02-06-2010, 19:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | 5130 after sd repair look the pb SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 3552460*******-6 Product Code: 0578115 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355246031478316 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF i try evry thing like pm and erase npc and write 5130 rpl from mxkey team and same thing contact service any advice |
02-06-2010, 20:34 | #6 (permalink) |
Member: 205475 Status: Offline Thanks Meter: 179 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 07.91 29-10-09 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 12 bytes written. - Key: 1, size 70 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 5, size 276 bytes written. - Key: 6, size 276 bytes written. - Key: 7, size 276 bytes written. - Key: 8, size 276 bytes written. - Key: 9, size 384 bytes written. - Key: 10, size 384 bytes written. - Key: 11, size 384 bytes written. - Key: 12, size 384 bytes written. - Key: 13, size 384 bytes written. - Key: 14, size 384 bytes written. - Key: 15, size 384 bytes written. - Key: 16, size 384 bytes written. - Key: 17, size 32 bytes written. - Key: 19, size 16 bytes written. - Key: 20, size 32 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 1.516 s |
02-06-2010, 20:38 | #7 (permalink) |
Member: 205475 Status: Offline Thanks Meter: 179 | Phone Type: RM-495 SW version: V 07.91 29-10-09 RM-495 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 43 LCD N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO N passed 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N !failed ! 71 BT_WAKEUP N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N !no signal 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal |
02-07-2010, 02:55 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | litle bit spend time with searching button u will get [MXKEY - INFO] !!! NEW magic button inside mxkey !!! and Just in case if Recovery via Server doesn't work....... br, |
02-07-2010, 12:31 | #11 (permalink) |
Member: 205475 Status: Offline Thanks Meter: 179 | Version Info: MCU SW version: V 07.91 29-10-09 RM-495 (c) Nokia HW version: 2000 RFIC version: 06540601 DSP version: ICPR72_09w33 LCD version: SEIKO PPM version: V 07.91 29-10-09 RM-495 (c) Nokia MEN BT MCM version: 2222-302 Retu version: 15 Tahvo version: 22 Content Pack version: Content: mena_a_red V 07.91 29-10-09 RM-495 (c) Nokia Product Info: Production serial number: IIN943286 Product code: 0576616 Module code: 0204024 Basic production code: 0567772 Long production SN: 0 Serial Numbers: IMEI plain: 35524******** IMEI spare to net: 3A 55 42 06 13 74 38 01 IMEI SV to net: 33 55 42 06 13 74 38 41 F7 Other Info: Model : Nokia 5130c-2 (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900 BSI: 3.8 KOhm Imei net: 355246*********** Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 02300106094D7E560F1B29AA141AD240AB64ECCC ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Reading RAP NPC (0x168 bytes) Original Product Code: 0576616 Reading RAP VARIANT (0x0 bytes) Reading RAP CCC (0x160 bytes) Product Code: 0564465 Product Code missmatch ! Reading RAP HWC (0xD4 bytes) Product Code: 0571600 Product Code missmatch ! |
02-07-2010, 12:59 | #12 (permalink) |
Member: 205475 Status: Offline Thanks Meter: 179 | RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 02300106094D7E560F1B29AA141AD240AB64ECCC ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Reading RAP NPC (0x168 bytes) Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! |
02-07-2010, 14:14 | #14 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=920409 | |
Successfully Repaired 3110c Security Test failed after SD Repair | romeoluv56 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-14-2012 12:37 |
Nokia 5130 XM No Network After SD Repair | crazy_kamal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 01-17-2011 08:46 |
5130 Camera on StandBy After SD Repair.. | GsmUniversal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 09-23-2010 15:08 |
E65 start up failed after sd repair and SUPER SD Auth PM 1 and 309[SOLVED] | miklaus35 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 02-06-2010 20:40 |
5300 still contact service after sd repair and use repair button | rajeshbahri | Universalbox | 17 | 12-15-2009 19:05 |
