12-01-2009, 11:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | 7210c show SECURITY_TEST failed! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! |
The Following User Says Thank You to aukonline For This Useful Post: |
12-01-2009, 12:43 | #2 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | Just Do Sx4 Authorization And Write P.M Field 1 And Field 309............ All Will Be Fine............ |
The Following 2 Users Say Thank You to prince_arsalan For This Useful Post: |
02-04-2010, 07:30 | #6 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1220104 Status: Offline Sonork: 1592061 Thanks Meter: 44 | 7210c show SECURITY_TEST failed! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! plz help ..................................... |
02-04-2010, 07:35 | #7 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Future
Member: 804247 Status: Offline Sonork: 1593659 Thanks Meter: 310 | same problem here.....cant access SX4.. Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 111.118.146.193 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-13-2010, 13:39 | #9 (permalink) |
Junior Member Join Date: Nov 2009 Location: Pakistan
Member: 1156668 Status: Offline Thanks Meter: 13 | HERE IS THE SOLUTION FOR THIS If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 POST RESULTS AFTER THIS TRY |
The Following 2 Users Say Thank You to 0C00L For This Useful Post: |
Nokia 7210c SECURITY_TEST failed! | jodhpur_raj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 21 | 03-22-2011 10:11 |
7210c-rm436 SECURITY_TEST failed! | sajohaker | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 18 | 02-27-2010 04:39 |
NOKIA 7210C STIL SECURITY_TEST failed | Wasim007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 26 | 02-13-2010 15:57 |
plz help me mr manole . still problem with 7210c SECURITY_TEST failed! | jagdish puri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-09-2010 13:18 |
after sd repair 7210c SECURITY_TEST failed! | snkhan70 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 16:06 |
