Old 02-21-2010, 11:20   #1 (permalink)
Member: 56008
DCT4+ "BUS Check" problem
Hello! I have a problem with these mobile phones: 1208, 2600C, 1680..
I use mobileEx_setup_v3.3_rev1.6_20100213_.exe
After pressing the "BUS Check" button always appears the same message:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
BootLoader not responding, mostly RAM problem !
It appears even on 100% working phones. Flashing is not possible.
Where is the problem?
Thank you!
Old 02-21-2010, 11:23   #2 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
Thank you!
use jaf interface ur problem solve
Old 02-21-2010, 11:34   #3 (permalink)
Member: 793926
Thanks Meter: 67
same problem wait...............
Old 02-21-2010, 11:57   #4 (permalink)
Member: 56008
Hi - "use jaf interface ur problem solve " - I must buy JAF which costs 200 eu here for unlocking and flashing DCT4+. That can't be serious!? Version mobilEx 3.2 rev 3.x works with UFS. Why doesn't the new one work with an original dongle?
Old 02-21-2010, 11:59   #5 (permalink)
realtech's Avatar
Member: 1003310
Thanks Meter: 28
Are you able to connect and check info in other softwares like hwk and jaf? if no problem with interface/cable pls check and comment
Old 02-21-2010, 12:05   #6 (permalink)
Member: 783116
Thanks Meter: 52
the same here, i used UFS
maybe this is a bug
Old 02-21-2010, 12:08   #7 (permalink)
Member: 56008
This is log using MTBOX - -same cable
Boot...
Trying boot BB5 phone...
Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit
Trying boot DCT4 phone...
DCT4
u3_2nd.fia
u3_amd.fia
ASIC ID: 3162
Configuration Info (9F):
Number of Flashes: 2
01000000: Samsung, 00EC 2208 0000 9121, 11
02000000: NotUsed, 0000 0001 0000 0000, 0
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
UEM IMEI is: 00000000000000
============= Set FBus mode for info =============
Pins:
Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
Phone is in: Local mode
Model: RM-340 (2600 Classic)
V 05.61/18-04-08/RM-340 (c) Nokia
Production serial number DPJ765646
Product code 0556645
Module code 0203632
Basic production code 0551000
Flash code
Order number
Long production SN 0
MCU SW V 05.61/18-04-08/RM-340/(c) Nokia
HW 1001
PCI
UEM 1328
UPP 12642
RFIC 0500
DSP P06w45.v48
LCD SUEZ
PPM V 05.61/18-04-08/RM-340/(c) Nokia/EK
BT MCM 2222-v101
Content Pack Content: ek/V 05.61/18-04-08/RM-340/(c) Nokia/
IMEI: 35417602254xxx
Old 02-21-2010, 12:24   #8 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
this is problem in new update so w8 new update fix this error
Old 02-21-2010, 12:49   #9 (permalink)
sajidashraf's Avatar
Member: 501674
Sonork: THEIF OF HEART
Thanks Meter: 883
Talking problem solve use version 1.6
Phone Type: RM-305
SW Version: V 5.91 27-03-09 RM-305 (c) NMP
Imei plain: 35680002817710-6
Product Code: 0547568
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IA
Language Pack:
- not available.
Imei net: 35680002817710
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000010002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
plz use letest version mx-key without any problem
Old 02-21-2010, 12:57   #10 (permalink)
Member: 56008
Hi,thanks for answer to all!
im use letest version mx-key
» Nokia Service Tool
Version from module: 1.0.0.12217
Version from server: 1.0.0.12217
Module version is up to date
My problem not for read phone info -problem is Bus check and flashing & unlock
Old 02-21-2010, 13:07   #11 (permalink)
Member: 507861
Thanks Meter: 69
TRY MY SOLUTION... download and install then post result..
http://www.4shared.com/file/22645972...v16_fixer.html
logs
Library version: 1.0.0.7548(21-01-2010), 1.0.0.12217(18-02-2010)
Rpl backup already exist (C:\mobileEx\3.3\data\backup\35135500417363_BACK.r pl).
Processing file: rh3010pra05.340 as MCU
[DCT4,DCT4 ALGORITHM] size: 5.48 MB
Supported Ids: 0120, 0121, 1120, 1130, 1131, 2142, 2140
ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 22F2 [Samsung K8S64158TM,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 008D66BC:C421DA60
Area [01000000-0100FFFF] erased in 0.531 s
Area [01010000-0157FFFF] erased in 43.923 s
Area [01580000-0168FFFF] erased in 8.392 s
Area [01690000-017EFFFF] erased in 10.796 s
Area [01E90000-01FEFFFF] erased in 0.420 s
Flash programming ...
Programming completed in 52.586 s
File Processed in 2 min 6.742 s
Processing file: rh3010_05.34.ucp_c as CNT
[DCT4,DCT4 ALGORITHM] size: 165.37 KB
Area [01580000-0168FFFF] erased in 8.643 s
Programming completed in 1.452 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 2.234 s
File Processed in 29.072 s
Processing file: rh3010_05.34c as PPM
[DCT4,DCT4 ALGORITHM] size: 1.02 MB
Area [01580000-0168FFFF] erased in 8.612 s
Programming completed in 8.682 s
File Processed in 25.486 s
Flashing completed in 3 min 2.493 s
After Flash Processing ...
