Old 02-10-2010, 18:34   #1 (permalink)
Member: 540254
Thanks Meter: 30
How to repair SD NOKIA N96 ..!!!
phone come to me with Simlock data corrupt and" phone start up failed "after flashed with another tool..
so I did write it's full pm backup using super sd auth but the phone became only nokia logo then go off..the I make repair simlock (make rpl simlock) and simlock repaired..but phone still as it (nokia logo then off)..
plz help me with steps to repair it..
Phone Type: RM-247 (Nokia N96-1)
SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
Imei plain: 35486302663277-1
Product Code: 0543727
ApeCoreSw: 30.033
ApeVariant: 30.033, 30.033.010.1, 30.033.098.1
ApeTest: ENOSW_4032_PR11.0835_003
ContentPack: V 40.2009.25.xx PRD
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 354863026632771
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-10-2010, 18:42   #2 (permalink)
Crazy Poster
Member: 616506
Thanks Meter: 3
i have same n96...identic problems...everyone one response??pls..
Old 02-10-2010, 19:10   #3 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 503
try this simple ...............
Old 02-10-2010, 19:27   #4 (permalink)
Member: 540254
Thanks Meter: 30
I tried b4..I already make sd repair then write it's full pm backup..but somtimes it fails when it's write field 1 and 309 and sometimes it write it..but still same..is it could be pm prb..??
do u have good pm or 1,309 good pm..so I can try it..!
Old 02-10-2010, 20:16   #5 (permalink)
gecata's Avatar
Member: 16994
Thanks Meter: 157
You make it at wrong way man. After SD repair and write full pm backup from same phone You revert it back to wrong state. Write full pm from another good working phone, make SD repair ... and ... just follow instructions ...
Good luck!
Old 02-10-2010, 22:06   #6 (permalink)
Member: 540254
Thanks Meter: 30
I write full pm from working phone then i make sd repair..then what what other instructions plz
Old 02-11-2010, 08:04   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
your last log info from phone ?
do "BB5 secure Validation" what do you get ?
br,
Old 02-11-2010, 11:59   #8 (permalink)
Member: 540254
Thanks Meter: 30
after writing full pm from working phone with skipping writing 120,308 fields phone still same..!
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
APE Data :
SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x]
ASIC MODE ID: 00
PUBLIC ID: 2298802FAE18DB4D0436631765D0ABD19151D15E
ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
ROM ID: 137A9A3B33259D2C
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1B500011AEDA015836D0F591AB38E30B114D4E2F
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00
Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3
FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE
ALG [35]: N8815 ALG STNFMS
Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78
APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Original Imei: 35486302663277
Original Product code: 0567011
Bluetooth ID: 0025CF3753B3
WLAN ID: 0025CF383E13
Language Pack:
- not available.
SIMLOCK_TEST passed
TimeStamp: 2008-11-27T11:07:47+00:00
SW Version: 12.043
Variant Version: 011
ProductProfile:
Simlock: simlock_3gstandard_bb5.bin
Counter: 0/3, 0/10
any ideas..?
Old 02-11-2010, 12:01   #9 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
Repaire S/D link
u can try
Old 02-11-2010, 12:22   #10 (permalink)
Member: 540254
Thanks Meter: 30
Yes I have tried that ..and here is log for "BB5 SECURE VALIDATION):
Product: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
ApeCoreSw: 30.033
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 35, size 16 bytes written.
- Key: 37, size 4 bytes written.
- Key: 39, size 36 bytes written.
- Key: 44, size 182 bytes written.
- Key: 45, size 182 bytes written.
- 120 skipped
- 308 skipped
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 1.875 s
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Reading RAP NPC (0x1B8 bytes)
Original Product Code: 0567011
Reading RAP VARIANT (0x0 bytes)
VARIANT empty !
Reading RAP CCC (0x160 bytes)
Product Code missmatch !
Reading RAP HWC (0x0 bytes)
Old 02-11-2010, 12:25   #11 (permalink)
MihaiGsm2003's Avatar
Member: 62032
Sonork: 1582666
Thanks Meter: 193
ApeCoreSw: 30.033
Section: 1
- 120 skipped
- 308 skipped
Section: 309
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
VARIANT empty !
Write rpl without NCP...then repair again
Old 02-11-2010, 12:28   #12 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
see this
http://http://forum.gsmhosting.com/v...d.php?t=920409
Old 02-11-2010, 12:34   #13 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
http://forum.gsmhosting.com/vbb/showthread.php?t=903537
Old 02-11-2010, 12:42   #14 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
see this
http://http://forum.gsmhosting.com/v...5&postcount=21
http://http://forum.gsmhosting.com/v...5&postcount=20
Old 02-11-2010, 13:06   #15 (permalink)
Member: 540254
Thanks Meter: 30
I wrote rpl without NPC from files that manole thread offered..and then make write full pm>simlock repair>repair sd>super sd auth>write pm 1,309 still same..!
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
VARIANT empty !
How To Repair Dead Nokia 1100 celluniversal Nokia Digital Core Technology 4 ( DCT-4 ) 10 11-26-2012 16:09
help...please explane step by step how to repair sd CHAPRAN MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-04-2010 10:53
How to repair sd by Genie? ashraf_bcs Genie Universal 4 01-18-2010 17:29
how to repair imei nokia 5070 jiangoma MT-BOX 1 06-10-2009 01:58
How To Repair Dead Nokia 1100 celluniversal Nokia Digital Core Technology 4 ( DCT-4 ) 5 09-25-2007 13:32
Page generated in 0.29903 seconds with 9 queries
