04-09-2010, 14:52 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | 3110c blinking at nokia logo 1. flashed with 7.21 using jaf with tested cable . 2. flashed with 7.30 using jaf with tested cable . 3. treid to scan with mx-key , it shows imei and after that say "phone not responding " (doesnot does simlock data and all) 4. erased with mx-key 5. after erasing flashed with jaf . (waiting to boot and then failed ) still the handset is blinking at nokia logo what next i have to do ps i use latest flash file 7.30 & also try with usb may be its hardware set not come in liacl mode |
The Following User Says Thank You to sneha For This Useful Post: |
04-09-2010, 15:12 | #3 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 13100102974D00528A2BA485B84FA6630BC5B73E RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 30.094 s |
04-09-2010, 20:39 | #10 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | mxkey>serves>quick fix>bb5 sw downgrade fix and clickdo job mxkey>serves>Quick fix "BB5 RAP3NAND Erase User Area |
The Following User Says Thank You to alasmmar For This Useful Post: |
04-10-2010, 03:43 | #12 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Set can be flashed with almost boxes with latest version and it is not coming to local test mode after flashing is the case prevailing right ? did u measured core voltages in system area ? connect to power supply and measure VIO and VCORE and check the current consumption in start up procedure is it over loading ? just check whether there is any heat in power ic ? b4 doing any hardware blindly ,just put a 5k1 resistor from BSI to GND and press power button -- is it can show test mode ? any of the test mentioned show faulty symptom we have to check power ( u already heated flash chip and ur above log say "[ADL] Update Server code successfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 30.094 s" so that i recomend to measure voltages in system power . regards, NEIL |
The Following User Says Thank You to neilthirumuttam For This Useful Post: |
04-10-2010, 04:39 | #13 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: IN MOBILES
Member: 613242 Status: Offline Sonork: 100.1626311 Thanks Meter: 645 | hello bro Quote:
B / R JAKKAR | |
04-10-2010, 04:49 | #14 (permalink) | |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
i opend the cable its 7 pin but 6 number pin have no conection .can this is cause some fault in local mode ?? u mention b4 doing any hardware blindly ,just put a 5k1 resistor from BSI to GND and can i put in cable that resitanse ?? where i put exact in cable can u give some screenshot i have very few knowladg in hardware so i ask u | |
