06-09-2009, 13:52 | #1 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | MobiEx 3.2.1 detected virus I have download new version of MobiEx in support area but detected virus at Mobiex.EXE, the virus New Heur PE Virus by Eset Smart Security antivirus. Please clarify about this!!! I was disabled my antivrius n run the program but still problem with WD2 bluetooth flashing always error, please fix the problem. Thks & Regards, |
The Following 2 Users Say Thank You to abellcell For This Useful Post: |
06-09-2009, 21:36 | #6 (permalink) | ||
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Quote:
if you not sure, send the binary/exe to your antivirus support to make sure your self. BR. | ||
06-10-2009, 03:29 | #7 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | hi, I-mobile I was fix the problem about viruses and was submit to EAV for analize, it is okay. WD2 flash Bluetooth error, logs: Nokia 3660 NHL-8 : Processing file: Nhl83050.8C1 ASIC ID: 0x1081 [UPP_WD2_v3.2,3.2E] w3_2nd.fia: [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x10D8 FlashID0: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 00000000-007FFFFF FlashID1: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA w3_amd.fia: [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7F10 Performing Flash Authentication ...OK UEM ID: 005F92A0:2984DA7E Programming MCU ... Nhl83050.8C1: [WD2 BT2][WD2 CBUS BT] size: 18.02 MB Area [00000000-0000FFFF] erased in 0.547 s Area [00010000-006FFFFF] erased in 58.125 s Area [02000000-023FFFFF] erased in 32.875 s Area [04000000-046CFFFF] erased in 55.484 s Flash programming ... BT MCM image (0x21): 0002DD00 Error while programming [00] at 0x00000021, Result: 0200 Flashing terminated with error(s) in 3 min 0.140 s RX Buffer: 0200000000D172 Ngage QD RH-29 : Processing file: rh2941.5c1 ASIC ID: 0x1081 [UPP_WD2_v3.2,3.2E] w3_2nd.fia: [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x10D8 FlashID0: 0001 007E [AMD 29BDS128J] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 0001 277E [AMD 29BDS064J] page size: 64 K type: NOR area: 02000000-027FFFFF FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: C900 00EA 7001 00EA 7301 00EA FFFF FFFF w3_amd.fia: [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7F10 Performing Flash Authentication ...OK UEM ID: 00D15646:2984DA7E Programming MCU ... rh2941.5c1: [WD2 BT2][WD2 CBUS BT] size: 17.62 MB Area [00000000-0000FFFF] erased in 0.531 s Area [00010000-00FEFFFF] erased in 1 min 54.890 s Area [02000000-027FFFFF] erased in 1 min 1.078 s Flash programming ... BT MCM image (0x21): 0002DD94 Error while programming [00] at 0x00000021, Result: 0200 Flashing terminated with error(s) in 3 min 39.500 s RX Buffer: 0200000000F172 I flash used other tools, it is okay. Thks & regards, |
06-10-2009, 07:13 | #9 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Checking for application updates, please WAIT ... Version from app: - Executable: 3.0.0.5025 - Library: 1.0.0.4728 winsock error: No data was read because the remote system closed the connection (recv() == 0) Server temporary unavailable. |
mt-box not working in new ver 3.2.1.3,2,1 | .::PATEL TELECOM::. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-04-2010 10:49 |
MobiEX 3.2 rev 5.2 WD2 PPM Flashing | abellcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 10-10-2009 04:53 |
MobiEX 3.2 rev. 5.2 Unlocking DCT4+ RM-298, RM-340 n RH-112 | abellcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-09-2009 07:30 |
