Old 10-12-2009, 19:21   #1 (permalink)
Member: 67240
Thanks Meter: 45
Create RPL from Pm?.....can Mx do this?.
hi, does any Mx user can tell me if Mx-Key have this function, create PRL from PM?. see this post:
http://forum.gsmhosting.com/vbb/show...=create+rpl+PM
Thnaks in advance.
Old 10-12-2009, 20:13   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
what is the advantage of that tool?
br
Old 10-12-2009, 20:25   #3 (permalink)
dars_cell's Avatar
Member: 209226
Thanks Meter: 210
I think it's a good feature..
If Mr. Alim may add on MXkey soft, it will being better
some time, it will be needed (if it work 100%)
More feature more power..
Just hoping
BR.
dars_cell
Old 10-12-2009, 20:34   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
what is good and how good of that feature, can you tell me more about it?
br
Old 10-12-2009, 20:41   #5 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
It is to create a simlock RPL from a PM.
This helps, in mobiles with the PM308 write protected, to sync again PM120 and 308 and solve the problem in reading SP-infos.
Is not enaugh, sometime, write only the PM 120.
It helps as well to relock the mobile if needed or fix bad unlocking where the simlock key data are not updated after changing the simlock data
It is a quite simple algo.
Alex
Old 10-12-2009, 20:46   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hello Alex,
so can you say, this method is to write eeprom via flash mode?
br
The Following User Says Thank You to gbluez For This Useful Post:
Old 10-12-2009, 20:56   #7 (permalink)
moulnisky's Avatar
Member: 947561
The simlock RPL in the mobiles is all included in the PM120.
sample:
PM 120
[120]
0=00000000000000002440700000000000001807000000000000 50000005FFFFFF00B4000005FFFFFF0118000005FFFFFF017C 000005FFFFFF01E0000005FFFFFF0244000005FFFFFF02A800 0005FFFFFF000000007FFF6F07FFFFFFFFF800030C03000503 000000007FFF6F3EFFFFFFFFC000030F02000103000000007F FF6F3FFFFFFFFFC000031102000103000000007FFF6F07FFFF FFFF07FE031308000503000000007FFF6F07FFFFFFFF07FE03 1B08000503000000007FFF6F07FFFFFFFFF800032303000503 000000007FFF6F3EFFFFFFFFC000032602000103000000007F FF6F3FFFFFFFFFC000032802000103000000007FFF6F07FFFF FFFF07FE032A08000503000000007FFF6F07FFFFFFFF07FE03 3208000503000000007FFF6F07FFFFFFFFF800033A03000503 000000007FFF6F3EFFFFFFFFC000033D02000103000000007F FF6F3FFFFFFFFFC000033F02000103000000007FFF6F07FFFF FFFF07FE034108000503000000007FFF6F07FFFFFFFF07FE03 4908000503000000007FFF6F07FFFFFFFFF800035103000503 000000007FFF6F3EFFFFFFFFC000035402000103000000007F FF6F3FFFFFFFFFC000035602000103000000007FFF6F07FFFF FFFF07FE035808000503000000007FFF6F07FFFFFFFF07FE03 6008000503000000003F007F206F07FFFFF800036803000503 000000003F007F206F3EFFFFC000036B02000103000000003F 007F206F3FFFFFC000036D02000103000000003F007F206F07 FFFF07FE036F08000503000000003F007F206F07FFFF07FE03 7708000503000000003F007F206F07FFFFF800037F03000503 000000003F007F206F3EFFFFC000038202000103000000003F 007F206F3FFFFFC000038402000103000000003F007F206F07 FFFF07FE038608000503000000003F007F206F07FFFF07FE03 8E08000503000000003F007F206F07FFFFF800039603000503 000000003F007F206F3EFFFFC000039902000103000000003F 007F206F3FFFFFC000039B02000103000000003F007F206F07 FFFF07FE039D08000503000000003F007F206F07FFFF07FE03 A508000503FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
1=CA64E106ACE4D4C760FB7F8A182BA60C5B8DA961C7E96AE197 A2A9EAE47C3730D9510D23FBD485C27650B37357F71B62DD91 E1BE48B3138EC257C2A1554C530DDF5CF3EF3F09B2BB310664 21AB583A9B
2=F88CD99B956A662C1A8FCB7E55213520ABDECE3C
SIMLOCK RPL
[CERT_PROG_DATA_OUT_CMT]
SIMLOCK_DATA_1=8D15652AF81FAD349B84440CEAAD97D8DD17601F0000000000000000244070000000000000180700
SIMLOCK_DATA_2=000000000050000005FFFFFF00B4000005FFFFFF0118000005 FFFFFF017C000005FFFFFF01E00000
