08-10-2011, 12:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | [INFO AND SOLUTION] Why Mx-box not detecting any phone (USER'S FAULT) ONLY ONE READ LIGHT AND GREEN LIGHT IS ON OTHER RED AND GREEN LIGHT NOT ON ALSO I TRY ON OTHER PC STILL SAME PROBLEM OTHER BOXs CONNECT AND FLASH PHONE WELL PLS HELP ME WITH THIS PROBLEM MY BOX IS 3 MONTHS OLD WBR sahil2000ind |
08-10-2011, 13:59 | #3 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: Waiting for HTI in boot mode ... » Begin transaction ... Initializing HTI ... HTI initialized. Boot version: 00.07 Serial: 00002EB9 Receive firmware from server ... SERVER->Served by MXKEY - BLADE Z at upd, agent version 1.1 revision 0.9 Firmware version on server: 00.17 Received buff checksum verified OK. Updating HTI firmware, please WAIT ... HTI firmware update OK. » End transaction (status: 0, Successfull) ALSO DONE BUT SAME WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
08-11-2011, 08:29 | #8 (permalink) |
Freak Poster Join Date: Apr 2008 Location: west java
Member: 756701 Status: Offline Sonork: 100.1592286 Thanks Meter: 91 | Check vbat output from RJ45 = 5v if not, change this IC (code BCP69) take from old jaf BR |
The Following User Says Thank You to sumatera For This Useful Post: |
08-11-2011, 10:23 | #9 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | R U SURE THAT ITS THAT IC PROBLEM I CAN REPLACE THAT IC BUT MY BOX IS STILL IN WARRANTY MX-KEY TEAM PLS HELP US TO MAKE OUR BOX WORK AGAIN WBR sahil2000ind |
08-11-2011, 10:33 | #10 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
we give warranty for six months. but if you want to void your warranty, be my guest sumatra's post is correct. about HW damaged, i already post this on my mxkey local forum. that transistor (PNP type) is damaged because of over current while handling short circuited phone. BR Last edited by gbluez; 08-11-2011 at 11:37. Reason: transistor type | |
The Following User Says Thank You to gbluez For This Useful Post: |
08-11-2011, 11:42 | #14 (permalink) | |
it is general purpose power transistor. you can substitute by any PNP transistor. here is the transistor data sheet. UFS use this transistor also. BR | |
The Following 2 Users Say Thank You to gbluez For This Useful Post: |
08-11-2011, 12:16 | #15 (permalink) | |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
THANKS FOR ALL URE HELP I CHANGED THE TRANSISTOR AND NOW ALL WORKING GOOD BUT MY BOX WARRANTY IS VOID WBR sahil2000ind | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
