Old 03-29-2012, 14:59   #1 (permalink)
.:TithiMobile:.'s Avatar
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
5800 vibrate only but Local mode test mode ok with usb (SOLVED, HW)
Here is My LOG>>>>>>>>
MXKEY [FT SCR2000 0], SN: C0832583
Using device: USB ROM
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.73
Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1EC4B54F
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1420000E14C2015804646757ACAB00490049677E
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0xFF bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0xFF bytes).
Reading CMT HWC (0xFF bytes).
Reading CMT R&D (0xFF bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 22CE09BF
Verifying communication to device OK.
Phone type: RM-356 (Nokia 5800 XpressMusic)
SW version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia
ApeCoreSw: V 60.0.003
Imei plain: 35418202321733-2
Product code: 0573797
Battery voltage: 3731 mV, current: 315 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354182023217332
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 03-29-2012, 15:03   #2 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
Self Test Result
Phone Type: RM-356
ID Test name Startup Result
104 ACCEL_IF N passed
32 AMB_LIGHT_SENSOR N passed
20 BACKUP_BATT N passed
101 BTEMP N passed
71 BT_WAKEUP N passed
92 BT_WLAN_COEXISTENCE N passed
5 CAMERA_ACCELERATOR N passed
38 CAMERA_AUTOFOCUS N passed
22 CAMERA_IF N passed
77 CDSP_GSM_TX_POWER N !no signal
82 CDSP_PWR_DETECTOR_BIAS N !no signal
86 CDSP_RF_BB_IF N !no signal
83 CDSP_RF_SUPPLY N !no signal
81 CDSP_RX_IQ_LOOP_BACK N !no signal
79 CDSP_RX_PLL_PHASE_LOCK N !no signal
56 CDSP_SLEEPCLK_FREQ N passed
128 CDSP_SLEEPCLOCK_FREQ N !no signal
74 CDSP_TXC_DATA N !no signal
85 CDSP_TX_IQ N !no signal
80 CDSP_TX_PLL_PHASE_LOCK N !no signal
75 CDSP_WCDMA_TX_POWER N !no signal
2 CURRENT_CONS N passed
3 EAR_DATA_LOOP Y passed
108 EXT_DEVICE N passed
96 HOOKINT N passed
119 IIC N passed
114 IO_EXPANDER_IF N !NOT EXECUTED(03)
7 KEYBOARD_STUCK N passed
113 LCD_CONTROLLER N passed
121 LED_FLASH N passed
44 LPRF_AUDIO_LINES N passed
21 LPRF_IF N passed
59 MAIN_LCD_IF N passed
8 MBUS_RX_TX_LOOP Y passed
90 PWR_KEY N passed
42 RADIO N passed
42 RADIO N !NOT EXECUTED(03)
93 SECURITY N passed
37 SEC_CAMERA_IF N passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
33 SIM_LOCK N passed
88 TAHVOINT Y passed
103 TOUCH_IF N passed
60 TOUCH_STUCK N passed
115 TVOUT_IF N !NOT EXECUTED(03)
46 UEM_CBUS_IF Y passed
91 USB_LOOP N !NOT EXECUTED(03)
49 VIBRA N passed
72 WLAN N passed
Old 03-29-2012, 16:16   #3 (permalink)
ms phone's Avatar
Member: 1119242
Sonork: 100.1638541
Thanks Meter: 121
flash with eno file .
change bsi line
Old 03-29-2012, 16:21   #4 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
eno file? bsi line?
change bsi line
where i can get eno file or how to check bsi line
give me eno file link
Old 03-29-2012, 16:23   #5 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
use naifirm to download it
Old 03-29-2012, 16:25   #6 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
which product code?
which product code and version file is eno file please tell me clear bro
Old 03-29-2012, 16:30   #7 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 4,180
flash same product code 1000000% on ur set
Old 03-29-2012, 17:37   #8 (permalink)
NOKIA_PLUS's Avatar
Member: 1547481
Thanks Meter: 27
NAVIFIRM_V1.5.2 search product code download file flash your mobile
not work check bsi line i hope work
Old 03-30-2012, 04:04   #9 (permalink)
Member: 608516
Sonork: 100.1607007
Thanks Meter: 123
yes u can use eno file in mcu part first take back up rpl the flash with eno file and thenflash with same product code file set will be 100% on
Old 03-30-2012, 04:19   #10 (permalink)
Member: 1488173
Thanks Meter: 194
Before flash this handset, clean the battery connector or replace battery, if not, full flash later and surely your phone will be alive again.
Br. Celumast3r !!
Old 03-30-2012, 08:02   #11 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
i can't understood eno file please give me eno file
i already flashed with same product code from nevi firm
Old 03-30-2012, 08:04   #12 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
My Mobile product code is 0575590
Old 03-30-2012, 08:38   #13 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
install Nokia phoenix and go in tool>data package download and write your product code and tick mark on download option file also, and press availability and download it , it will download all files with eno file, but must see that this version is downgraded to your version so must take backup of rpl and pm and erase flash and flash these file and restore backup of rpl and pm and if still same then 100% hardware problem
Old 03-30-2012, 08:49   #14 (permalink)
viniy's Avatar
Member: 1720726
Thanks Meter: 44
try this solution by nicky collection ( bhopal )
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
try this solution and post me result
Old 03-30-2012, 09:08   #15 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
thankssss
thanks i will try and will post result
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.28728 seconds with 11 queries
