04-08-2012, 07:08 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: ..:: Limra ::.. Mobile's .
Member: 680336 Status: Offline Thanks Meter: 44 | C1-01 Successfully Flashed With Usb With Letest Ver. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: xxxxxxx Using device: USB ROM and HTI, FW ver: 00.50, SN: xxxxxxx Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35702104142091 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35702104142091_ back.RPL" Processing file: rm607__06.15.mcusw Downloading item CODE:rm607__06.15.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.360 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.500 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.359 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 1.437 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 30.860 s Checksum verified (0x49A2) Processing file: rm607__06.15.ppm_a Downloading item CUSTackage_a.ppm_ebl_psi.fls, num block: 1, size: 3.54 MB Erasing area 0x41C00000-0x41F88D16 ...OK Programming completed in 4.859 s Checksum verified (0xDF49) Processing file: rm607__06.15.image_a_0595346 Downloading item CUSTackage_a_0595346.image.fls, num block: 1, size: 11.38 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 16.390 s Checksum verified (0xAD17) Total time for flashing process(boot+erase+write) was 7 min 35.828 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 325DF844 Verifying communication to device OK. After Flash Processing ... Reseting Factory Values OK. Phone type: RM-607 (C1-01) SW version: V 06.15 25-11-11 RM-607 (c) Nokia Imei plain: 35702104142091-5 Product code: 0596369 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00CS00000401022E05, ver: 001.004 Imei net: 35702104142091 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
The Following 2 Users Say Thank You to sirajkhan For This Useful Post: |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
