Old 08-16-2010, 08:41   #1 (permalink)
djomir's Avatar
Member: 424104
Thanks Meter: 45
5130c successful SECURITY_TEST failed! (ANSWERED)
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1AD000099CF18956BC24B7E61EB79E6DAF16B91A
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Original Imei: 35604003783329
Original Product code: 0578115
Bluetooth ID: 002668610ECF
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.96 20-05-10 RM-495 (c) Nokia
Imei plain: 35604003783329-6
Product Code: 0578115
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
Imei net: 356040037833296
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
PM AUTH
Authenticating using [MX] security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 114.124.74.15
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Retrying ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
SUPERDONGLE authorized !
Updating RFBB data ...
Writing section 1...
Writing section 309...
Done.
Writing PM from Node ...
Section: 1
- Key: 0, size 12 bytes written.
- Key: 1, size 70 bytes written.
- Key: 2, size 70 bytes written.
- Key: 3, size 70 bytes written.
- Key: 4, size 70 bytes written.
- Key: 5, size 276 bytes written.
- Key: 6, size 276 bytes written.
- Key: 7, size 276 bytes written.
- Key: 8, size 276 bytes written.
- Key: 9, size 384 bytes written.
- Key: 10, size 384 bytes written.
- Key: 11, size 384 bytes written.
- Key: 12, size 384 bytes written.
- Key: 13, size 384 bytes written.
- Key: 14, size 384 bytes written.
- Key: 15, size 384 bytes written.
- Key: 16, size 384 bytes written.
- Key: 17, size 32 bytes written.
- Key: 19, size 16 bytes written.
- Key: 20, size 32 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 7.672 s
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Counter: 0/3, 0/10
thank to team mx-key
the best for unlock/flash nokia
br
The Following 2 Users Say Thank You to djomir For This Useful Post:
Old 08-16-2010, 09:01   #2 (permalink)
anowar_virus's Avatar
Member: 1024090
Thanks Meter: 1,175
mx-key good.......................
Old 08-16-2010, 09:06   #3 (permalink)
Member: 101650
Thanks Meter: 46
i dnt understand clearly plz tell what was condition before 5130 sl3 phone.it comes for unlock or flash...and tell step procedure.
Old 08-16-2010, 09:09   #4 (permalink)
djomir's Avatar
Member: 424104
Thanks Meter: 45
First method:
1. taking full Backup IMEI & Security -> Backup RPL (All Section)
2. Super SD Auth, and finally write Full PM(without Field 308-120)
Old 08-16-2010, 09:10   #5 (permalink)
Member: 143764
yes this hash work with mxkey and not work with HWK . tnks
Old 08-16-2010, 09:13   #6 (permalink)
Member: 862260
Sonork: 100.1612919
Thanks Meter: 156
good work brother ..............
Old 08-18-2010, 12:10   #7 (permalink)
Member: 101650
Thanks Meter: 46
Originally Posted by djomir View Post
First method:
can u give the link 5130 pm file
Old 08-18-2010, 12:42   #8 (permalink)
Member: 101650
Thanks Meter: 46
i did same procedure but not done
SW Version: V 07.95 03-02-10 RM-495 (c) Nokia
Imei plain: 35417903960405-7
Product Code: 0571584
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SIMLOCK_DATA corrupted!
Old 08-18-2010, 12:59   #9 (permalink)
.::VENUGOPAL::.'s Avatar
Member: 1230663
Sonork: 100.1593487
Thanks Meter: 174
not possible sl3 wait for update
Old 08-18-2010, 13:19   #10 (permalink)
djomir's Avatar
Member: 424104
Thanks Meter: 45
Language Pack:
- not available.
SIMLOCK invalid!
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Done.
Section: 1
Section: 309
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
- taking full Backup IMEI & Security -> Backup RPL (All Section)
- Restore only NPC Backup Part
- Repair Superdongle with MXKey
- Super SD Auth, and finally write Full PM(without Field 308-120)
(If required Recover Cert)
at try to recurrent
congratulation try
Old 05-07-2011, 10:44   #11 (permalink)
Member: 456367
Sonork: 100.1613650
Thanks Meter: 94
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
PM AUTH
Retrying ...
Done.
Section: 1
Section: 309
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
br
sir i need to pm file 5130c plz uplod ...
Old 05-08-2011, 01:45   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
you don;t need any pm to fix contact service caused by security test failed.
- do not load any pm, mark load RFBB from server, and click write after auth is done.
Old 11-20-2011, 19:46   #13 (permalink)
Member: 807057
Thanks Meter: 16
Big thanks to mx team
Old 04-01-2013, 15:44   #14 (permalink)
Member: 1255883
Thanks Meter: 4
thanks bro its working
SUCCESS in Repairing 3310 Contact Service (Double-blink) using NFREE by ViperBJK ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 07-08-2001 16:00
In wintesla 3310, what does cobba parrarel failed means brittnee Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 05-18-2001 16:05
MCU EEPROM contents: failed phr3ak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-12-2001 15:58
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.28002 seconds with 9 queries
