01-17-2010, 11:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Philippines
Member: 557796 Status: Offline Thanks Meter: 187 | 3600s what's this problem? Hi.... i need help.... i have a nokia 3600s the problem is when you go to message or in camera it restart...... i'm trying to flash it but the logs says this: Bus check: Code: Version Info: MCU SW version: V 05.64 21-01-09 RM-352 (c) Nokia HW version: 0500 RFIC version: 064c0601 DSP version: ICPR72_08w47 LCD version: SEIKO PPM version: V 05.64 21-01-09 RM-352 (c) Nokia MA BT MCM version: 2222-143C Retu version: 15 Tahvo version: 22 Content Pack version: Content: ma_charcoal V 05.64 21-01-09 RM-352 (c) Nokia Product Info: Production serial number: DKI999861 Product code: 0561123 Module code: 0203624 Basic production code: 0551468 Long production SN: 0 Serial Numbers: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 21 F6 Other Info: Model : Nokia 3600 slide (Connect Contemporary) CS type : GSM850/GSM900/GSM1800/GSM1900 BSI: 8.8 KOhm Failed to read SP data Phone info: Code: Phone Type: RM-352 (Nokia 3600 slide) SW Version: V 05.64 21-01-09 RM-352 (c) Nokia Imei plain: 12345610654321-? Product Code: 0561123 Cellular System: GSM ASIC ID: 0x0000, type: 0 Ppm Id: MA Language Pack: - not available. Imei plain is invalid !!! Failed to read SP data what shud i do with this kind of problem?......... the Imei is corrupted can this be repaired by MXkey?....... Last edited by =Deftones=; 01-17-2010 at 11:59. |
01-17-2010, 12:00 | #2 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Quote:
Hello ur IMEI is corrupted mean RPL is corrupted u have to buy RPL at the moment all Nokia server r closed so no solution yet. Thanxs | |
The Following User Says Thank You to mujahid_ali For This Useful Post: |
01-17-2010, 12:03 | #3 (permalink) |
Member: 557796 Status: Offline Thanks Meter: 187 | so in short this RPL problem cannot repaired by MXkey?.....or other tools?........ |
The Following User Says Thank You to =Deftones= For This Useful Post: |
01-17-2010, 13:43 | #5 (permalink) |
Freak Poster Join Date: Jan 2006 Location: philippines
Member: 216705 Status: Offline Thanks Meter: 48 | sir try to use 3.2 an older version of mxkey alot of bug in new update ... adjust your date from 2010 to 2009 you can used it again ,its normal if you flash your fone in mxkey that it said emply uem or something like that but if you have bus check your fone and back up certificate its ok just flash ir again or check your cable try it to other fone if its not faulted else ask the owner it it drop or wet damage ..... |
The Following User Says Thank You to joalbert_ramos For This Useful Post: |
08-02-2010, 10:55 | #6 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1251739 Status: Offline Sonork: [email protected] Thanks Meter: 1 | 3600s restart hello 3600s whter damage set restart&camera standby problum any solution.plz |
what's this Problem can;t Unlock N95 8GB | ZoHaiB_(FoneGSM) | Cyclonebox | 3 | 10-30-2009 08:55 |
what's this problem with s320 | nikel333 | Infinity-Box | 4 | 10-07-2009 21:47 |
What's this probleme | oxygene31dz | Universalbox | 2 | 08-31-2009 17:49 |
Realy i dont know what's this problem | freeman2001 | DreamBox | 7 | 07-31-2008 16:07 |
what's this problem hirrrrrrrr | freeman2001 | SCDR II | 5 | 05-28-2007 01:07 |
