05-20-2010, 06:57 | #20 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | i have same problem i try sd auth and ok write pm 1,309 is ok security test pass but after power on show conntact services read again =security test failed any idea? |
05-20-2010, 07:25 | #21 (permalink) |
Registered User Join Date: Dec 2004 Location: largest democratic country
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | 1.erase pm 2.very important check the working sx4 server & select the same 3.write full pm(excluding 308) with sx4 auth 4.scan phone & check status of simlock & security 5.if not okay then do the process required(init sim lock or sd repair) 6.if still getting security failed auth sx4 & write pm with field 1,309 also remember above process is 100% working if full flash erasing is not done if full erarsing has been done then one has to restore hwc & ccc certificates or back rpl (with all data) must be restored |
05-20-2010, 07:33 | #22 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | Please note that "SD Repair" function is DIFFERENT than "SD Auth" !" SD Repair" is under "Imei and security" > "Imei rebuild" tab. Good luck |
05-20-2010, 07:41 | #23 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: LOVE A L L AH LOVE ALQURAN
Member: 754324 Status: Offline Sonork: LOVE MOHAMMAD (S.A.W) Thanks Meter: 500 | Quote:
05-20-2010, 07:55 | #24 (permalink) | |
Freak Poster Join Date: May 2007
Member: 507861 Status: Offline Thanks Meter: 69 | Quote:
try this to see the problem in rpl 1.service 2.phone test 3.various 4.bb5 cet validation... if hwc_ccc rpl is empty download hwc_ccc rpl and write in your phone.. | |
05-20-2010, 08:02 | #25 (permalink) | |
05-21-2010, 05:24 | #27 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Kushtia,Bangladesh
Member: 597569 Status: Offline Sonork: 100.1593870 Thanks Meter: 271 | Quote:
05-21-2010, 06:55 | #28 (permalink) |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | face the same problem with 3110c in the new version but other fones work fine.procedure used sd repair recover certificate super sd auth write full pm but still security test failed any answer to help me or the server fault with 3110 c set . please explain |
05-21-2010, 07:04 | #29 (permalink) |
No Life Poster Join Date: May 2005 Location: Emmc & Ufs Chips Age: 42
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,408 | very simple [QUOTE=palash_c6;5860432]TODAY I RECEIVED A 3110C WITH "SECURITY TEST FAIL" BUT ALL OTHER SECTION IS VALID I TRIED SO MANY TIMES TO DO SX4 & SUPPER SD AUTH.BUT ALWAYS GIVINGTHIS ERROR"Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request" THEN I TRIED TO DO SX4 ON 6303. IT WAS SUCCESSFUL this will happen with 3110 no other software than mxkey will able to remove this just follow simple step 1) repair sd 2) * most important * recover certificate (this is only process will do u a lot in 3110 security test fails c\s ) 3) supersd auth with rf\bb tick then when auth click write i will remove more than 100 c\s of security test fails with mx key its only done by mxkey so well done mx team for ur hard work wbr sachin |
The Following User Says Thank You to chinchik For This Useful Post: |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
Ringtones from the charts and new Links | GM | GSM Mobile Links | 0 | 09-26-1999 13:54 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
