12-25-2010, 19:54 | #1 (permalink) |
No Life Poster Join Date: Oct 2010
Member: 1423200 Status: Offline Thanks Meter: 53 | do you need high end gpu AND cpu or just high end GPU can i still unlock in around 50 hours with phenom dual core and 5870 thanks? |
12-25-2010, 20:19 | #2 (permalink) |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | see here ATI HD 5850: ~55 hours ATI HD 5870: ~43 hours ATI HD 5970: ~24 hours Dual ATI HD 5970: ~12 hours http://forum.gsmhosting.com/vbb/f550...-done-1170957/ |
12-25-2010, 20:32 | #3 (permalink) |
Member: 1423200 Status: Offline Thanks Meter: 53 | i think it would be btter t ogo for nvidia cards becuase then you can take advantage of CUDA. the ati cards dont have CUDA im alos asking "will having a better cpu play a crucial part in the time it takes to unlock?" |
12-25-2010, 20:52 | #4 (permalink) |
Freak Poster Join Date: May 2007
Member: 515830 Status: Offline Thanks Meter: 80 | ati is beter. 5970 have 3000 stream cores. and 4.9teraflops. ati have cuda but with other name. ati call this tech "stream" not buy quad or x6 with 5870. dual core with 2gb and 5970 is faster |
The Following 2 Users Say Thank You to evasoft For This Useful Post: |
12-25-2010, 22:58 | #6 (permalink) |
Member: 515830 Status: Offline Thanks Meter: 80 | cuda or strean (name of cuda for ati cards) use gpu power not cpu. so if you want to make phone faster. try to spend less money in cpu, memory, hdd and try to spend "ALL" you money in one or two 5970. i was using cuda for years helping in folding@home for find cure cancer and others. now i using stream for play and folding. i hope mx key help folding@home when they are not using sl3 read more in.... Folding@home - Main |
The Following User Says Thank You to evasoft For This Useful Post: |
12-26-2010, 02:59 | #7 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: ATT IPHONE -SL3 LBF,MAC EFI
Member: 542009 Status: Offline Thanks Meter: 54 | Quote:
http://www.frys.com/product/6490932?...H:MAIN_RSLT_PG Thanks | |
12-26-2010, 06:01 | #8 (permalink) |
No Life Poster Join Date: Mar 2005 Location: cebu city
Member: 126086 Status: Offline Sonork: 100.113901 Thanks Meter: 232 | 5970 is better compare there specs.. GPU estimations Radeon HD 5970 3200 725 2320.00 8561M 2320M 44190 1103658 134826 4d 17h $600 3.87 Radeon HD 6990 ?? 3072 750 2304.00 9328M 2400M 45714 1141715 139475 4d 13h - - |
The Following User Says Thank You to .:CARLO:. For This Useful Post: |
12-26-2010, 07:32 | #9 (permalink) |
Member: 515830 Status: Offline Thanks Meter: 80 | 6990 is a graphic beast, but is not for sale until 02/2011 and dont will be cheap. if the prereleased data is ok 2x6990 will unlock sl3 in 7/8hs Drivers are also a big problem. better drivers for 5970 are catalyst 10.5, in the latest vercion just work one gpu on stream (remember 5970 is better because has 2 gpu in one card) and maybe ati dont release a good fixed driver until 06/2011. Dont forget power supply with real 1000w and a good heat solution if you dont want to reball you card every weak. A stock cooled card at full load for 24hs will burn in 2 days if you are lucky. First you need to do some stress test to you sistem like "sandra" with that program you will know if your sistem can support heavy work. a well cooled environment is required. the big boom of sl3 will come when mx team release a cluster or cloud solution. escuse my bad english |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
