02-27-2010, 03:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | 7210c-rm436 SECURITY_TEST failed! SW Version: V 05.21 20-10-08 RM-436 (c) Nokia Imei plain: 35574302640687-2 Product Code: 0566806 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355743026406872 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF how can solve this problem and whether it may MX-Key |
02-27-2010, 03:43 | #3 (permalink) |
Insane Poster Join Date: Jul 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 811157 Status: Offline Sonork: poklay Thanks Meter: 9 | repair ur sd first then wrute pm 1 and pm 309 using super sd auth |
The Following User Says Thank You to aerish For This Useful Post: |
02-27-2010, 03:45 | #4 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | no need to repair sd since sd is valid Quote:
The Following User Says Thank You to alfox For This Useful Post: |
02-27-2010, 03:46 | #6 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Future
Member: 804247 Status: Offline Sonork: 1593659 Thanks Meter: 310 | First, MAke Repair SD Super SD auth Then write PM 1 and 309 / write modified PM |
The Following User Says Thank You to daveiant For This Useful Post: |
02-27-2010, 03:50 | #8 (permalink) |
Freak Poster Join Date: Jan 2008 Location: NGANJUK
Member: 689706 Status: Offline Thanks Meter: 28 | step by step 1 update splock 2 repair sd 3 super sd auth 4 load from file 5 pm 1 to 309 6 writem pm |
The Following User Says Thank You to balqis_iman For This Useful Post: |
02-27-2010, 03:54 | #10 (permalink) | ||
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | Quote:
02-27-2010, 04:25 | #15 (permalink) |
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | ..........problem is solved ...thanks .........MobileEx-Team........ Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. |
Nokia 7210c SECURITY_TEST failed! | jodhpur_raj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 21 | 03-22-2011 10:11 |
NOKIA 7210C STIL SECURITY_TEST failed | Wasim007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 26 | 02-13-2010 15:57 |
7210c show SECURITY_TEST failed! | aukonline | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-13-2010 13:39 |
plz help me mr manole . still problem with 7210c SECURITY_TEST failed! | jagdish puri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-09-2010 13:18 |
after sd repair 7210c SECURITY_TEST failed! | snkhan70 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 16:06 |
