07-28-2008, 19:57 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Barcelona
Member: 206476 Status: Offline Thanks Meter: 459 | Realy i dont know what's this problem i try to repair it via dream it's block on 97% or teste failed what's happand this full dss log wbr |
07-29-2008, 11:13 | #3 (permalink) | |
Member: 214480 Status: Offline Thanks Meter: 2,087 | Hello! Quote:
07-30-2008, 03:06 | #5 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Serbia
Member: 18423 Status: Offline Thanks Meter: 26 | Laser: that error can be caused by different problems. lets see all of them 1. user has run "executor" application, which was not deleted after "new altbypass unlock". solution - select correct model on settings check only "use preloader security bypass". execute any operation, say : "read flash" 2. main software somehow has been damaged (cause of free tools, etc) solution - select correct model on settings check only "use signed mode". add to firmware area only main part of firmware press flash (use com/ufs or dcu60 with "2+5" keys if phone not connecting with "C" ) after that, phone should show identify normally. I have problem with k800 cid 53, stoped 97%-dream box, solved with MT-SE only flash. |
The Following User Says Thank You to space1 For This Useful Post: |
07-31-2008, 00:10 | #6 (permalink) |
Member: 206476 Status: Offline Thanks Meter: 459 | @GSM Dream if this phone hw problem i reflashed it via cruiser and now the phone powred on but it's loocked i try many times via tp but no chance where is the problem i passed this times K800 it's go prefect but this the same problem Code: -- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-746991-8 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. i dont think's sir wbr |
07-31-2008, 16:07 | #8 (permalink) |
Member: 206476 Status: Offline Thanks Meter: 459 | hi sir u see only stage 2 i try to baypass it directly to Stage 2 because stage 1 all the times saide failed so whay ! when i try to read info via teste point it's accepte Teste point and show me all info so where is the problem ps the phone now power on and work prefect but it's loocked wbr |
3600s what's this problem? | =Deftones= | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 08-02-2010 10:55 |
what's this Problem can;t Unlock N95 8GB | ZoHaiB_(FoneGSM) | Cyclonebox | 3 | 10-30-2009 08:55 |
what's this problem with s320 | nikel333 | Infinity-Box | 4 | 10-07-2009 21:47 |
What's this probleme | oxygene31dz | Universalbox | 2 | 08-31-2009 17:49 |
what's this problem hirrrrrrrr | freeman2001 | SCDR II | 5 | 05-28-2007 01:07 |
