02-21-2010, 11:20 | #1 (permalink) |
Junior Member Join Date: Feb 2004 Location: Bulgaria Age: 57
Member: 56008 Status: Offline Thanks Meter: 0 | DCT4+ "BUS Check" problem I use mobileEx_setup_v3.3_rev1.6_20100213_.exe After pressing the "BUS Check" button always appears the same message: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! It appears even on 100% working phones. Flashing is not possible. Where is the problem? Thank you! |
02-21-2010, 11:23 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
02-21-2010, 11:57 | #4 (permalink) |
Member: 56008 Status: Offline Thanks Meter: 0 | Hi - "use jaf interface ur problem solve " - I must buy JAF which costs 200 eu here for unlocking and flashing DCT4+. That can't be serious!? Version mobilEx 3.2 rev 3.x works with UFS. Why doesn't the new one work with an original dongle? |
02-21-2010, 12:08 | #7 (permalink) |
Member: 56008 Status: Offline Thanks Meter: 0 | This is log using MTBOX - -same cable Boot... Trying boot BB5 phone... Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit Trying boot DCT4 phone... DCT4 u3_2nd.fia u3_amd.fia ASIC ID: 3162 Configuration Info (9F): Number of Flashes: 2 01000000: Samsung, 00EC 2208 0000 9121, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 UEM IMEI is: 00000000000000 ============= Set FBus mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-340 (2600 Classic) V 05.61/18-04-08/RM-340 (c) Nokia Production serial number DPJ765646 Product code 0556645 Module code 0203632 Basic production code 0551000 Flash code Order number Long production SN 0 MCU SW V 05.61/18-04-08/RM-340/(c) Nokia HW 1001 PCI UEM 1328 UPP 12642 RFIC 0500 DSP P06w45.v48 LCD SUEZ PPM V 05.61/18-04-08/RM-340/(c) Nokia/EK BT MCM 2222-v101 Content Pack Content: ek/V 05.61/18-04-08/RM-340/(c) Nokia/ IMEI: 35417602254xxx |
02-21-2010, 12:49 | #9 (permalink) |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | problem solve use version 1.6 problem solve use version 1.6 Code: Phone Type: RM-305 SW Version: V 5.91 27-03-09 RM-305 (c) NMP Imei plain: 35680002817710-6 Product Code: 0547568 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35680002817710 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
02-21-2010, 12:57 | #10 (permalink) |
Member: 56008 Status: Offline Thanks Meter: 0 | Hi,thanks for answer to all! im use letest version mx-key » Nokia Service Tool Version from module: 1.0.0.12217 Version from server: 1.0.0.12217 Module version is up to date My problem not for read phone info -problem is Bus check and flashing & unlock |
02-21-2010, 13:07 | #11 (permalink) |
Freak Poster Join Date: May 2007
Member: 507861 Status: Offline Thanks Meter: 69 | TRY MY SOLUTION... download and install then post result.. http://www.4shared.com/file/22645972...v16_fixer.html logs Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7548(21-01-2010), 1.0.0.12217(18-02-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\35135500417363_BACK.r pl). Processing file: rh3010pra05.340 as MCU [DCT4,DCT4 ALGORITHM] size: 5.48 MB Supported Ids: 0120, 0121, 1120, 1130, 1131, 2142, 2140 ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F2 [Samsung K8S64158TM,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008D66BC:C421DA60 Area [01000000-0100FFFF] erased in 0.531 s Area [01010000-0157FFFF] erased in 43.923 s Area [01580000-0168FFFF] erased in 8.392 s Area [01690000-017EFFFF] erased in 10.796 s Area [01E90000-01FEFFFF] erased in 0.420 s Flash programming ... Programming completed in 52.586 s File Processed in 2 min 6.742 s Processing file: rh3010_05.34.ucp_c as CNT [DCT4,DCT4 ALGORITHM] size: 165.37 KB Supported Ids: 0120, 0121, 1120, 1130, 1131, 2142, 2140 ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F2 [Samsung K8S64158TM,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008D66BC:C421DA60 Area [01580000-0168FFFF] erased in 8.643 s Flash programming ... Programming completed in 1.452 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 2.234 s File Processed in 29.072 s Processing file: rh3010_05.34c as PPM [DCT4,DCT4 ALGORITHM] size: 1.02 MB Supported Ids: 0120, 0121, 1120, 1130, 1131, 2142, 2140 ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F2 [Samsung K8S64158TM,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008D66BC:C421DA60 Area [01580000-0168FFFF] erased in 8.612 s Flash programming ... Programming completed in 8.682 s File Processed in 25.486 s Flashing completed in 3 min 2.493 s After Flash Processing ... Updating SIMLOCK ...OK Phone Type: RH-30 (Nokia 3200) SW Version: V 5.34 11-02-05 RH-30 3200 (c) Nokia Imei plain: 35135500417363-2 Imei OTP: 35135500417363 Product Code: 0511998 Cellular System: GSM ASIC ID: 0x1130, type: 2 Ppm Id: C Language Pack: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Imei net: 35135500417363 Version: SIMLOCK SERVER VERSION 40 - Extended number of TDS-6 boxes Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 13.098 s Last edited by ELOY1024; 02-21-2010 at 13:10. Reason: a |
02-21-2010, 18:44 | #13 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | what ever interface you use, the problem is bug in older versions i was facing same problem but updated with last release and now phones going well |
02-21-2010, 20:12 | #14 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
hi, plese reupload link not working thanks. BR. | |
02-21-2010, 20:26 | #15 (permalink) | |
warning link blocked sign applitation and blocked start mx-key | |
DCT4 NOKIA 8310 Problem.Please advice me. | NKV | MT-BOX | 11 | 02-16-2006 05:26 |
DCT4 unlock big problem... | GSM-Java | Phone Unlocking Codes & Maps | 2 | 09-03-2003 14:46 |
flasher dct4 pro pro problem | NNN | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-17-2003 16:17 |
DCT4 Flash connector problem? | ecsike | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-13-2002 19:51 |
DCT4 Flasher Pro Probleme | LORD_SHAH | Nokia Digital Core Technology 4 ( DCT-4 ) | 20 | 11-13-2002 13:57 |