Updating SIMLOCK ...OK
Phone Type: RH-30 (Nokia 3200)
SW Version: V 5.34 11-02-05 RH-30 3200 (c) Nokia
Imei plain: 35135500417363-2
Imei OTP: 35135500417363
Product Code: 0511998
ASIC ID: 0x1130, type: 2
Ppm Id: C
Language Pack:
English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
Imei net: 35135500417363
Version: SIMLOCK SERVER VERSION 40 - Extended number of TDS-6 boxes
Counter: 0/3, 0/10
PROFILE_BITS: 0000000000000002
Total time to process is 3 min 13.098 s
The Following 2 Users Say Thank You to ELOY1024 For This Useful Post:
Old 02-21-2010, 16:43   #12 (permalink)
Member: 56008
Big thanks ELOY1024 - all is ok!!!
Old 02-21-2010, 18:44   #13 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
what ever interface you use, the problem is bug in older versions
i was facing same problem but updated with last release and now phones going well
Old 02-21-2010, 20:12   #14 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
logs
Ppm Id: C
Language Pack:
Counter: 0/3, 0/10
hi,
plese reupload link not working thanks.
BR.
Old 02-21-2010, 20:26   #15 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
Originally Posted by eloy1024 View Post
try my solution... Download and install then post result..
logs
using device: Ufs_usb v2.8 (c) sarassoft 2007.
rpl backup already exist (c:\mobileex\3.3\data\backup\35135500417363_back.r pl).
Processing file: Rh3010pra05.340 as mcu
[dct4,dct4 algorithm] size: 5.48 mb
supported ids: 0120, 0121, 1120, 1130, 1131, 2142, 2140
asic id: 0x1130 [upp_8m ver: 3.0 or 3.01 or 3.1]
secondaryboot: U_2nd.fia [dct4] version: 4.76.0 revision: 0.7 size: 0x9a0
supported ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
flashid0: 00ec 22f2 [samsung k8s64158tm,64 mbits] page size: 64 k type: Nor area: 01000000-017fffff
flashid1: 0000 0001 [unused/removed]
extbusc: Ad7e b61a 1bbe 0be2 7d58 6be4 dbee 6514
algorithm: U_amd.fia [dct4 algorithm] version: 4.76.0 revision: 0.7 size: 0x78b8
performing flash authentication ...ok
uem id: 008d66bc:c421da60
area [01000000-0100ffff] erased in 0.531 s
area [01010000-0157ffff] erased in 43.923 s
area [01580000-0168ffff] erased in 8.392 s
area [01690000-017effff] erased in 10.796 s
area [01e90000-01feffff] erased in 0.420 s
flash programming ...
file processed in 2 min 6.742 s
processing file: Rh3010_05.34.ucp_c as cnt
[dct4,dct4 algorithm] size: 165.37 kb
area [01580000-0168ffff] erased in 8.643 s
extracting content pack, (c) nokia file server
content pack extracted successfully in 2.234 s
file processed in 29.072 s
processing file: Rh3010_05.34c as ppm
[dct4,dct4 algorithm] size: 1.02 mb
area [01580000-0168ffff] erased in 8.612 s
file processed in 25.486 s
flashing completed in 3 min 2.493 s
after flash processing ...
Updating simlock ...ok
phone type: Rh-30 (nokia 3200)
sw version: V 5.34 11-02-05 rh-30 3200 (c) nokia
imei plain: 35135500417363-2
imei otp: 35135500417363
product code: 0511998
cellular system: Gsm
asic id: 0x1130, type: 2
ppm id: C
language pack:
English,german,french,italian,dutch,spanish,turkis h,portuguese
imei net: 35135500417363
version: Simlock server version 40 - extended number of tds-6 boxes
provider: All operator, country: -
counter: 0/3, 0/10
config_data: 0010100000000000
profile_bits: 0000000000000002
block 1: 1.open 2.open 3.open 4.open 5.open
block 2: 1.open 2.open 3.open 4.open 5.open
block 3: 1.open 2.open 3.open 4.open 5.open
block 4: 1.open 2.open 3.open 4.open 5.open
block 5: 1.open 2.open 3.open 4.open 5.open
block 6: 1.open 2.open 3.open 4.open 5.open
block 7: 1.open 2.open 3.open 4.open 5.open
total time to process is 3 min 13.098 s
warning link blocked sign applitation and blocked start mx-key
DCT4 NOKIA 8310 Problem.Please advice me. NKV MT-BOX 11 02-16-2006 05:26
DCT4 unlock big problem... GSM-Java Phone Unlocking Codes & Maps 2 09-03-2003 14:46
flasher dct4 pro pro problem NNN Nokia Digital Core Technology 4 ( DCT-4 ) 1 04-17-2003 16:17
DCT4 Flash connector problem? ecsike Nokia Digital Core Technology 4 ( DCT-4 ) 0 11-13-2002 19:51
DCT4 Flasher Pro Probleme LORD_SHAH Nokia Digital Core Technology 4 ( DCT-4 ) 20 11-13-2002 13:57
Page generated in 0.29401 seconds with 9 queries
