Old 05-13-2010, 11:56   #1 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
check this yall
Imei net: 01149800283671
Version: SIMLOCK SERVER
Provider: T-Mobile, Country: U.S.A.
Counter: 0/3, 0/10
CONFIG_DATA: 3102000000000000
PROFILE_BITS: 800000000001000B
BLOCK 1: 1.LOCKED (MCC+MNC): 310160
BLOCK 2: 1.LOCKED (MCC+MNC): 310200
BLOCK 3: 1.LOCKED (MCC+MNC): 310210
BLOCK 4: 1.LOCKED (MCC+MNC): 310220
BLOCK 5: 1.LOCKED (MCC+MNC): 310230
BLOCK 6: 1.LOCKED (MCC+MNC): 310240
BLOCK 7: 1.LOCKED (MCC+MNC): 310250
BLOCK 8: 1.LOCKED (MCC+MNC): 310260
BLOCK 9: 1.LOCKED (MCC+MNC): 310270
BLOCK 10: 1.LOCKED (MCC+MNC): 310310
BLOCK 11: 1.LOCKED (MCC+MNC): 310580
BLOCK 12: 1.LOCKED (MCC+MNC): 310660
BLOCK 13: 1.LOCKED (MCC+MNC): 310800
BLOCK 14: 1.LOCKED (MCC+MNC): 310490
Calculating SIMLOCK RPL using security server ...
and thats all is this server problem?
Old 05-13-2010, 11:58   #2 (permalink)
Member: 1239771
Sonork: 1591957
Thanks Meter: 314
Arrow
Counter: 0/3, 0/10
bro what is your problem past all logs here
don"t wary servar are busy
The Following User Says Thank You to Gulzar Magsi For This Useful Post:
Old 05-13-2010, 12:02   #3 (permalink)
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
Counter: 0/3, 0/10
i wat to unlock this fone but it cant ..... is stop at Calculating SIMLOCK RPL using security server
Old 05-13-2010, 23:16   #4 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
Post screen shot, so we can see full log and the software version.
BR,
Manole
Old 05-15-2010, 10:14   #5 (permalink)
Member: 751235
Sonork: 100.1662008
Thanks Meter: 526
» Nokia Service Tool
Version from module: 1.0.0.12955
Version from server: 1.0.0.12843
Module version is up to date
i try to make update but is up to date
Old 05-15-2010, 10:41   #6 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
Hi Mr. wzupfones
first go and see in option the servers list ,after press it, i think you will find it empty,
just uninstall ur mxkey then delete the folder mobileEX , delete any thing related with mobilex manually, then setup it again nd sign application,
see now if u can see servers,
i faced same prob the procedure above solved it
wish u good luck
New to all this (about 1 hour) :) Mark UK Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 10-01-2010 09:01
check out my FREE large gsm soft site LaLGsm GSM Mobile Links 0 01-16-2001 04:36
try this for nokia 5.36 BELY Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-28-2000 00:59
READ this IGOR_M!!!!!!!!!!!!! nightxyz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-04-2000 04:49
Has someome tested this software Nokia New Series Tool? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-20-2000 16:39
Page generated in 0.18025 seconds with 9 queries
