Old 03-05-2010, 15:21   #1 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
5130 superdongle_key invalid
pls help mx team i need solution of this
simlock invalid
superdonle key invalid
wd timer enable phone restart itself after 3 min
simlock test failed
security test passed
pls help i have rpl backup also
thanks in advance
Old 03-05-2010, 15:24   #2 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 102
simlock invalid
simlock test failed
thanks in advance
Super dongle data is possible to repair by clicking Repair SD
but simlock invalid isn't possible at the moment bcz it is SL3 Phone
Old 03-05-2010, 15:24   #3 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
sir pls help me i need it urjent pls
Old 03-05-2010, 15:27   #4 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
sir my phone is in contact service how may i do this pls guide me
Old 03-05-2010, 15:29   #5 (permalink)
Member: 199814
Thanks Meter: 1,960
you can not repair this phone As in logs your phones simlock data is corrupted
Old 03-05-2010, 15:36   #6 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
this cannot be posible with mx or this cannot be repair from any tool
Old 03-05-2010, 15:37   #7 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
you can repair sd but,
you cant repair simlock at this moment not supported yet...
wait for update...
Old 03-05-2010, 15:38   #8 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
but can i remove only contact service frm that phone
Old 03-05-2010, 15:41   #9 (permalink)
Member: 199814
Thanks Meter: 1,960
@b12345 Explain already you can not repair this phone at this moment at not supported for rearing simlock data. and other option you can repair it using bb5 rpl but i dont have idea that server is online or not! it will cost you not a free service..
Old 03-05-2010, 15:42   #10 (permalink)
Member: 760274
Thanks Meter: 146
if u need remove contact service need rpl service contact with nokia care...
Old 03-05-2010, 15:44   #11 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
ok sir
i m very much unhappy because i have to return it back to my customer
thank u sir
SUPERDONGLE_KEY invalid! what can i do ?? comp_new2006 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 18 05-08-2011 09:37
nokia 5130 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SE >>.123.<< MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 10-24-2010 11:05
7120c SUPERDONGLE_KEY invalid,SIMLOCK invalid!done. ...sewren... MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 03-25-2010 08:09
nokia 5130 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SE >>.123.<< MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 02-17-2010 05:29
Help 7310c simlock superdongle_key invalid and invalid nardisk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-29-2010 19:38
Page generated in 0.20622 seconds with 9 queries
