Old 05-19-2011, 02:16   #1 (permalink)
Member: 219702
Question C3 problem (mtp device driver)
i need help.
hi, i have this problem, everytime when i try to read nokia c3 whit mxkey
usb via
i have this problem : pc says mtp device drivers needs..... ever . ever , ever ,ever and ever..... and no connect whit mxkey usb via.
nokia ovi and nokia pc suite installed and i try in 2 different pc. and 2 different phones.
br.
this is log:
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
Secondary boot loaded.
FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID1: 0010 0011 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E
Update server code loaded.
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2A8380B9
Verifying communication to device OK.
Original Imei: 35538404887658
Original Product code: 059C3J1
Bluetooth ID: 9C4A7B534242
SIMLOCK PA identifier:
[0] PA_SL3
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Waiting for device boot up ...
Device found: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 3AD6EA7C
Verifying communication to device...
Communication lost, phone not found.
Phone not responding !
Old 05-19-2011, 06:39   #2 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
Angry
Download attach mtp driver
The Following 2 Users Say Thank You to TechPhone For This Useful Post:
Old 05-19-2011, 22:34   #3 (permalink)
djkiddrick's Avatar
Member: 645603
Thanks Meter: 89
make a full flash not use bus check,not always work using the bus check.
The Following User Says Thank You to djkiddrick For This Useful Post:
Old 05-20-2011, 18:09   #4 (permalink)
Member: 219702
Post no solution
no solution yet, is same problem and when i try flash, mxkey put same log.
br.
Old 06-01-2011, 04:21   #5 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
I have tried everything to resolve this and not find the solution.
please no one is solved this?
Old 06-01-2011, 05:56   #6 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
I install the Nokia OVI,Update the Windows Media Player, the MxKey too. and it still keeps coming! I want remove the security code to Nokia Rm C3-00-614.
I do not see the solution !!!!!
Mr. Malone, Help please!
[IMG]http://2.bp.********.com/-Brd-cDiFvy4/TeXEq8cosdI/AAAAAAAAAoM/0NAR6nlOCy0/s640/MTP+Device+ERROR.JPG[/IMG]
The Following User Says Thank You to braham12 For This Useful Post:
Old 06-01-2011, 07:13   #7 (permalink)
rana_g_mobiles's Avatar
Member: 1421704
Thanks Meter: 64
dont buschek
add flash file and just full flash
after flash all serves is active
The Following User Says Thank You to rana_g_mobiles For This Useful Post:
Old 06-01-2011, 16:24   #8 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
I flash it but no reset de user code, i want do this!!! how can do this via usb?
Old 06-01-2011, 17:35   #9 (permalink)
aravindanav's Avatar
Member: 1587303
Thanks Meter: 42
download microsoft mtp driver kit
Old 06-02-2011, 02:15   #10 (permalink)
Member: 69911
Thanks Meter: 69
where do i paste this inf...?
thanks...
Old 06-02-2011, 06:42   #11 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
paste any where in ur system when system found new hardware just give the path where ur paste the MTP driver ok
Old 06-03-2011, 17:41   #12 (permalink)
Member: 219702
well
when mtp device drivers appears its solution whitout choose bus-check and usb cable.
flash your phone and finished, whit out disconnect your phone; in mxkey´s window appears option flash and service , choose service option and reset o read user code.
remember not disconnect your phone.
br.
Old 07-29-2011, 16:38   #13 (permalink)
mail0's Avatar
Member: 236218
Thanks Meter: 35
thanks...
download from microsoft support
Old 12-18-2012, 00:27   #14 (permalink)
dampealdany's Avatar
Member: 1308889
Sonork: 100.1608156
Thanks Meter: 266
i have the same problem, edymata you can solved this ? but my problem is just with one C3
Old 11-29-2016, 14:36   #15 (permalink)
Member: 598806
merciiiiiiiiiiiiiiiiiiii bcp
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.26162 seconds with 10 queries
