02-26-2010, 14:21 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | that can be many reason : - phone have stable local mode ? - same type or not ? - wrong procedure what is your problem ? can you post details log for this phone ? br, |
02-26-2010, 14:33 | #5 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | mostly come from BAD QUALITY cables come from CHINA what are not able to put your nokia phone in local mode. br, Last edited by Andra; 02-26-2010 at 15:18. |
02-26-2010, 14:53 | #7 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | trying to flash N72 Quote:
ya m trying to flash N72 only.... sir its not cable problem i flashed by Hwk sucessfully.. ill pos here info log | |
02-26-2010, 14:57 | #8 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | JAF interface problem hello br see this doing with HWK Imei: 35957001****** Restoring RF/BB DATA from backup ... Error unable to detect product ! Updating WARRANTY ...error 0x0 Updating PROD ...error 0x0 Updating BT ...error 0x0 APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 963CCE52E8900CDAF8650F21443F5BF57273FDA6 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0160010EF6506851097BDB00A3B9C1EC7D462883 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 0001 0002 - 0000 7111 [AMD NA] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS is blank/erased. NPC verified Ok. Updating CMT NPC ...OK Updating CMT VARIANT ...failed, Result: 0000000000000000 Certificate programmed successfully ! Phone not responding ! |
02-26-2010, 15:05 | #10 (permalink) | |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | flashing option need RX2 pin in BB5 for have good result in SERVICE operation ( write PM,factory default,etc ) , stable cable in LOCAL MODE needed for this point is we must have good cable about this one Quote:
br, | |
02-27-2010, 06:13 | #11 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | the problem was only getting restart in 15 mins...... so when i buscheck everything was ok... so i thought need to flash .. but now this problem m facing set is dead now............................................... ........................... |
02-27-2010, 10:07 | #14 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | see here one more logs by LATEST UPDATE Super SD AUTH Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. ApeCoreSw: V 5.0819.4.0.1 07-05-08 RM-180 (C)Nokia SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D Restarting phone ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...Connection timed out ERROR: could not connect to server! |
Many Many bugs pleas fix it !!! | 1NOKIA1 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 07-02-2009 00:24 |
many bugs in cruiser version 10.33 | Naseerjako | Cruiser Suite | 5 | 03-09-2007 01:07 |
Uni Dongle Whats Hapning To Many Bugs | tunjay-gsm | Universalbox | 1 | 12-01-2006 12:02 |
SonyEricsson Cooler v1.0 I`m think have many bug`s!!! | Zone_x | Sony Ericsson | 41 | 04-17-2003 10:26 |
