Old 03-12-2010, 16:05   #1 (permalink)
Member: 1206133
Thanks Meter: 8
3110c contect service
SCAN
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 3*************
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 3****************
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
When i try to pm auth then
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 110.172.152.3
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 03-12-2010, 16:16   #2 (permalink)
Registered User
Member: 892591
Thanks Meter: 42
use SuperSdAuth button,write pm 1 and 309 only,,
Old 03-12-2010, 16:31   #3 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
detailed info here about this error
Click here --> http://forum.gsmhosting.com/vbb/f550...l-here-945700/
The Following 2 Users Say Thank You to hasnain For This Useful Post:
Old 03-12-2010, 18:27   #4 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
bro,pls do it step by step
1_mxkey>serves>imei&securty>imei rebuild>repair sd
2_go to pm >click sd auth writ pm 1 and 309 and wait 2 mnt
3_full factory
do it
Old 03-13-2010, 06:23   #5 (permalink)
Member: 1206133
Thanks Meter: 8
Using device: J.A.F, FW ver: 01.B2
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
Using cached productData[2A500215CF417E569A58D7A9F5775916C8240964] ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 86 bytes written.
- Key: 18, size 86 bytes written.
- Key: 20, size 86 bytes written.
- Key: 25, size 4 bytes written.
- Key: 29, size 6 bytes written.
- Key: 34, size 80 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 2.844 s
SCAN
Imei plain: 3***************
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 3*******************
Counter: 0/3, 0/10
Still same
Old 03-13-2010, 06:29   #6 (permalink)
Member: 1206133
Thanks Meter: 8
3_full factory
do it
REPAIR SD
Calculating SUPERDONGLE using security server ...
Completed in 5.422 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_3**************_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
Updating SIMLOCK...OK
SD AUTH writ pm 1 and 309
Section: 1
Section: 309
Completed in 2.843 s
FULL FACTORY... OK
Completed in 4.204 s
SCAN
Imei plain: 3****************
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
STILL SAME
Old 03-13-2010, 06:41   #7 (permalink)
Member: 1235188
Thanks Meter: 34
open mx key > service tab > Quick fix > Tick on BB5 sw Downgrade Fix >
PM tab > PM auth > write pm 1 OR 309
Your problem 1000% solve
Old 03-13-2010, 06:51   #8 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 271
write 3110c rpl without npc data.
Old 03-13-2010, 07:06   #9 (permalink)
Member: 1143765
Thanks Meter: 22
Dear bro,
It will be don only whith MX KEY.
If u have MX KEY?
Than u can clear this problum
Old 03-13-2010, 08:15   #10 (permalink)
Member: 1206133
Thanks Meter: 8
Done backup RPL
replace CCC and HWC data with manole's uploaded clone RPL's and write it back
Imei: 3********************
Restoring RF/BB DATA from backup ...
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2A500215CF417E569A58D7A9F5775916C8240964
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Erasing CMT NPC ... OK
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0514950)... OK
Updating PSN (7F0821634)... OK
Updating HWID (2000)... OK
Updating LOCK ...OK
Updating WMDRM_PD...OK
Certificate programmed successfully !
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Still same
Old 03-13-2010, 08:22   #11 (permalink)
Member: 1206133
Thanks Meter: 8
recover certificates gives error
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Reading RAP NPC (0x168 bytes)
Begin Certificate Request ...
Connecting to server ...OK, Login ...
ERROR: No certificate found in the database !
Old 03-13-2010, 08:27   #12 (permalink)
pinkyelectronic's Avatar
Member: 1173492
Thanks Meter: 27
1.Service > Imei & Security > Imei Rebuild > Repair SD
2.Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
3.Service > PM >super SD auth is done, write PM imediately.
Old 03-13-2010, 08:29   #13 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
here you solution 100% tested
http://forum.gsmhosting.com/vbb/f550...ed-but-918754/
fresh thank's button if you solve
Old 03-13-2010, 08:44   #14 (permalink)
Member: 1206133
Thanks Meter: 8
Repair SL
Imei net: 3*********************
Counter: 0/3, 0/10
Backup already exist.
Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x3948 bytes) ...OK
Sending CustomLoader(0x50B0 bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x3B0 bytes) ...OK
Calculating LOCK data ...OK
Receiving Unlocked PM, please WAIT ... OK
Unlocked PM saved to "C:\mobileEx\3.3\data\backup\3***************_UNLO CKED_308.1.PM"
Writing Unlocked PM ... OK
Completed in 40.984 s
Restarting phone ...
Reading Simlock info ...
Counter: 0/3, 0/10
Repair SD
Completed in 3.844 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_3****************_SIMSD.RPL"
SUPER SD AUTH and PM1 and PM309 write
Phone authenticated to SUPERDONGLE already.
Section: 1
Section: 309
Completed in 2.860 s
STILL SAME
Old 03-13-2010, 08:49   #15 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
can you post here in logs info....
1.first if stell try make simlock rpl and write
nokia 7210c ,3110c contect service solution ashish_1212 Nokia Base Band 5 ( BB-5 ) 11 05-29-2010 10:01
3110c contect service help vaghubha_sodha Cyclonebox 3 10-24-2009 08:32
nokia 3110c contect service ranagaurav MXKEY Nokia Flasher and Unlocker (by Alim Hape) 19 10-23-2009 20:31
3110c contect service help vaghubha_sodha Nokia Hardware & Hardware Repair 7 09-15-2009 20:56
3110c CONTECT SERVICE sonugola2 Nokia Base Band 5 ( BB-5 ) 3 08-21-2009 19:10
Page generated in 0.28788 seconds with 10 queries
