8BA42BABCA130FD19EFFCE35E 2449D272CDFD0B2638FEEEDF00C9F44BC7A65AF59 NPC_DATA_9=B82759CE95F1FD496D964329FB6225E6FB4CBEA DAEFF3C61CAE3EE271B9F0BB32EA33B2F6033E8BA VARIANT_DATA_1=357043A5020041500100000030353335323 430430033E09351F51844E9F43E0074A89A0000000000 VARIANT_DATA_2=080000001F00000000000000000000007B3 37D022930ACC4DDC82B3EEDC90233BC9B241CDFDB6A47 VARIANT_DATA_3=0F992E980F27B455BF41ABDB7AA6A6B5189 A971DB6176506478B9D782E86746804844630BFAFD411 VARIANT_DATA_4=80737EA72B6FD38D94FE39CBBC87C99CFA6 339C4CFF5284F630AFF3BA2FCC0A65FE428C6392A6F00 VARIANT_DATA_5=093D97174DC8FC9B181C048ACBD09139C1B CD20457591E96 CHECKSUM=-1 replace the RED lines with the clone RPL in SL1 have to replace variant in SL2 have to replace CCC and HWC is it ok now sir thanx |
The Following 25 Users Say Thank You to hasnain For This Useful Post: |
03-08-2010, 10:47 | #5 (permalink) | |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
see locks shown open than means simlock data not invalid just software shows u that it is invalid thanx | |
The Following 6 Users Say Thank You to hasnain For This Useful Post: |
03-08-2010, 11:13 | #6 (permalink) |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! in such cases Repair SL ( make simlock rpl option ticked ) than SD repair than Super Auth than pm |
The Following 22 Users Say Thank You to hasnain For This Useful Post: |
03-08-2010, 11:30 | #7 (permalink) |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | To Everyone Just post here your success and problems for thanks plz use thanks button |
The Following 11 Users Say Thank You to GsmEasy For This Useful Post: |
03-08-2010, 11:40 | #8 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Around The World
Member: 482670 Status: Offline Thanks Meter: 125 | how to open security code on 5800D Xm ?? dct 4 n other bb5 is easy to open ..but this show out no responding ...cant read that code oso.. wat can i do ? |
The Following User Says Thank You to Brother Hui For This Useful Post: |
03-08-2010, 12:04 | #10 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | @hasnain! Bro thanks a lot after doing many tricks and failing all finally step 3 of your manual could solve my N73 Startup failed Problem and thanks to MX-key team for useful option of : Recover CERT WBR |
The Following User Says Thank You to NawabN Sahoo For This Useful Post: |
03-08-2010, 12:06 | #11 (permalink) | |
3. if still not solved than recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON ) | |
The Following 2 Users Say Thank You to hasnain For This Useful Post: |
03-08-2010, 12:16 | #12 (permalink) |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | For SL1 mobile SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359367007671670 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED a. First Do REPAIR SL b. if not solved than Repair SD Repair SL Super Auth pm c. if still not solved than 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SX4 Auth then write PM1 and PM309 from SAME phone model if still same than contact me always there for u thanx |
The Following 17 Users Say Thank You to hasnain For This Useful Post: |
03-08-2010, 12:19 | #13 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: india
Member: 681945 Status: Offline Thanks Meter: 422 | Quote:
yes mr. husnain's trick is best and tested by me big thanks to mr. hasnain for shareing.... | |
The Following User Says Thank You to kapilgupta For This Useful Post: |
03-08-2010, 12:32 | #14 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: QQ:2557307931
Member: 1010502 Status: Offline Sonork: whats this?! Thanks Meter: 316 | Quote:
thats NOT TRUE! because product code is MISMATCH. certificate product code must same as npc product code. | |
The Following 3 Users Say Thank You to Y.P.Y For This Useful Post: |
03-08-2010, 12:34 | #15 (permalink) |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Phone Type: RM-379 (Nokia 7310 Supernova) SW Version: V 09.40 06-11-08 RM-379 (c) Nokia Imei plain: 12345610654321-? Product Code: 0559926 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2008-11-18T09:56:29Z SW Version: 09.40 Variant Version: 005 ProductProfile: RM379_0559926_09.40_005.spr Simlock: 0559926_simlock.bin Imei plain is invalid !!! SIMLOCK_DATA corrupted! in such cases u could only get mobile out of contact service but can't repair the imei after fix it will show u logs like this e.g, Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0544343 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following 13 Users Say Thank You to hasnain For This Useful Post: |
N73 security test fail start up fail | mobile_mania | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 31 | 03-14-2013 19:33 |
succes full repair phone startup failed and security test failed | jagdish puri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-12-2010 14:17 |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
Please HELP security test -Failed | rakishi | Universalbox | 0 | 01-18-2007 23:45 |
