Old 11-15-2012, 13:52   #1 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Red face e65 phone startup failed Contact the retailer
e65 phone start up failed Contact the retailer here is log
MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C086FDE7
Using device: HTI, FW ver: 00.50, SN: 010060CC
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 8F1D9A540A92E0FC151D9B959F5703558496A983
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0CC00102F84D0254CC7C87151FA4632B58E66460
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0266638E9C2164FC6B5194ED596A6A251C699896
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
Storage0: 0098 0078 - 00A5 00C0 [Toshiba 1Gb DDP NAND,1 Gbits] type: FLASH,NAND, asic:APE
Storage content: 0002 0000 0006 0000 0000 0000 0000 0000
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 0266638E9C2164FC6B5194ED596A6A251C699896
Original Imei: 35483201977498
Original Product code: 0553560
SIMLOCK PA identifier:
[0] PA_SL
Phone type: RM-208 (Nokia E65)
SW version: V 4.0615.2 05-06-08 RM-208 (c) Nokia.
Imei plain: 35483201977498-1
Battery voltage: 4468 mV, current: 149 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354832019774981
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 2.141 s
Now tel me what is prob
Old 11-16-2012, 21:43   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
Try Hard Reset,
Press & hold these 3 keys together:
- Green dial key
- * key
- 3 key
Then press the Power ON Switch of your Phone,
Do not let go the three keys until you see the "formatting" screen displayed,
If not Solve, then it means it's Hardware & need Selftest Logs.
BR,
ZUBER
Old 11-17-2012, 08:00   #3 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Originally Posted by .::ZUBER::. View Post
Hi,
Try Hard Reset,
- Green dial key
- * key
- 3 key
BR,
ZUBER
here is Selftest Logs
Old 11-17-2012, 08:34   #4 (permalink)
akhtarmughal's Avatar
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
bro hardware problem
Old 11-17-2012, 08:51   #5 (permalink)
Member: 1061035
Sonork: raza
Thanks Meter: 12
hardware problem Brthr ...
Old 11-17-2012, 14:04   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
It's Hardware,
Reflow PCB, specially Avilma IC & Audio Section.
BR,
ZUBER
Page generated in 0.14174 seconds with 9 queries
