Old 02-27-2010, 19:16   #1 (permalink)
louisgsm's Avatar
Member: 605126
Sonork: 100.1617907
Thanks Meter: 297
e63 unlock helpppppppppppppp
Phone Type: RM-437 (Nokia E63)
SW Version: V ICPR71_08w44.1 30-10-08 RM-437 (c) Nokia
Imei plain: 35683602585540-1
Product Code: 0585258
Language Pack:
- not available.
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Backup already exist.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Product: V ICPR71_08w44.1 30-10-08 RM-437 (c) Nokia
ApeCoreSw: 100.21.110
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: 4B9B75103E691FF8
Sending SecondaryBoot [rapidov11_2nd.fg](0x3AC0 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x190C bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x190 bytes) ...OK
Sending KEYS [SLPA] (0x19B0 bytes) ...OK
Calculating LOCK data ...OK
Unlocked PM saved to "C:\mobileEx\3.3\data\backup\356836025855401_UNLOC KED.PM"
Writing Unlocked PM ... OK
Completed in 20.875 s
Restarting phone ...
help plz urgent
The Following User Says Thank You to louisgsm For This Useful Post:
Old 02-27-2010, 20:07   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
distinguish when using NCK and SIMLOCK Repair
br,
The Following 2 Users Say Thank You to Andra For This Useful Post:
Old 03-01-2010, 04:27   #3 (permalink)
Member: 507832
Thanks Meter: 78
br 1 stup rirer sd
lod pm 1 309 & auth pm write pm problem sloved
Old 03-01-2010, 05:29   #4 (permalink)
Member: 1133675
Sonork: 100.1604417
Thanks Meter: 18
Use MX to repair it,your phone will be OK
Old 03-01-2010, 09:23   #5 (permalink)
AllGsmStore's Avatar
Member: 99509
Sonork: Whatsapp +971508482353
Thanks Meter: 210
hi louisgsm you do just select UNLOCK BY CODE and click calc NCK
i do already e71x+e51
mebey your problem solve
The Following User Says Thank You to AllGsmStore For This Useful Post:
Old 03-21-2010, 12:03   #6 (permalink)
silveraxe's Avatar
Member: 166746
Thanks Meter: 86
I am unlocking E63 RM RM-450
It was saying superdongle invalid
So i followed forum, and fixed REPAIR SD
then I SUPER SD AUTH
now security test failed,
forum says need good PM
I dont have a PM for E63 RM450 PLEASE HELP URGENT
Old 03-21-2010, 12:04   #7 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
http://forum.gsmhosting.com/vbb/f550...-mxkey-954123/
Click here --> http://forum.gsmhosting.com/vbb/f550...l-here-945700/
The Following 2 Users Say Thank You to hasnain For This Useful Post:
Old 03-21-2010, 12:12   #8 (permalink)
silveraxe's Avatar
Member: 166746
Thanks Meter: 86
ok nevermind this POST fixed my phone DDD
http://forum.gsmhosting.com/vbb/f550...failed-922005/
Old 03-21-2010, 12:14   #9 (permalink)
silveraxe's Avatar
Member: 166746
Thanks Meter: 86
re
Thank you man, but is now sorted out
with those 2 posts thank u
Old 07-12-2010, 13:30   #10 (permalink)
Member: 894173
Originally Posted by Andra View Post
thanks BOSS mantap....
Old 07-21-2010, 12:28   #11 (permalink)
Member: 52362
Thanks Meter: 35
why cannot unlock E63
this log : scan phone ---->
SW Version: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia
Imei plain: 35200904400616-6
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 352009044006166
Version: SIMLOCK SERVER
Provider: Singtel Optus-Cable + Wireless Optus, Country: Australia
Counter: 0/3, 0/10
CONFIG_DATA: 5050200000000000
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 50502F, DATA=50502F
bus check ---->
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 18E00108B4940052A4B0CC902334BD448395AFCC
ASIC MODE ID: 00
ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
Please select correct loader version from 'Config' menu !
i try many loader but still same .....
and this unlock by code ----->
Counter: 0/3, 0/10
Product: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia
ApeCoreSw: 400.21.013
ERROR: Missing SP BLOCK or PM corrupted !
why should i do ????
please help me...
thank's .
Old 08-05-2010, 04:07   #12 (permalink)
Member: 1351347
Thanks Meter: 2
For unlocking Nokiae63, go through the site Wicked Unlock.com- Unlock Your Phone
It has the best unlocking solutions.
You too try this site.
Old 08-05-2010, 05:22   #13 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 813
Language Pack:
- not available.
SIMLOCK invalid!
help plz urgent
use this guide
>> REPAIR SIMLOCK
>> tick "Make SIMLOCK RPL"
>> "Repair SPLOCK"
The Following User Says Thank You to naveedbutt For This Useful Post:
Old 08-05-2010, 05:49   #14 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
all detail solution now is here hope you can solve your problem
e63 unlock problem cant unlock [SOLVED] msmobile Cyclonebox 7 12-29-2009 08:42
E63 Unlock problem le3sa Cyclonebox 11 07-03-2009 22:06
e63 unlock ???????????? parveen kumar Universalbox 2 05-29-2009 15:51
e63 unlocking possible with ub rajesh_ch Universalbox 1 05-23-2009 15:24
E63 unlocked, an other one E63 dead evaireland Universalbox 2 05-20-2009 07:57
Page generated in 0.26515 seconds with 9 queries