SIMLOCK_DATA_3=05FFFFFF0244000005FFFFFF02A8000005FFFFFF000000007F FF6F07FFFFFFFFF800030C03000503
SIMLOCK_DATA_4=000000007FFF6F3EFFFFFFFFC000030F02000103000000007F FF6F3FFFFFFFFFC000031102000103
SIMLOCK_DATA_5=000000007FFF6F07FFFFFFFF07FE031308000503000000007F FF6F07FFFFFFFF07FE031B08000503
SIMLOCK_DATA_6=000000007FFF6F07FFFFFFFFF800032303000503000000007F FF6F3EFFFFFFFFC000032602000103
SIMLOCK_DATA_7=000000007FFF6F3FFFFFFFFFC000032802000103000000007F FF6F07FFFFFFFF07FE032A08000503
SIMLOCK_DATA_8=000000007FFF6F07FFFFFFFF07FE033208000503000000007F FF6F07FFFFFFFFF800033A03000503
SIMLOCK_DATA_9=000000007FFF6F3EFFFFFFFFC000033D02000103000000007F FF6F3FFFFFFFFFC000033F02000103
SIMLOCK_DATA_10=000000007FFF6F07FFFFFFFF07FE034108000503000000007F FF6F07FFFFFFFF07FE034908000503
SIMLOCK_DATA_11=000000007FFF6F07FFFFFFFFF800035103000503000000007F FF6F3EFFFFFFFFC000035402000103
SIMLOCK_DATA_12=000000007FFF6F3FFFFFFFFFC000035602000103000000007F FF6F07FFFFFFFF07FE035808000503
SIMLOCK_DATA_13=000000007FFF6F07FFFFFFFF07FE036008000503000000003F 007F206F07FFFFF800036803000503
SIMLOCK_DATA_14=000000003F007F206F3EFFFFC000036B02000103000000003F 007F206F3FFFFFC000036D02000103
SIMLOCK_DATA_15=000000003F007F206F07FFFF07FE036F08000503000000003F 007F206F07FFFF07FE037708000503
SIMLOCK_DATA_16=000000003F007F206F07FFFFF800037F03000503000000003F 007F206F3EFFFFC000038202000103
SIMLOCK_DATA_17=000000003F007F206F3FFFFFC000038402000103000000003F 007F206F07FFFF07FE038608000503
SIMLOCK_DATA_18=000000003F007F206F07FFFF07FE038E08000503000000003F 007F206F07FFFFF800039603000503
SIMLOCK_DATA_19=000000003F007F206F3EFFFFC000039902000103000000003F 007F206F3FFFFFC000039B02000103
SIMLOCK_DATA_20=000000003F007F206F07FFFF07FE039D08000503000000003F 007F206F07FFFF07FE03A508000503
SIMLOCK_DATA_21=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_22=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_23=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_25=FFFFFFFF
SIMLOCK_KEY_DATA_1=CA64E106ACE4D4C760FB7F8A182BA60C5B8DA961C7E96AE197 A2A9EAE47C3730D9510D23FBD485C2
SIMLOCK_KEY_DATA_2=7650B37357F71B62DD91E1BE48B3138EC257C2A1554C530DDF 5CF3EF3F09B2BB31066421AB583A9B
SIMLOCK_KEY_DATA_3=F88CD99B956A662C1A8FCB7E55213520ABDECE3C
The part in this color is calculated
Writing this rpl the data are sync in the PM308 and PM120
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 10-12-2009, 21:09   #8 (permalink)
moulnisky's Avatar
Member: 947561
Originally Posted by gbluez View Post
hello Alex,
br
We can say yes.. as the data are written by the firmware in the PM.
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 10-12-2009, 21:13   #9 (permalink)
moulnisky's Avatar
Member: 947561
If you add this function for the SL2 and, as well, for the new new security and the extraction of the superdongle key from the PM308 this tool will fly as service tool.
Alex
Old 12-21-2009, 19:05   #10 (permalink)
moulnisky's Avatar
Member: 947561
sample:
PM 120
[120]
SIMLOCK RPL
The part in this color is The SHA1 signature of the PM120,0 <==== Correction added on 21.12.2009
Alex
Just made a correction in my old post as been asked a few times how to calculate it
Alex
Old 08-27-2010, 07:19   #11 (permalink)
Member: 331052
I've accidently overridden/delete the PM for my 5800,
I have the original imei and imsi number,
the device is rm-356, 50.0.006
cannot create RPL from phone. hugmax Cyclonebox 5 10-07-2009 05:18
!!! E65 Failed to Create RPL from phone -> Failed to Boot / Prepare Phone !!! sirbigman Cyclonebox 12 07-08-2009 15:05
Create RPL from PM function moulnisky Cyclonebox 9 06-08-2009 06:56
Error creating RPL from N73-1 ISO9002 Cyclonebox 7 06-05-2009 07:58
Can I do this? From 6233 to 6280? KRIZA Nokia Base Band 5 ( BB-5 ) 0 10-11-2008 22:37
Page generated in 0.22598 seconds with 9 queries
